Question about Philips Televison & Video
My DVD kitchen radio with LCD-TV has poor picture quality at times. You have to turn the TV screen around to find an acceptable picture. Its a great set but the problem with picture quality is disappointing. Thanks, Brian
  • 217 Answers
Its due to faulty electic components on the main board and the board needs to be checked.
Posted on Nov 30, 2008
  • Philips Master
  • 19,396 Answers
Check that there is no Microwave or any large appliance that is disturbing the signal, change TV position and if this is not eenough, get a amplified antenna.
  • Ginko
    Ginko Nov 30, 2008
    Large appliances, like fridges and freezers, ovens etc. can cause disturbance to your TV, particularlyy if the aerial, or the antenna cable is passing near to a compressor or to a big AC power supply.
    Microwave ovens can disturb the signal even from distance.
    Try to find a good position inside your kitchen for this nice TV set.
    If you are using an internal aerial, buy an amplified tv aerial, they start at about $15.
Can radio frequencies cause tv reception problems? Our kitchen 15 tv has very good picture quality and sporactically and sometimes for long durations it has jumpy lines & poor picture quality.
yes if there is a cb with a power booster on it, it can cause problems check ground fault for house.. If you know the person with radio have him check his ground this can blow the TV up.
Dec 31, 2017 | Televison & Video
Aerial connection bad!
Oct 04, 2014 | LG 42LG50 42 in. LCD HDTV
Apex Digital LD4088 LCD TV has horrible quality on cable but fine quality with dvd or ps3
try if you are not, routing signal for comcast via the rear AV jacks--if poor reception that way not the set but the incoming signal.
Most people who are paying for cable or whatever do not complain hard enough--just accept lousy signal and pay for it.
If its poor complain and keep complaining----in most cases there are alternate signal providers eager to jump in.
May 28, 2012 | Apex Digital LD4088 LCD TV
I just bought a sony kdl40ex400, 40" lcd tv and when i first turned it on the picture quality was poor and there are 2 vertical blue bars running down the screen at all times how do i fix this
The tv Tuner signal board is bad,must be replaced.This tv is new,bought it,under a year old?So this tv is still under warrenty.Call Sony for a warrenty repair.
Oct 16, 2010 | Sony KDL40EX400 40 in. HD-Ready TV
7'' Trutech lcd tv and dvd not working
Pls. check your antenna line if it is still connected. Blue screen happens only if your
tv is not getting any signal from your indoor or
outdoor antenna.
Sep 21, 2009 | Televison & Video
Poor picture quality on cable input
Try swapping some cables around, like the skart lead from the dvd(if scart) for the cable one, if the picture problem swaps with the lead then thats the problem. If it doesn't try settings on the cable and tv, if the cable is sending nvbs signals and the tv is set to pal then this can also occur.
Jun 30, 2009 | Dell W2306C 23 in. HD-Ready LCD Television
Pixelated lcd tv picture
it indicates that the problem is aspect ratio or pixel settings for thescreen
bring up the on screen menu and adjust the pixel setting to fit the screen or the apsect ratio to fit the screen
read the operators manual to see how the adjustments are made
May 19, 2017 | Sylvania LC370SL8 37 in. LCD Television
Samsung le40a lcd - picture quality
Hi - I have some suggestions. The following factors effect picture quality:
1. Source (because LCD TVs have much higher picture quality than traditional CRT "Tube" TVs, the worse your source material, the worse it looks on a LCD TV).
DVD and Sky/Digital TV should look excellent on this TV when connected with a good quality Scart lead (nothing too expensive, but a Oxygen Free Copper Gold lead may help) directly into one of the TV's Scart inputs (avoid using "switching" boxes for multiple equipment).
Also, bear in mind that this is a HUGE screen (40 inches I think) and will REALLY show up bad source material.
The best advice I can give is, if you have HD-ready equipment use HDMI connections for everything (ideally with an HD-uplscaling DVD player which will "improve" the quality of standard DVDs on the TV - I recommend models by Philips) and check that you are in "Movie" or "Cinema" mode on the TV.
Make sure that all of your equipment, like your Sky digibox, is set to 16:9 mode (not 4:3) aswell to preserve the true widescreen aspect ratio.
Hope that helps!
Dec 31, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Diagonal lines and ghost images
You may have a bad flyback transformer (high voltage trans former). The lines you're seeing are retrace lines caused by the picture tube screen set too high. This is often caused by the screen control opening up. This control is part of the flyback.
Dec 02, 2007 | Proscan PS32500 32" TV
Televison & Video Logo
16 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
