Question about Husqvarna Viking 1
Feed dog problem and service cost
I've had a Designer I SE for 2 years, it has always worked great. Today I was using a decorative stitch, then the machine made a terrible noise and stopped feeding. I checked the bobbin, the thread, I cleaned out the bobbin casing area, turned off the feed dogs, turn on the feed dogs, turned it off for a while and then back on, but still have the problem. If I put a straight stitch on a 6 length if goes a little. The feed dogs don't move, but up and down a little, not forward or backward, enabling the fabric to move.
I also noticed that the "troubleshooting" part of the manual is kind of ****.
I am hoping someone knows what the problem is and that it won't cost me a trip to the repair guy. I've never had it serviced (probably about time though) but what should I expect it to cost? Or is there anything I should watch out for that might be unnecessary and just a way for the repair guy to screw me out of money. (Yea, I'm kind of paranoid:P)
Anyway, thanks for any help anyone can provide.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 192 Answers
I believe that your machine will need a new link spring
SPRING, LINK
itm412514901
--> 412514901
This spring is in the freearm area and rides on the feed eccentric. Go to a Husqvarna Viking authorized service center. The technician may not be immediately familiar with this problem but when you tell them where the problem is they will be able to fix it quite easily.
I recommend that they do not remove the feed mechanism. Instead, remove the three large screws on the bottom of the machine that hold the frame on the base plate and the screw that holds the link spring in place can be accessed through a hole in the bottom of the freearm that may be hidden by the ribbon cable that goes to the thread cutter. I have changed the part without removing anything else, just put it in place with a tweezer and reinstall the screw. No adjustments are required to the feed mechanism because none of the mounting screws are loosened.
Definetly have the machine serviced while it is in.
First, ask the associate at the service dealer what the price will be for a service for the machine. Then, ask what the additional cost will be for replacing the link spring. I will charge an additional $35 to the service for labor and the spring is about $5 to $10 is I remember correctly.
Don't attempt the repair on your own.
Posted on Dec 04, 2008
How do you make the 1080 machine do straight stitch?
Set the stitch width to zero, the stitch length should be set at #2 or there-abouts. No decorative stitches should be selected. The feed dogs need to be in the up position.
May 02, 2017 | Sewing Machines
The feed dogs on my sewing machine will not raise
if your question is that the fabric didn't feed when I tried a zig-zag stitch , well then this might be a normal thing to happen on your machine , some machines when set to MAX size zig-zag stitch retract the "feed dogs" as you call them so that the operator can hand move the fabric around under presser foot , this is task called "darn" and its usually for filling large holes in fabric (socks!!) and for adding embroidery too (special needle)
Oct 05, 2016 | Sewing Machines
I cannot get the green decorative stitches to work. I'm insure if my Bernina 930 is broken or I'm just unfamiliar with this machine. How do I set my machine for the embroidery stitches?
There are 2 levers on the top that need to be set. One shows the green stitch selections. That needs to be set to your stitch choice. To its right, there is another lever called the "changeover lever." It needs to be pushed all the toward the back of the machine--that switches it from straight stitch to decorative stitch.
Then on the bottom front on the right is a large knob. Both the outer ring of the knob and the inner knob perform different functions. One drops the feed dogs for darning or raises to activate the feed dogs to pull the fabric through the machine. The other part switches between the red and green stitch selections. When that knob is turned the light should show green or red to coordinate with the stitch selection lever on the top of the machine.
So to make decorative stitches, there are 2 levers that need to be moved plus the red/green activator knob. In addition, you will want to adjust the stitch width dial and the stitch length lever to widen or lengthen the stitch.
If you need a manual for your machine, you can download it free here:
BERNINA Support Machine and Accessories Finders and Software Support...
Apr 07, 2016 | Bernina Sewing Machines
Singer sewing machine
Only a sewing tech can tell you:
If the feed dog height is too low, you have to get it serviced.
It the feed dogs are worn out, you can buy them and put them on yourself, but the repair shop would probably attach a new set while you wait with no labor charge.
Mar 06, 2014 | Singer 2638 Mechanical Sewing Machine
My Viking Designer 1 seems to be falling apart. First the touch screen stopped working. I took the machine into my dealer for general servicing and to investigate this problem. The screen was replaced...
It's a shame, but you are discovering why many of us are returning to the old mechanical machines circa 1965 or earlier. The fact is these newer computerized machines have issues far more often than one would think.
If I were you I would call the support line for your machine. Ask directly if your machine has been recalled. And whether or not your motor (never heard of a feed dog motor) or board(s) are covered under the warranty. Ask them to confirm that via email.
Good luck.
Aug 23, 2012 | Husqvarna Designer I
I've had the machine about a year. I have never dropped the feed dogs before, and today I did. Now they will not return to their normal position, even though I am flipping the switch that is supposed...
try putting some fabric under the foot, lowering the pressure foot and making a couple of stitches, they should come back up as the machine goes through its stitch formation.
Jun 20, 2011 | Juki HLZ 35Z Sewing Machine
I have a designer 1 and when i put the Walking Foot (whatever husquvarna call it) onto the machine it stitches extremely small stitches, how the hell do i get it to stitch at a descent length?????? HELP...
Make sure the u-shaped arm that is on the walking foot is "over" the needle screw i.e. the needle screw should be inside the u shape. The feed dogs need to be up also. Use the SET menu to set the machine for the correct fabric and function.
Is the walking foot new? I had one that I used a lot and it went nutty and had to be replaced. I pulled it apart and could not find anything out of place/worn out/broken but it just did not do the job any more. The new one works great.
Nov 06, 2010 | Husqvarna Designer I
Feed dogs on serger don't advance
I use my BLSE200 all the time and ran into the same problem just last week. After pulling out my hair in frustration, I finally realized it had to do with the stitch length. Something wasn't connecting after I adjusted the stitch length, so when I re-set the stitch length, it popped things back into alignment and the feed dogs started working again. *whew* Hope that helps!
Jan 18, 2009 | Baby Lock Eclipse Serger
Are feed dogs supposed to be up or down w/ embriodery unit?
The embroidery carriage automatically lowers the feed dogs when put in place
Dec 01, 2008 | Brother SE-270D Computerized Sewing...
Sewing from m-memory
Hi Ann,
m-memories are not stitched with the hoop or embroidery unit. They are stitched with the #2 sewing foot and with the feed dogs up just like any of the 9mm decorative stitches on the machine.
Linnette
Nov 07, 2007 | PfaFF Creative 7570
Sewing Machines Logo
212 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
