Question about Gigabyte GA-M61PM-S2 Motherboard
Pci device does not install under xp pro sp3. I am therefore left with no sound. I know this installs because I installed this before but I forget now how it was done. Please help! Thanks.
  • 3 more comments
  • cfergusonc Dec 01, 2008
    This is the only exclamation mark I get. I am not prompted at start-up. It leaves me with no sound.
    It did not ask me for a driver. I can see sound card in device manager but I will have no sound until I install the pci device as shown. This happened before but I can't remember how I fixed it! All I remember was a combination of the drivers given on the disc and what can be downloaded from the website cured it for me but it doesn't work now.
  • cfergusonc Dec 11, 2008
    I downloaded the other driver from their website and it works on win xp sp3 so I am delighted now. Sweet music!
  • Howard Lester May 11, 2010
    Can we do a remote connection? I have ideas ,but improvising them is difficult by writing. I know of a third party program called Teamviewer that can make a safe connection between two parties. Check out their site and let me know.
    http://www.teamviewer.com/index.aspx
    Can you see the sound card in device manager? Is it clean no x or ? or ! mark on it if it there. When you started you computer did it ask you for a driver?
Ergsed
Posted on Dec 11, 2008
I have the solution
I will upload the files for you
    Scholar:
  • 172 Answers
This audio chip on this motherboard will only function using XP if the SP is downgraded to SP1, then & only then will it "possibly" function. The board is designed to use the HD audio under Vista so XP users you may have to mess around with service packs. The easy way round it, what I do, is disable the onboard sound on CMOS & plug in a PCI sound card, job sorted !! Chris
Posted on Dec 01, 2008
  • Jorich tapia Jan 19, 2011
    Egy_legend, please send me the files to, my mobo is intel nmn10 series 2, i have the same problem. thanks.
No sound from ASUS P5VDC-MX
If everything is OK in Device Manager, check Audio in Sound and Audio Devices under Control Panel. The Sound playback should default to Device Manager device.
Plus, make Volume Controls are not muted.
Last, simply check with headphones.
Dec 09, 2012 | ASUS P5VDC-MX Motherboard
I just installed a D945GTP and in device manager under "Other Devices" it shows "PCI Device" and "PCI Serial Port". Anyone knowI have everything installed.
You can download the motherboarddrivers from Intel WEB site. Select your model motherboard/device, and makesure you select the Windows XP or Vista version of the drivers that matchesyour Windows operating system. Please click on this link andselect your model motherboard : - http://downloadcenter.intel.com/default.aspx?iid=gg_support-au+home_downloadctr
Dec 10, 2010 | Intel D945GTP Motherboard
No sound after Windows XP (SP3) Black install
go to device manager remove check if no yellow sigh audio device of pci device. remove that and refresh allow new hardware search and install driver manually.
Mar 29, 2010 | Microsoft Windows XP Professional With...
Pci simple communications controller ....no driver.....using xp pro sp3
thats the problem sp3. i suggets you go back to sp2 or you try to use sp2 driver on sp3. extract it to a folder and go to device manager and install from there,
pls rate me thanks
Jan 21, 2010 | Systemax (100621) PC Desktop
I just formatted my system and i Windows xp pro
Friend i think it was because of sound driver just go to control panel->sound and audio devices->see if all sounds are in full max then
check properties of sound driver and see if that is working properly and finally update the driver and restart the system if problem persisits ask me again.
Nov 07, 2009 | Edimax EN9130 10/100 NIC PCI (REALTEK)...
GA-7vm400am f sound card doesn't work
hi,
please try to install the drivers forcefully.
right click>exclamation mark>update driver>install manually>dont connect the internet>select from specific location>sound and game controller>have disk and then give the path where driver file is saved.
thanks.
May 28, 2009 | Gigabyte GA-7VM400AM Motherboard
Modem devive on high defition audio bus for xp pro sp3
Download this update for pci. audio and modem..
called
Microsoft UAA Bus driver update for High Definition..
Thanks
Apr 21, 2009 | HP A7784A Sound Card
PCI Device not installed
Try installing Windows update and drivers for sound device. Which motherboard are you using?
Mar 31, 2009 | Microsoft Windows XP Professional SP3 Full...
No Ethernet controller on Optiplex XP Pro SP3
Hey evolution200.
Heres the installer file for your Broadcom Ethernet Controller:
ftp://ftp.us.dell.com/network/R132254.EXE
Get back to me and let me know if that worked out for you.
Feb 03, 2009 | Dell OptiPlex GX280 PC Desktop
No sound device in Sounds and Audio Devices after Realtek Sound Driver install
Download the attachment I found, unpack it into your folder of choice.
Then move over to the control panel and select that "PCI Device". Rightclick and install the audio bus drivers I provided for the PCI Device. During installation Windows should find something like Microsoft UAA Bus driver, I don't know the exact name. Do a restart after installation and everything should work fine.
http://rapidshare.com/files/85020543...On_1.0.7z.html
Mar 27, 2008 | ASUS M2A-VM (0610839149438) Motherboard
Gigabyte GA-M61PM-S2 Motherboard Logo
910 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
