Question about Oasis Hunter 54' Ceiling Fan
Remote Control Ceiling Fan Problem
We installed a new ceiling fan with remote. Before we had a ceiling fan / light combo that was controlled on two light switches. One switch for the fan -- and one switch for the light.
Our ceiling wiring has one black - one white - and one copper (all three were connected to the old unit). We wired the white from ceiling to white on the receiver. Then the black from the ceiling to the black from the receiver. Green went to the copper one (ground). Then we wired the receiver to the fan according to the colors and the diagram.
Both switches are on. We can't get any power at all to come on now. We have checked and double checked the connections, etc. Could the problem be in the switch somehow?
My other thought was to wire the white and black wires from the receiver to just the one black from the ceiling (capping off the white from the ceiling) but I don't know if that is safe or not.
    Scholar:
  • 75 Answers
OK, first off, there have been some problems with those remote units. That said, let me tell you what the wires should be doing and you can see if that is happening.
Normally they take a "Hot Wire" and attach it to the white wire that goes to the switch. It is hooked through the switch to the black wire to bring the "Hot" back up to the light/fan. The whites in the ceiling box are the neutral. A "Hot" and a neutral are required to make anything work. The copper is a ground, or added safety. It usually is attached to the same spot as the neutral in the breaker box, so it is not a big deal. If you have a hot going to the switch which works as the off/on valve, and back up to the box. The hot and a neutral make what ever you hook it to work. Now, if you have a remote, it uses a connection at ceiling box to turn it on and off. You can have a switch to turn the whole thing off and on, but if that switch is on, the remote is just a different way to turn it off.
If you have a way for the electricity to make the big circle, it should work, unless a part some where is not letting it through. I imagine in your situation it is the remote.
If this is new, you may want to see if you can get another, and take the remote part out (Up in the fan) and replace it. You would not have to re-assemble the whole fan. I have replaced several of these lately, and even put a different kind of remote on a few.
Posted on Dec 22, 2008
Install a hunter highland remote in a prewired house that has 2 lights on the same main switch
Prewired for ceiling fan (colors, installing, bedroom, lights ...
www.city-data.com > City-Data Forum > General Forums > House
Jan 29, 2009 - 10 posts - ‎3 authors
In my new house, there's 2 switches so I can do them separately. ... is there anything else I can do with that switch since the fan has a remote and I won't be using it much? TIA. .... Those same wires should be in that switch box.
Wiring on ceiling/fan light combo with remote and ... - Bob Vila
www.bobvila.com/.../82070-wiring-on-ceiling-fan-light-combo-with-re...
Oct 3, 2007 - I can have installed the fan/light (a Hampton Bay Veranda) without the ...My house wiring has a green ground and two black and two white wires. ... Fortunately I found a universal/all brand fan speed control wall switch made by Hunter. ... i havethe same problem . so you just did not used your remote?
Jan 19, 2016 | Hunter Dryers
I need to replace my Hampton Bay Ceiling Fan remote control. Part # G9P2BTAUC7052T. Where do I get one?
I need to replace my hampton bay remote control part #G9P2BTAUC7052T for my ceiling fan and light.Where do I get one
Jul 11, 2011 | Universal Remote Control Hampton Bay...
10.27.09 - Ceiling Fan Light Kit not Working.
the remote does control the light. i think it's the bottom button, once to turn it on, again to turn it off. there should have been a blue wire connected in to the wires in the ceiling, this is power for the light. if only the white, black, and copper are connected, the light part won't work but the fan will (usually)
Oct 28, 2009 | Hunter 52" Ceiling Fan With Light And...
My home is pre wired for a ceiling fan in the master bedroom. There are two light switches that control the pre installed wires. One for the light on the fan and one for the fan. There are four wires
The usual wiruing for these fan/light circuits is that the black wire on one switch is for the fan and the red on the other switch is for the light. If you are using a remote set up for both fan and light, then hook the remote wires to the black and white wires in the ceiling, You can cap off the red wire in the ceiling as this will not be used.
Apr 24, 2009 | Hampton Bay 24002 Ceiling Fan
How to wire a remote control ceiling fan, without using remote.
If you don't want the to use the remote you don't have to, but you don't have enough wires to switch the upper light, the lower light, and the fan. You can, however, switch the upper and lower lights together if that's okay. In order to do that you'd connect the white from the ceiling box to the white (neutral) on the fan, then the green from the ceiling box to any green(ground) wires on the fan, then the black from the ceiling box to the black(motor) from the fan, then the red from the ceiling box to the blue and orange (lights) from the fan. I'm assuming that the black and red in the ceiling box are also in the switch box where the fan/light control switch is going. Those are the ones you'll connect to the controller.
Jul 05, 2008 | Hampton Bay 04383 Calibre Ceiling Fan
Ceiling fan and lights with remote control
I got a new reciver installed in ceiling fixture,works fine:Boytin
Mar 15, 2008 | Hunter 52" Ceiling Fan With Light And...
Oasis Hunter 54' Ceiling Fan Logo
273 people viewed this question
Top Oasis Dryers Experts
Are you an Oasis Dryer Expert? Answer questions, earn points and help others
