Question about Frigidaire 24 in. GLD2150RCC Built-in Dishwasher
The dishwasher will not run
I have Model #GLD2150RCB0.
The unit ran fine on 11-26-08. Tried running it this morning, and nothing happened.
Found water in the bottom of the unit, dis-assembled the wand etc. in the bottom, and sucked out the standing water. Put everything back togather, pressed start, the lights lit up where programmed on the control panel, and after a moment just heard a click. And, nothing happened.
On advice from my father, I checked for any blockage in the discharge hose under the unit to the garbage disposal. There isn't any and the inside of the garbage disposal is clean.
Please help....The unit is only 4 years old and Christmas is around the corner...
Also, I am quite handy at fixing things.
  • 1 more comment
  • chris_napols Nov 30, 2008
    Gary,
    Thanks for your advice. As I indicated the plastic drain line did not have any obstruction from the discharge under the washer to the disposal. Also, the "top hat" moved freely but, I will check it for debris.
    Any suggestion on checking if the motor or water pump is working properly?
    Your help is greatly appreciated...
    CMN
    I have not checked for a burnt out fuse link however, if it is blown and correct me if I'm wrong, I should not get any power too the main control panel?
  • chris_napols Dec 09, 2008
    I removed the Motor and the discharge impeler pump. Any suggestions on how to perform a bench test?
  • 24 Answers
Ftp://ftp.electrolux-na.com/ProdInfo_PDF/Kinston/154476001.pdf
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Kinston/154475601en.pdf
Above is a manual and wiring diagram.
There is a test you can initiate by pressing two buttons, see the wiring diagram.
Couple things to consider.
1) Since you say lights come on, seems the door switch is probably OK.
2) There is a level switch, which switches the motor, etc. off if water level gets high.
Check this switch which should have about an inch travel. (Device looks like a top-hat).
You can lift it out and clean under it as well. All this amounts to is a float, it operates a switch under the floor of the d-washer.
If this doesn't get you going, I suspect the timer or the motor.
A blocked drain is definitely reason for the dishwasher to leave water in the bottom.
Seems removing the water should have left it run a partial cycle.
What your dad said is on the right track. You will need to disconnect the hose from the disposal or small drain pipe where the rubber hose connects to the drain. (can be the side of the disposal). Other end is connected to the dishwasher and can be removed from there as well.
Water will be in it, have a towel ready to catch the water. You can check it for any kind of blockage once you disconnect it. Careful not to run water in the sink while disconnected, it can run out the opening.
Manual has troubleshooting tips and may be of some help, though I didn't see your problem as one of the tips.
Let me know.
Gary
Posted on Nov 30, 2008
  • Gary C Smith
    Gary C Smith Dec 09, 2008
    Hello again Chris.
    From the wiring diagram, it looks like the main motor has a 2 wires, one white and one blue.
    The pump motor has a 2 wires, one white and one violet.
    Both have impellers that should turn freely, as will the motor.
    They mention bearings being seized, so they may have a history of failure.
    An ohm meter test Wh to Bu should show some resistance, probably something less than 10 ohms.
    The motors are 120 v, so 120 applied to the WH and BU wires should result in the motor running.
    Same for the pump motor, but WH and Violet.
    Main motor shows a thermal switch. If it shows infinity ohms and doesn't run, switch may be the cause.
    Either way, motor will have to be replaced. Thermal switch is usually embedded in the windings and cannot be replaced.
    Again, take care.
    Problem Solver:
  • 7 Answers
Did you check electronic board/ if your unit has a burnt inline fusible link inside unit were electronics are did you check fuse box tomake sure fuse wasnt burnt
4 Suggested Answers
  • 159 Answers
SOURCE: Garbage Disposal backing up in dishwasher
Most dishwasher have a check valve at the pump to prevent water from backing into the dishwasher. If the pump is electric there is a rubber flat that may be gone or not working properly. If that is the case you need to replace the pump. If the pump is part of the motor assembly then the pump and motor will need to be replaced. One other thing to make sure of is that you have the drain hose looped to the top od the dishwasher and then to the disposal conection. Its called a drain loop and all dishwashers should have it. Good Luck
Posted on Jul 12, 2007
Skill Will
  • 53 Answers
SOURCE: Dishwasher not pumping the water out?
hi
the larger motor housing underneath the unit is what moves the water around to wash, the smaller pump is the drain pump, if you don't hear that running it is likely in need of replacement. check your paper work for warranty, if it's out of warranty try to find a deal online and it's relatively easy to replace
Posted on Mar 21, 2008
heatman101
  • 43501 Answers
SOURCE: Water Stayed in dishwasher
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Sep 29, 2010
Have a Bosch SHU43C05UC/14 dishwasher. Water comes in, gets heated, but the unit never seems to go into wash cycle, fills, then drains a little.
This may sound odd but might work.
Reset the machine as to start a new cycle. Add 2-4 cups of water. If the machine starts and runs through a cycle then the water inlet valve needs to be replaced.
Good luck
Jan 02, 2014 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher does not heat dry
Hello Jamie Wolz - Try resetting the unit either by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. Make sure the rinse aid dispenser is filled and check that the incoming water temperature is not less than 120 F. Restart unit and select normal cycle. If it proves to be ineffective, contact a professional to move forward accurately. The dishwasher may be experiencing a wiring failure or a communication error with the control panel.
Dec 18, 2012 | Electrolux Frigidaire Professional Series...
Won't drain and unit will not shut off
water will not go into my dishwasher any solutions
Nov 16, 2009 | Asko D1776 Stainless Steel Built-in...
Whirlpool Dishwasher won't drain during normal cycle
As you say a clogged line or valve does not make sense.
Try running it without the heated drying and see if it empties or if the cancel button will work then.
The dishes should air dry quickly if you empty it and open the door.
It could be a defective thermostat allowing it to get too hot during the heat cycle
May 18, 2009 | Dishwashers
Bosch SHU3300 dishwasher stuck on hot water intake (w/ no power)
It sounds like the fill vlave is stuck open. This can happen if your pressure is low or if the machine is old. I would start by replacing the vlave.
May 12, 2009 | Bosch 24 in. SHU5305UC Built-in Dishwasher
We have just installed GE Model GLDL560NSS. It fills with water and it emptys the water but it doesn't actually wash or rinse. The water just sits at the bottom of the dishwasher tub
I had the same problem running the dishwasher the second time. The first time worked perfectly. I thought the problem was from the sensor not reading enough water to actually start the wash cycle. It sure uses less than any dishwasher I've had before. When I tried to restart it the machine drained the water that was in it. I later found out it does this automatically when you push the restart button. I poured water from a bucket into the dishwasher and tried this a few times and found that on the fourth try it ran fine and haven't had a problem since. I didn't know how much to put in and did overfill it once. Maybe the sensor float or whatever was stuck and overfilling it helped.???
Jul 23, 2008 | GE Dishwashers
Dishwasher will not drain water out after completing the rince or final cycle
hi there,
check to see if there is anything stuck in the pump. if there is nothing and the problem persists, have the technician replace the drain pump.
May 02, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Neff dishwasher continuously attempting to pump out water
I have just encountered the same problem on my S5433 XO GB/13. Did you manage to get a solution.
Jan 17, 2007 | Neff 24 in. S5443X2 Built-in Dishwasher
Frigidaire 24 in. GLD2150RCC Built-in Dishwasher Logo
276 people viewed this question
Top Frigidaire Dishwashers Experts
Electrolux
Electrolux
Mike Cairns
Mike Cairns
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
