My dimplex duoheat radiators keep clicking madly like they are stuck, i keep having to turn them off by the plug and turn them back on the next day. I don't think they are receiving the signal from the main control panel. It's never all 3 heaters together, just one or two at a time. This is now happening every day. I have been told a process to reset them but it is not working. Any help would be great!
  • jameslea Jan 05, 2009
    My duo heat also keep clicking and the front radiant element feels like it is constantly on. Which is a bit worrying because i think i'm wasting electricity. Not sure if thermostat is not working inside. Help me
ACTECH
  • 80 Answers
SOURCE: air condition won't work
THE CLICKING SOUND IS A RELAY PULLING IN ITS LIKE A SWITCH CONNECTING TWO WIRES. THIS IS A GOOD SOUND BUT IS USALLY FOLLOWED BY SOMETHING COMING ON FAN ETC... CHECK TO SEE IF YOUR UNIT HAS AN LED LIGHT ON IT AND HOW MANY TIMES IF ANY DOES IT BLINK?
Posted on Jan 14, 2008
hotuna
  • 288 Answers
SOURCE: Vulcan ducted heating not working
How many wires for the thermostat do you have? If you tell me I can help. The green flashing, instead of red, in my experience, means a thermostat problem.
Posted on Mar 05, 2008
chillmaster
  • 104 Answers
SOURCE: Fedders window model A6Y12F2B "New Unit",,only
Take it back to the store. Manufacture defect if it died after only 10 days. Attempting repair or disassembly will probably void warranty.
Posted on Jun 23, 2008
aclamonte
  • 81 Answers
SOURCE: my aristion DIA 20-24 combi
hi,
just check your water supply of your aristion DIA 20-24 combi boiler if is in constant pressure. not properly circulated water supply can cause overheating.
and manuals can help us also in proper checking. at the link below please check this out if you don't have.
http://www.ariston.co.uk/products-select.php?t=0&id=0000000005
Posted on Nov 28, 2008
  • 659 Answers
SOURCE: How to install a new temp sensor Whirlpool electric water heater
The instructions for installing the sensor will probably included with the new part. Also, when you receive the part and actually see it, you will probably know where it will go. Sometimes, things like this happen even with new units. I have had bad thermocouples on brand new units right from the factory. It happens and unfortunately it happens to us sometimes. Good luck and if you get the part and still have trouble, contact them again. If you would have bought a GE (Rheem) unit, they would have sent a tech out to your house at no cost. I'm not a fan of Whirlpool water heaters.
Posted on Apr 02, 2009
1996 lesabre no start but fuel pump makes noise
replace the radiator cap and keep the reservoir bottle up to the line . Check that the hose from the radiator is in good condition. What you have is the hot coolant escaping to the reservoir and as the engine cools down the coolant is being sucked back to keep the radiator full . but sometimes the suck back is not happening and that points to the cap
Mar 09, 2014 | Buick Cars & Trucks
Radiator rattling Noise
You are going to have to take it apart to see if something is loose in the fan.
Nov 11, 2013 | Dimplex Epx1250 Panel Heater
Dimplex Fx20ve 2kw Timer Wall Mounted Bathroom Downflow Fan Heater Pull Cord is stuck
turn of the powere and take the cover off and clean the pull cord and the use a bit of lubricant to keep it free that should loosen it
Sep 24, 2013 | Dimplex Fx20ve 2kw Timer Wall Mounted...
Fire wont mist ad keeps turning its self off 3rd time lucky at posting this as not a car or truck and it keeps coming up under cars or trucks
You can call Dimplex directly for Tech Support:
Dimplex Technical specialists:
1-888-346-7539
Monday - Friday
8:00 a.m. - 4:30 p.m. EST
Feb 07, 2013 | Dimplex Compact Electric Flame Stove...
I have dimplex duoheat radiators and the electronic control is not working it is stuck and I cannot control the input or output heat
Try to unplug the poligonal motor (laser unit) and turn the machine on.
See if turns on. If so you will need to change the poligonal motor of the laser unit.
Oct 26, 2011 | Office Equipment & Supplies
We have a new OFC2400TIF heater. We have set a program which worked for a day. Now the heater will not work on either manual or auto. The display lights are all on, the screen indicates that the heater is...
The heater may need to reset itself. Turn the Master ON/OFF Switch to OFF and unplug the heater from the wall outlet. Wait 12 - 15 minutes and plug the heater back in. Turn the Master ON/OFF Switch to ON and set the controls as you normally would. Hopefully, that 12 - 15 minute timeout allowed the heater to reset itself. If this continues to occur, contact Dimplex Technical Service at
888-346-7539.
Hope this helps you to further troubleshoot and solve the problem.
Apr 24, 2011 | Dimplex OFC2000 Oil Filled Radiator Heater
Just purchased a dimplex DS5629 electric stove. Plugged it in, but NO HEAT and NO BLOWER. Dimplex is closed for the weekend. NOW WHAT???
Ar e you sure that the receptacle your have it plugged into is working? If it is, you can try this. It usually works. Turn the Master On/Off Switch to OFF. Unplug the unit and leave unplugged to 12 - 15 minutes. Plug the unit back in and turn the Master On/Off Switch to ON. Then, turn each individual function one at a time. If they ail function as they should, the unit has reset itself.
If it doesn't work, then you'll have to wait until Monday to contact Dimplex OR you could contact the retailer you purchased it from and have them replace it immediately. That is, unless you purchased it online. Then, it would be better to wait until Monday and contact Dimplex. Be sure you have your Model Number and Proof of Purchase, when you contact them. In case you don't have it, their Technical Support number is 888-346-7539.
Hope this helps you solve the problem.
Apr 01, 2011 | Dimplex DS5629 Electric Heater
I have a Dimplex electric grill like the BPC one and it won't come on. Plugged in and nothing happens. It was purchased late summer 2010
If you still have your Proof of Purchase, it's still under warranty. Contact Dimplex USA, Customer Service at 800-668-6663. If you don't have your Proof of Purchase contact Dimplex USA, Technical Service at 888-346-7539. But, before making any calls, check the receptacle that the grill is plugged in to, to make sure it's functioning. If it isn't then the circuit breaker for that receptacle has been tripped and needs to be reset. Reset the breaker without anything plugged into the receptacle. Then plug the grill back and turn it on in to see if it tripped the breaker. Often times, the receptacle itself can be at fault and may need to be replaced.
Hope this helps your solve the problem.
Mar 19, 2011 | Dimplex BPC-2007 Electric Grill
How do I unjam paper in HL 2142
You open your printer (use your manual to correctly do this)
check all paper paths to see if any paper is stuck
Next take out the toner and drum and check again for any stray scraps of paper that may have been stuck there.
Also open the paper tray and look inside there to see if anything is stuck there.
If your printer has a single sheet tray check there too
If your printer has a back opening, check there too
I recomend that you also purchase "paper path cleaning sheets" to keep the unit clean and paper jam free (once a week if you print constantly and twice a month if a casual user)
NEVER NEVER NEVER get mad and RIP out stuck paper. Such an action will break internal mechanisms inside your laser printer.
Hope this helps Have a great day
Mar 06, 2010 | Brother HL-2040 Laser Printer
Dimplex air heater
my guess is the power switch is shot.
Oct 31, 2007 | Dimplex DS5598 Mid-Size Heater
Heating & Cooling Logo
528 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
