Question about RCA HD52W58 52" TV
My RCA 52" tv turns off by itself and won't turn back on. The green power light blinks once and then pauses and then blinks 5 times quickly. What is the problem.
  • tdula2005 Dec 02, 2008
    Sam problem, I power the TV on, the picture flickers and then it powers itself off. I called the local TV repair and they told me that soem boards need to be replaced and it could be anywhere form $70-$250. Any one else have a solution?
  • rjones4 Dec 17, 2008
    Will it's Rhonda again. I have been working on my TV now for 1 month. I refuse to give up. I finally got some fuses in last Friday. On Saturday my husband replaced the fuse and soldered the flyback like you said, finally. It was working great he went to put the Tv back together on Sunday and felt a little tug with the wires, so he stopped. Right after that the TV kicked off and won't kick back on now. He has tried resoldering the flyback but nothing is changing. Did he mess something up with the fly back or is there something else I should be looking for... Again I want you to know you have been so much help it's the TV that is not cooperating :-)
Once you remove the back cover from your TV, on the bottom left board there is a gray capacitor next to a vertical heat sink and it says KP 2000vdc this gets loose for lack of soldering after a while , remove the board turn it around and clean the area, apply flux and soldering put back on and your problem is fixed, let me know if this worked for you.
Posted on Dec 28, 2008
    Genius:
  • 1,030 Answers
The rca itc22 chasis. microprocessor has detected a safty condition that requires a shutdown of the set for safety. THere is about 25 different resons that cause this to happen. The one thing you can deduced form this condition is that one the main fuse is working and that the processor is receiving power. THe most like cause of this condition is a high voltage problem. the horizontal output transistor, the flyback. look for blown capacitors there is a capacitor called cp150 that common problem. Technician have special computer equipment that reads error codes much like that of a car.
Posted on Dec 10, 2008
52 Inch RCA TV Model HD52W55 does not turn on green power light blinks 3 times but does not turn on. ive got it to turn on once before, and left it on since, accidently shut it off and cant get it back on,...
The best assumption, at this point, is that the power supply board has died. You can buy a replacement unit from the link below and have it professionally installed.
Power Supply
Aug 28, 2011 | RCA HD52W58 52" TV
TV won't turn on
the first thing that you need to do is to open the back cover of your tv.Go to the power supply section it is separate board where the power cord is connected.Using a multitester,plug in the power cord and measure for the output supply.see if the 5vdc ,12vdc and 24vdc are present..if one of this output is missing,replace the power supply board But if the output voltage are complete,replace the inverter board,It is a board that supplies the high voltage to the backlights of your monitor/screen....You can also try to reset the system of your tv by pressing the the small switch mounted on the main board press it twice while the power is on...tnx and good luck!
please vote for my help!
Jun 04, 2010 | Sharp AQUOS 52" Flat-Panel LCD HDTV
I have a RCA R56wh78 projection power button flashing green.
Thats the classisc sign that the CP150, CP114 and CP120 capacitors need replacement. You can get the repair kit called CP150, CP120 and CP114 at www.tvrepairworld.com which contains the capacitors and the CD with step by step instructions on how to do the repair.
Dec 04, 2009 | RCA HD52W56 52" Rear Projection HDTV
Power problems
You have bad capacitors in the power supply.
Sep 03, 2009 | RCA D52W135D 52 in. TV/DVD Combo
RCA D52W20 52 in. Rear Projection HDTV power light blinking
Liz, yes it is a power supply problem, better question is; low voltage or high voltage power supply ? count the blink code, it should repeat the code, once you have the code call your local tv shops and give them the model number of your tv and the blink amount and they`ll tell you price to fix, gl, video-tek
Jun 05, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W19BYX2 power light blinks once pauses, blinks a 2nd time, pauses, and blinks a 3rd time. Wait about 65 secs and it will do it again. Happens whether I use the remote or the switch on the set. Also,...
try unplugging the tv overnight, then plugging it in when you want to watch it.
i guess there is some safety switch on the processor inside the tv itself that kicks itself on...stupid.
that is the only "band-aid" i have found that works
Apr 10, 2009 | RCA D52W19 52" Rear Projection Television
TV shuts off on its own and wont come back on until unpluged.
On the Deflection board CK 3 capacitors cp150,cp114,cp120 If cp150 is puffed up on top it is bad 2200uf 16v /other 2 caps are 220uf 35v.Also resolder all pinns on FBT
Jan 13, 2009 | RCA D52W23 52" HDTV CRT TV
1995 rca 52 inch tv...
Please post the model number of your RCA as usually its a bad flyback and start up capacitor when you get a 3 blink error code . But I can help you better if I have the model number of your set.
Oct 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
52 inch RCA - green light turns on & off, BUT no picture
CP150 is a capacitor in the power supply circuit....feel top to
see if flat....change if "pooched" or swollen..................T.
Apr 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA TV D52W136D
unplug your set leave unplug for 30 min plug back up any change?...this reset it.. if still not come up may have other issues
Nov 21, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD52W58 52" TV Logo
250 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
