Question about Air Tools & Compressors
Winterizing an air compressor
I just would like to ask if I should bring indoors, my Dewalt 15 gal. vertical oilless air compressor for the winter. I have a outdoor unheated shed I was thinking of leaving it out in, here in Canada. I was going to leave the drain plug open and cover it with a tarp. Not having the most room in the house...but I feel a little uneasy about it and with it being recently new......well....I would like to do the right thing here!?
  • jbell3 Dec 11, 2008
    Thank you.
Keeping it in the house is OK, However I store mine out side, A GOOD spray of WD40 on the switches and leave the drain plug open. I also spray WD 40 on the drain plug and inside the tank. It doesn't take much WD 40 on th4 inside if the tank and swish it around,.
Posted on Dec 03, 2008
I have a 25 gal. craftsman oilless air compressor. Runs for about 1/2 a minute & than kicks the breaker out.
Hello babeaton, several things can cause that, but, the most common thing is the regulator. let it run again and right ofter it kicks off feel the power cord and see if it's warm to the touch, if so it likely is the regulator. Breakers operate based on the amount of heat generated from current running through the cord/wires.
Good luck my friend!
Jan 16, 2011 | Craftsman 25 gal Air Compressor 3 12 hp...
Hi, I have a 15 gal dewalt air compressor model
This model compessor has developed many problems all related to the unusually high cutoff pressure of 200psi. Most all single stage compressors cutoff at about 125- 140psi to keep amp draw to a minimum. Reduce the cutoff pressure as low as possible for job to extend the life of you unit. Locate pressure switch and remove cover to expose adjustment nut. There are generally two adjustments. One for pressure cutout and the other for differential. Sometimes instructions are under cover to switch. Good luck.
Aug 16, 2010 | Dewalt Air Tools & Compressors
Motor runs pressure stays around 25psi
if they are oilless compressors then the rings are worn
Jan 15, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Sounds like a loud leaf blower, no engine sound.
You can get a rebuild kit from DeWalt for about $40 and fix it yourself. The flappers are most likely bent.
Jul 21, 2009 | Dewalt d55151 factory reconditioned emglo...
Air Compressor
Dewalt recommends synthetic oil in their compressors. The dewlat part # 5130427-00 quart, and 5130702-00 for a 4oz size. Available at www.dewalt.com or their service center. I have been using the Lowes brand of synthetic compressor oil. Kobalt oil sells for about $7 and works great. If you do not use your compressor all day like I do, you can use the standard grade of Kobalt compressor oil that sells for around $3. Synthetic oil is for extreme conditions. Good Luck!
Apr 01, 2009 | Dewalt 2 Hp 4 GAL Air Compressor
Dewalt compressor electric not starting after blowing circuit breaker
look for a reset button on the compressor sometimes but not always is red in color but could be black also
Mar 22, 2009 | Dewalt 2 Hp 4 GAL Air Compressor
Regulator will not turn
I AGREE WITH EDITOR 925. ALSO MAKE SURE YOUR NOT TRYING TO EXCEED THE PSI OF THE REGULATOR OR COMPRESSOR. TYPICALLY YOU PULL THE CAP UP A TINY BIT AND TURN IT. IT MAY BE MAXED OUT ALSO.
Mar 09, 2009 | Dewalt 2 Hp 4 GAL Air Compressor
Craftsman 5 hp 30 Gal Won't build to more than 50/60 PSi
Most oilless compressors suffer from a short lifespan of the cylinder and piston ring. Unplug the unit and remove the cover to expose the cylinder and rod. Move piston to topmost position and examine the condition of the cylinder. If you see scratches or worn areas close to the top of the cyl. then most likely will need rebuild kit. (Not expensive) If cylinder looks good, remove the head and check the reed valves for debris or broken reed. Reed valve plate is also available as part with gaskets. To extend the life of an oilless compressor try not to use it in dusty or sandy areas as the bottom of the unit is open and tends to **** dirt into cylinder. Good Luck.
Dec 31, 2008 | Craftsman Air Tools & Compressors
Air Tools & Compressors Logo
59 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
