this is a GE profile wall oven model # JT955B0F8BB. I have checked the breaker and it is fine. Will pull the oven out this evening to check the power at the oven.this is a GE profile wall oven model # JT955B0F8BB. I have checked the breaker and it is fine. Will pull the oven out this evening to check the power at the oven.
solved pulled oven out of cabinet and checked connections. neutral was disconnected.solved
You can't post conmments that contain an email address.
1. Check the power supply to the oven. Make sure the power cord is securely connected to the outlet and that the outlet is providing power.
2. Check for a loose wiring connection inside the oven.
3. Check the display control board for any signs of damage or corrosion.
4. Replace the display control board if necessary.
When the power drops, it often sends a spike down the power line. Most electronics are sensitive to voltage spikes and if too high, destroys the equipment. Unfortunately your display is probably toast.
Hello, What will cause that is a part on the clock that powers the display to illuminate has gone out yet the part of the clock (also called the electronic oven control) that send power to the heat elements is still working.It may work like that for years as long as you done mind the clock not displaying, OR to get it to display the clock/eoc would need to be replaced .
There is a safety thermostat located in the back side of this oven. When looking at the oven, from the back side, it will be located on the right side. I have a part number of 318003613. Good luck.
solved
