Question about KitchenAid KSRS25IL Side by Side Refrigerator
KitchenAid ksrb25fkss01- fan runs, warm air circulates
I have a KitchenAid ksrb25fkss01. Once or twice a week, it does not circulate cold air, instead the warm air (almost room temp.) air is circulating inside the freezer section. The frozen food thaws. Couple of ours later, it starts working normal again. During this phase motor works fine, and there are no strange noises coming from the compressor. I cleaned all the coils, no avail. I called a tech, he showed up and said the compressor is going out without even really examining the fridge. He also told me that the compressor is going to cost about $800. Is the compressor going out or this problem is due to something else? If the compressor is going out, can I replace it. I found this replacement kit:
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=961572&PPStack=1
Is this feasable?
Thanks,
Ertan
  • ertan Nov 30, 2008
    Gary,
    Thanks for your helpful reply. Your assessment coincides with my original logic. This unit is approx. 5 years old. I inherited it when I bought the house in 2004. Sears technician was a knowledgeable elderly guy who asked me some questions and then suggested that the compressor was going bad. He did not run any tests as the frig was working fine when he showed up.
    I agree with you that trying to change the defrost timer is worth trying, My next option would be to go get a frig during the holiday sale season, but it will still cost me about $1000. My unit is in perfect shape, I don't want to replace it unless I have to.
    Although, I am a very handy and tech savvy person, I don't know much about repairing refrigerators. I opened the unit's back panel once to check the obvious stuff. Everything seems in order; when the compressor is running, the fan is also blowing, and the compressor is running quietly. One simple question, where do I find the defrost timer, and what does it look like? Once I locate it, I'll test it as you suggested.
    Thanks again.I appreciate it.
    Ertan
  • 24 Answers
Compressor change is probably more than you wish to tackle.
1) must be certified to work with refrigerant.
2) requires silver soldering and or silver brazing.
3) requires re-charging with refrigerant and this is critical and must be measured to the oz.
If it works fine when it re-starts we need to find out what is stopping the compressor. First guess is a defrost timer. The unit goes into defrost at pre-determined intervals, depending on the defrost timer. When it goes into defrost, compressor goes off, heaters come on, and a defrost cycle is initiated. Following this, the heaters go off, (usually by a t-stat and not time), and the compressor is allowed to run again. Changing the defrost timer, which is probably one of the least expensive components, is worth a try. No guarantee, but it is a better choice than the compressor. If the tech did any tests, did he say why the compressor was questionable? Since this happens once or twice a week, it sounds like the timer or at least it is coinciding with a typical defrost cycle. Here is a possible test, when you find it blowing warm air in the freezer, advance the timer 1/4 turn cw. See if the compressor comes on when you do this. That is probably more info that you were looking for, but this is worth a try.
How old is the unit?
Gary
Posted on Nov 30, 2008
  • Gary C Smith
    Gary C Smith Dec 01, 2008
    Best way to find timer is from manual.
    These fellows are about 3" or 2.5" square. Have several wires to them. Have a dial in the center that allows a screwdriver to advance.
    Normally in front or back at floor level, although some are in different places.
    Looking at the manual and parts diagram from Kitchenaid, there is an adaptive defrost control. Appears to be electronic control and not an analog control, as in the past. Suppose there is electronic test done with test equipment made for techs. Sorry.
    I suspect a good tech could help with this.
    Note: Compressor and entire sealed system should have a 5 year warranty.
    Kind Regards,
    Gary
The freezer is cold but why is the refrigerator warm?
Likely, either your circulation fan has stopped working due to icing, or you have ice buildup in the cold air duct between the freezer and refrigerator. Try unplugging your refrigerator overnight with the doors open, mop up any melt water with towels, then plug the refrigerator back in next day. Listen for the circulation fan in the freezer and, if it is not working or not moving air, replace the circulation fan.
May 21, 2015 | Refrigerators
Hotpoint FFB6187
sounds like 2 things either the t stat making fridge run all the time, or 2 the fan not having enough cfm to circulate the air.
Nov 06, 2013 | Freezers
Freezer is too warm. We have cleaned all vents but is still in the 40s
Compressor is one reason why your freezer may not get cold. The compressor which is usually found at the back of the freezer helps to pump out gas/ cold air and the fan circulates this cold air in the freezer. If this compressor is knocked/defective, the freezer won't cool. Also, gas in the compressor sometimes get's finished and needs to be refilled. So, the compressor needs to be checked in a situation like this.
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster.
I hope the above helps.....
For further assistance, please let me know.
Regards.
Sep 15, 2011 | Maytag Freezers
It is running but is not freezing the food
Regards.
Sep 15, 2011 | Maytag 15 cu. ft. / 425 liter Upright...
The freezer is not working... It has been slowly warming up for a few weeks. What could be wrong? Also, does this mean that the fridgerator is next to go? We have a GE Model # GSH25KGPA WW
Good luck.
Sep 14, 2011 | Freezers
My freezer is no longer freezing
Regards.
Sep 14, 2011 | Hotpoint Freezers
Freezer too warm
Let's start by diagnosing the freezer;
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food
Good luck.
Apr 07, 2011 | Fisher and Paykel Refrigerators
Freezer not getting cold
Good luck.
Mar 29, 2011 | Refrigerators
Model 106.9630280 The freezer is working but
you probably have a bad air circulation fan or a restriction in the ductwork between the freezer and the refrigerator that the circulation fan supplies the cold air from the freezer to the refrigerator compartment. you should be able to hear the circulation fan motor running when the unit is in normal operation mode. the only time the fan will not be running is when the unit is in defrost mode which occurs once every six to eight hours depending on the defrost timer in your unit.
Mar 14, 2010 | Refrigerators
Cold air circulating fan
behind back panel inside freezer. take back panel off
Oct 19, 2008 | LG Refrigerators
KitchenAid KSRS25IL Side by Side Refrigerator Logo
317 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
