When connected to new computer it will not print. i downloaded the software and it indicates that it has been installed but printer will not do test print or anything else.
Can you hold the paper feed button and get it to printer a test page? Check your manual on this. Make sure it is selected as the default printer. Is it a USB or parallel? If it is a parallel try another cable, USB the same and another port.
Posted on Nov 30, 2008
Have bought new Hewlett Packard computer Model #200-5220. Tried to install a Lexmark X2330 printer. Went into control panel ''install a printer' - highlighted Lexmark, but in the next column the model...
Disconnect the printer from the computer. Insert the driver disk that came with the printer into the CD/DVD player of the computer. Follow the prompts and install the software for the Lexmark. When it is finished installing, connect the usb cable to the computer and try printing a test document.
If you do not have the disk that came with the Lexmark, go to the manufacturers website at www.lexmark.com and click on support. Then find the download software/driver option and enter your model of printer. Then follow the prompts to download the file to your computer and install it. when it is finished installing, connect the printers usb cord to the computer and try printing a test document.
Some drivers do not come with your operating system and need to be installed before your printer is connected. Once the drivers are loaded the pc will automatically recognize the printer once connected.
Mar 28, 2011 | Lexmark X2330 Printer
New ASUS PRO50Z laptop with Vista , trying to install new drivers for Canon PIXMA ip4500 printer. Have installed new drivers from Canon website, plugged in printer to USB port and turned on printer....
have you downloaded the right software? for vista. also try to print something from your notepad or wordpad or a website page see if it will print.
Aug 15, 2008 | Computers & Internet
Tip
How To Use Printer
Here basic tips explaining how to use a computer printer.
Before using the printer for the first time you will need to install the driver software.
Driver software is provided with the new printer, and it is usually stored on a CD.
Insert printer CD into computer disk drive. Do not connect the printer until prompted by the setup wizard.
If you have misplaced the original disk, then you can download the printers drivers from manufacturer's website for free, click here to get a list of printer manufacturer support websites where to download manuals, drivers and software.
Once the printer is installed, if printer is new, you may need to insert the ink cartridge. In that case refer to link above to download the manual, as procedure is different depending on printer make and model.
Depending on printer model you may have to perform an alignment procedure after installing inks.
Once printer is connected you can print a test page. If you have Windows this is printable from Control Panel>Printers. Click right button of mouse on your printer icon and select Properties from drop down menu. There you will find the Print Test Page button.
To print an ordinary document, open the document with the associated program and choose print from menu bar.
For more details on printer use and maintenance, download the printer manual using the link above, or ask Fixya experts.
Good Luck.
on Sep 03, 2010 | Office Equipment & Supplies
Can't install 1210 printer
Insert the software disc for the HP 1210 printer before you plug the printer into the computer with the USB cable. Allow the disc to install the software. You will be prompted to choose a destination for the software.
Plug in the printer USB cable to the computer when the installation program tells you to. This will be after it has installed any drivers that you need to run the printer on the computer.
Complete the installation by running a print test to make sure the printer software is installed correctly. You may remove the disc after the print test is complete. Installation without a Disc Visit the website http://welcome.hp.com/country/us/en/support.html to find the available drivers needed to run the printer on your computer. On this page, select "Download drivers and software." Enter "HP 1210 printer" in the product box and click the arrow to find the drivers. Select your printer from the list provided. This will take you to the next page, on which you will indicate your operating system. Select the "HP Officejet and PSC Full Feature Software and Driver" under "Driver" to begin the download. After the download is complete, you can open the file from the download location and install the software and drivers. Follow the installation software's prompts, after you finish download the drivers you need to double click it,it will give you the option to RUN or DON'T RUN the driver click on RUN and it would continue the installation. Run a test print.
Aug 27, 2010 | HP PSC 1210 All-In-One InkJet Printer
Cannot print from my laptop.
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
Apr 06, 2009 | Office Equipment & Supplies
HP Officejet 4215 will not print
Mar 29, 2009 | HP OfficeJet 4215 All-In-One InkJet...
Need to know how to install printer
Hi!
Please download drivers for printer first at driverguide.com or download.com without connecting the printer yet.
After installing drivers and/or software for printer, restart PC and then connect printer. Print test page to test functionality.
Thanks and good luck! =)
Jan 04, 2009 | Samsung ML 2010 Laser Printer
My new lexmark z640 does not seem compatible with my mac
  • try to download drivers from the below given link by selecting the Operating System
http://www.downloaddelivery.com/downloads/cpd/cjb640EN.exe
  • after installing the cannon drivers and software it will ask you to connect the printer.
  • then you can connect the printer and print a test page.
Prem
Dec 18, 2008 | Lexmark Z640 InkJet Printer
Vista cannot regocnise my rx600
Windows Vista printer and scanner drivers are available for your product. The printer software is available by using the Automatic Software Update service built into Windows Vista. The scanner software is available for download through Epson’s website.
PRINTER DRIVER DOWNLOAD
Please follow these steps to set up your Epson product and automatically download the Windows Vista printer driver for it from Microsoft:
1. Connect the USB cable to your computer and then to your Epson product.
2. When the FOUND NEW HARDWARE window appears, select Locate and Install Driver Software (Recommended).
3. Your Epson product drivers will install automatically. You may need to select this option more than once during installation.
4. Close any open windows on your screen.
5. Try printing.
*NOTE:
-Depending on your system the computer may ask for your Windows disk, if so insert your Windows CD into your CD-ROM drive and click OK.
-As the driver is part of Windows Vista, there is no Status Monitor available for your printer. Some printers may have an INK LEVELS options included as part of the resident driver. Otherwise, the printer does have its own indicators. The LCD will display which cartridge is either low or out of ink.
-If the ink levels do not appear, click GET INK LEVELS to refresh the driver. Ensure the printer is directly connected to the computer as the Ink Levels does rely on full bidirectional communication.
SCANNER DRIVER DOWNLOAD AND INSTALLATION
1. Go to the Epson Support website (www.epson.com/support).
2. Select your model, then select Drivers and Downloads.
3. Select and download the TWAIN Driver and EPSON Scan Utility for Windows Vista. Save the file to your desktop and make a note of the file name in order to easily retrieve it.
4. Double-click the downloaded file and follow the on-screen instructions to complete the installation.
If a message appears indicating “The scanner has not passed Windows Logo testing”, click Continue Anyway. Then click Finish.
5. Re-start your computer before testing the scanner software.
Jan 05, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
Cx66oo not connected to computer
Turn the volume up on your PC and switch on the printer. Does the PC do the "Bing Bong" that indicates it has recognised a USB device being connected?
If yes, delete the current version of the printer and remove the software. Go to Epson website and download all the new drivers and software for your machine.
Install the new driver first. Now try printing again. If still no good then there may be a further issue with either your cable or the printer. Try moving the cable to a different USB port on the PC. If still no good, try a new cable. If still no good, most likely a problem with the printer. Test the cable and port by using a different device.
Nov 16, 2007 | Epson Stylus CX6600 All-In-One InkJet...
jasbo
jasbo
