Question about Plustek OpticPro 9636T Flatbed Scanner
Scans in solid colors
Had this scanner for a few years but it has always faithfully worked on Win XP. scans are now coming out either solid red or solid yellow. If i do a direct scan to copy function, the paper only has a few lines on it, noting else Have power cycled several times and reinstalled software. Any ideas? thanks for any help
  • 2985 Answers
SOURCE: problems with installing a plustek 7200i film scanner
Delete the software. restart computer Come off line. Disable the anti virus software and fire wall. Now reinstall the software. Check out that is runs before reinstating A/V and firewall.
Posted on Jul 24, 2007
0 characters
1 Points
Red and green colors appear on the right-hand edge of scans
Yes I think it is time for new scanner . Hope this helps
Dec 19, 2015 | Epson Perfection Scanners
Drivers HP scanjet 4400c for windows 7
This worked for me:
Do NOT connect scanner before these first few steps
1. Download & save win xp drivers from HP website:
The 63.4mb file is the only one you'll need
2. Right-click on the saved file and go to its properties. Under the compatibility tab, set the file to run with win xp service pack 3. Apply changes and close properties dialogue.
3. Right click on the same file and choose 'run as administrator'. Accept any windows prompts that may appear and let the program & drivers install.
4. Once the software has finished installing, connect the scanner to your computer (via USB) and turn the scanner on.
5. Restart the computer without unplugging or turning the scanner off.
6. Your scanner should now work fine with the HP Precisionscan Pro utility.
Oct 31, 2011 | HP Scanjet 4400c Flatbed Scanner
I have a hp scanjet 3670 flatbed scanner and cannot get the toolbox desktop icon anymore with which i used to be able to select what kind of scan to do, such as picture, document or color slides' I have...
This is something you need to talk to Hp about. Hp which maked your old scanner is the only one who would need to rewrite a software package that will work in the new win 7 operating system.
I do have a solution to your issue without calling on HP to help you:
Dual boot your harddrive: One side Win 7 and the other Win xp. Use your Hp scanjet and it's toolbox software in win xp and now you will never have compatiblitity issues with your unit again.
If you need to know how to dual boot your hard drive, let me know and I'll tell you ok?
Aug 09, 2010 | HP ScanJet 3670 Flatbed Scanner
Canoscan 9950F scanner will not scan with Win XP
Since you have had the scanner a while, you may not have a recent enough driver to work well with XP: until I smashed my 9950F, I was scanning under XP with the ScanGear CS 10.324a driver with no problems (the driver is dated 22 June 2007). You can download it from several sources on the web, I used
Other than that, they report some issues if the system drive is NTFS, but I was using NTFS for my system (and only) drive, so I don't see any reason for this to be your problem.
Good luck,
Mar 19, 2009 | Canon CanoScan 9950F Flatbed Scanner
Mustek Scan Express A3 USB Scanner
I've had a similar problem with the streaks, lines and color bleeds appearing in the scan. Try uninstalling the all software and drivers for the scanner and reinstall. Worked for me. Have had to do this a couple of times since I've owned the scanner... about three to four years now.
Jan 25, 2009 | Mustek A3 USB Flatbed Scanner
Driver for Acer Vuego 610P
Instructions for installing Acer brand parallel port scanners in Windows XP:
For this driver to work in XP you must install the MiraScan software then install the scanner manually.
Step 1. Download MiraScan v3.424 from the web :
Step 2. Unzip and install the Mira Scan driver that you just downloaded. After installation , system will suggest you to add a scanner
Step 3. Then, add an imaging device
Step 4. Then the Scanner and Camera Installation Wizard comes up. Click Next at the bottom.
Step 5. Then on Scanner and Camera Installation Wizard screen it will ask you which scanner or camera do you want to install? You want to go where it says "Manufacturer" and then click on EPPSCANNER and where it says "Model" it should say color flatbedscanner. Make sure it is highlighted, also. Click on Next at the bottom.
Note: For additional of this procedure and installation procedures, please read the pdf file posted here:
from Vuego Scan
Nov 26, 2008 | AcerScan 610P Flatbed Scanner
Scanner dint work
I purchased Canon DR 9080C scanner two years back but the CapturePerfect 3 not received. So speed is slow. Can Canon Big help me to provide capture perfect 3 software. My email is
Jun 07, 2008 | Scanners
I need a driver for snap scan 310 p that work with win xp
please help me with installation driver for, snapscan 310 scanner
Mar 06, 2008 | Agfa SnapScan 310 EPP Flatbed Scanner
Acer 640p driver
install scan mira scan then go to control panel >> scanner then add an imaging device then EPS scanner then color flattebernd scanner then cotinue anyway .. then ENJOY
Feb 15, 2008 | Acer ScanPrisa 640P Flatbed Scanner
Driver needed to update my Agfa Snapscan 1212p to use with windows Vista
I from Chile and the solution I write in Español
tienen que descargar el driver de la pagina de agfa
luego renombrarlo cambiando la extensión exe a zip y descomprimirlo en alguna carpeta,
colocan instalar manualmente y dan la dirección de la carpeta donde descomprimieron el archivo,
win da una alerta que el driver no esta firmado, proceden y con esto queda el driver instalado sin incompatibilidad, pueden revisar el “administrador de dispositivos”.
Para scanear, sobre el icono del scanwise, colocan propiedades (boton derecho del mouse) y en compatibilidad colocan con win95
no olviden instalar el driver para que se instale el scanwise
suerte y saludos
Nov 07, 2007 | Agfa SnapScan 1212p Flatbed Scanner
Plustek OpticPro 9636T Flatbed Scanner Logo
Top Plustek Scanners Experts
Mohan Sriraman
Mohan Sriraman
Gareth Cockram
Gareth Cockram
Are you a Plustek Scanner Expert? Answer questions, earn points and help others
