Question about Zephyr Milano-G ZMI-M90G Kitchen Hood
Can't figure out how to get bulbs out of hood to replace on Zephyr Milano-G ZMI-M90G Kitchen Hood
  • ScotchieII Dec 13, 2008
    same here - have the Zephyr Milano Kitchen Island hood and I can't get the bulb out for replacement - tried suction cup to get a firm grip but it didn't work - is it possible to remove the plate under (above) the fan screen and then twist the bulb from above?
  • achowanic Jan 19, 2009
    I have the same problem, I pulled one bulb out by using a flat screwdriver for leverage and I ended up pulling the bulb plus the connection points out. It looks like they got soldered together when the bulb burned out. Not sure what to do next. Don't want to do this to the other bulb too. By the way, does anyone know what replacement bulb to buy? I guessed and bought a 20W halogen, but I'm not sure it is going to work.
Just use an adjustable pliers wide enough to grip the outer small edges. Grip, turn counter clock wise and remove. The other way to do this is unscrew the panel behind the filters and you should be able to reach the neck of the bulbs.
Posted on May 07, 2009
How to for bulb removal and replacement on zephyr stove hood
Turn bulb counter clockwise about a third of a turn and then pull down. Sometimes dishwashing gloves make it easier to grab the bulb.
Aug 23, 2010 | Zephyr (AK2100A) Kitchen Hood
I need a replacement bulb Zephyr Pyramid range hood, I cnnaot find it anywhere.
According to the "Use, Care and Installation Guide for your unit,
Replacement bulbs are available at
specialty lighting stores. Purchase type
JDR E27 50W halogen bulbs.
Or to order bulbs, please call our service
center: 888-880-8368 or online parts store:
www.zephyronline.com
Jul 30, 2009 | Zephyr Pyramid ZPY-E30 Kitchen Hood
Removing existing light bulb to replace.Flush mount with nothing to grab on to
Use rubber kitchen glove to grasp bulb. Be careful not to cut yourself if bulb breaks.
Jul 07, 2009 | Zephyr Pyramid ZPY-E30 Kitchen Hood
How do I change light bulbs on a Zephyr Milano hood?
Hi elenara, try applying slight upward pressure as you turn the bulb. Remember righty tighty, lefty loosy. This worked for us, now if I could only find a replacement bulb. Good luck!
Feb 14, 2009 | Zephyr Milano-S ZMI-M90S Kitchen Hood
Light blub burnt out
The easiest way to remove the light bulb is to wear a rubber glove, use your palm to press against the bulb, and turn counter-clockwise.
The suction created by the rubber glove should allow you to remove the light bulb easily.
Jan 12, 2009 | Zephyr Savona ZSA-M90S Kitchen Hood
Zephyr Milano hood fan and lights stop working. Power is on.
Hi ronio,
I'm Harvey the Master Plumber.
Your problem is: After the power went out your Zephyr hood lights and fan don't work at all. There is a faint glow on the digital display but the fan and lights don't respond to pressing the control buttons.
First check the circuit breaker. If OK then check the transformer in the unit. It's next to the fan motor. If no power on the high side then you have a loose or broken connection. If you have no power on the low side the you have a bad transformer. If OK then you have a bad control board.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 22, 2008 | Zephyr Milano-S ZMI-M90S Kitchen Hood
Zephyr ZMI-M90S stopped working
The company doesn't list such a part. Probably, you have a bad connection in the unit. With the power off, remove the motor housing. Find the connection box and fix up the connections.
Nov 20, 2007 | Zephyr Savona ZSA-M90S Kitchen Hood
Zephyr Milano-G ZMI-M90G Kitchen Hood Logo
354 people viewed this question
Top Zephyr Kitchen Ranges Experts
Marvin
Marvin
reliableservice
Are you a Zephyr Kitchen Range Expert? Answer questions, earn points and help others
