Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
USB Drive Problems
You replied to my post about USB drives. Thank you for your help, but I don't know what smd level is. Also, I have no idea how to do a file recovery. Any help would be greatly appreciated. Thank you.
Not detecat
Posted on Dec 02, 2008
It is not open showing error
if you want to know what this is the error code is related to
click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
you might be able work your way through the problem
if you need more help with this post a reply with the error message details
or
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
if you need more help with post a reply
hope it helps
Aug 22, 2012 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Artista 200 flash drive not recognized
for xp operating system
hope it helps
Jul 22, 2012 | Bernina artista 200
I have a 16 GB Clickfree Flash Card and when I plug it into my laptop the laptop fails to recognize it. Any ideas?
you might have restore it to its defaults
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
If you need more help with this post a reply
hope this helps you
May 08, 2012 | ClickFree 16GB TRAVELLERMULTIPLE COMPUTE...
A problem occurred during hardware installation. Your new hardware might not work properly.my pen drive 8GB
hi! can u help me? i bought usb flash drive yesterday hp 8gb and it's properly working, when i create bootable usb im in diskpart in command promp and my computer got freeze not responding, im in a computer shop that's why i remove my usb flash drive and just went home. when i plug the usb it says a problem occured during hardware installation. i know there is the connection about diskparting the usb yesterday. i troubleshoot my usb flash. i go to device management and uninstall the usb drive and scan plug and play, but its not working it always show the yellow mark. even i update the driver its not working. what should i do? i hope u can help me :( here is my email just incase u have a solution for me. rk_mrace@yahoo.com Thank you very much!
Feb 16, 2012 | Electronics - Others
Its saying that please insert the disk. what's wrong with it? i have just opened the pack of ma brand new 16 GB pen drive. nybdy have ny idea then please tell me.. thanks
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
hope this helps you
Dec 23, 2011 | Generic Memory USB 2.0 128MB Black Pen...
I am trying to retrieve some files I had copied to an 8GB Dane-Elec Twice Memory USB flash device. Even though I don't recall improperly removing the flash device, I may no longer acces the files on...
ports(com&lpt)right click update driver if this fails to fix the problem
hope this helps you
Nov 02, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
Need instruction manual don't know how to use
An example on how to download and save to an External Hard Drive and copy and paste to an External Hard Drive Click start all programs accessories open windows explorer navigate to your data
Right click on the data select copy navigate back to the External Drive.
or right click on the data select paste or select the data hold the mouse cursor then drag the data to your usb drive then drop it in
or if you are downloading data from the internet.
Once it starts downloading windows will ask whether you want to run or save it
a browse option will open you can save it into your External Drive or a folder in my documents or another device or a usb device
if you need more help with this post a reply Hope this helps
Oct 27, 2011 | Kingston 2PK 4GB USB 20 DATATRAVELERI GEN...
How format datatraveler 8gb
click start click on my computer you should see your usb drive
right click then select format
another way is to control panel administrive tools computer management disk management right click on your drive select format
hope this helps
Sep 15, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I am looking for a manual for FreeAgent GoFlex Desk USB 3.0. I have no idea how it works. It doesn't need fixing, I need to know how to do various tasks.
Here's a link for all the Seagate FreeAgent GoFlex external hard drives support page: http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=goflex-support&vgnextoid=884623db95b07210VgnVCM1000001a48090aRCRD
I would suggest finding the quick start guide for your external hard drive and reading that first.
Thanks for using FixYa; please post back if you have any problems and I will help you further.
Apr 09, 2011 | Seagate FreeAgent 2TB GoFlex Desktop USB...
Cant open or view files
I have this same problem with my mac not reading the USB. I will let you know if i get a reply and will you do the same? Thanks!
May 10, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
22 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
