Question about HP PSC 750 All-In-One InkJet Printer
HP PSC 750...NO COLOR from VISTA & ADOBE CS3
I SUDDENLY CANNOT PRINT COLOR from VISTA & ADOBE CS3 on HP PSC 750. Ithought it was my color cartridge but it turns out the test page prints fine. All settings are correct in photoshop...And set for default on printer.It is not a dirty printer as one person suggest. I figure ts due to MS auto updates.BUT HOW DO I FIX THIS? I have already trashed a few good color cartridges by mistake...I also can not update my CS3 with VISTA!!!
SOURCE: Can't print from Adobe Acrobat
I was unable to print with adobe as well. I changed the document to print as an image under the advanced tab.
Posted on Jan 17, 2008
SOURCE: color cartridge wont print
The color cartridge is defective. Sometimes, when the printer detects a refilled cartridge, it "marks" the cartridge as defective hence the refilled cartridge will not work on any printer.
Posted on Jul 21, 2008
SOURCE: Changing cartridges
I just turned on my hp psc 750 and an error message appeared. Incorrect black cartridge installed
I just used it yesterday, what is wrong???
Posted on Aug 24, 2008
SOURCE: HP 7350 printing goes through the motions but nothing
I had the same problem and couldn't figure it out until I found this on the web - I changed the DEP setting and now I can print just fine. Hope this helps you too!!
Julia
Source:
http://www.tech−archive.net/Archive/WinXP/microsoft.public.windowsxp.print_fax/2006−06/msg00081.html
· From: Shawn D <ShawnD@xxxxxxxxxxxxxxxxxxxxxxxxx>
· Date: Sat, 10 Jun 2006 07:40:01 −0700
I just figured out my issue. It had to do with DEP − Data Execution
Prevention. I had remembered that I was fooling around with this a couple
weeks ago and had changed it to "Turn on DEP for all programs and services
except those I select" in which I had Windows Explorer checked. I just got
done selecting the original which states "Turn on DEP for essential Windows
programs and services only", rebooted, and now I can print again to my hp
7350 printer.
The DEP can be found under control panel−>system−>Advanced Tab−>Performance
Settings−>Data Execution Prevention Tab
Hope this helps.
Posted on Mar 06, 2009
  • 19 Answers
SOURCE: hp psc 750 won't print with new color ink cartridge
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hope this help. Please Rate My Response! Thanks!
Posted on Aug 24, 2009
I just hooked up my hp psc 750 printer to my laptop do you have to have a color ink to use this all in one printer
Yes you have to use both the black and color cartridge in order for the printer to work. Both cartridges need a good supply of ink in them to, or it wil not print.
May 24, 2011 | HP PSC 750 All-In-One InkJet Printer
Printer always says "Remove and check color cartridge"
It must be your ruined catridge. Some times the wire connections are burned at the side of the catridge and you must thaw away it and buy a new color catridge.
Oct 28, 2009 | HP PSC 750 All-In-One InkJet Printer
Installed black ink but hp psc 750 keeps saying install colour and i only have black ink. Can you operate this printer without colour in.
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth. Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Aug 19, 2009 | HP PSC 750 All-In-One InkJet Printer
Won't print gives error message above power and function push button incorrect color cartridge installed---was working fine yesterday no cartridge was done...
uninstall and reinstall printer and make sure u follow the promp and put the right cartridge in the right spot....black and color....2 different chambers
Apr 19, 2009 | HP PSC 750 All-In-One InkJet Printer
How can i print in just black with no color cartrage
in your printer you can use single cartridge but there should be both cartridge inserted in the printer.it will not print if only one cartridge inserted.so let the colour cartridge empty but it should be there in the printer.other wise it will not print.at present the problem in your printer is colour cartridge circuit is got faulty so the printer is not detecting the co,lour cartridge in it.so it ask for replacement.in this case you will have to compulsary get the replacement cartridge.you can buy new cartridge or recycles cartridge that will be quite cheaper then new cartridge.
Apr 03, 2009 | HP PSC 750 All-In-One InkJet Printer
We have long had an HP PSC 750. We don't print in color and a tech person at HP told us just to buy black cartridges and take out the old color cartridge & put it back in and set the printing prefs for...
You must replace the color ink cartidge because the inking system uses both cartridges even on just black prints.
Sad, but true. This is how HP makes their money. Selling ink, not printers.
I'm a good ol' US of A boy.
Jan 22, 2009 | HP PSC 750 All-In-One InkJet Printer
Color cartridge wont print
Jul 21, 2008 | HP PSC 750 All-In-One InkJet Printer
HP PSC 750 PROBLEM
Had the same problem. Cleaned the copper-colored "contacts" on the actual printer. Where the printer and the cartridge touch ... you will see them when you take the cartridge out. Hope that helps.
Feb 17, 2008 | HP PSC 750 All-In-One InkJet Printer
Changing cartridges
Nov 06, 2007 | HP PSC 750 All-In-One InkJet Printer
HP PSC 750 All-In-One InkJet Printer Logo
51 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
