Question about Mitsubishi VS-45607 45" Rear Projection Television
Mitsubishi VS-45607 Picture flickers and dims
I just bought a used Mitsubishi VS-45607 for 400 dollars the picture is fine for about the first 15 mins. then the picture starts to flicker and dim it seems to flicker sometimes to the sounds on the tv is there anything I can do to fix this and is it worth it. Thank you.
  • Anonymous Mar 26, 2014
    Mitsubishi VS 45607 - when turned on, we have a problem in aligning the colours, and the vertical keeps rolling. Where can we find the option to restore it, in the Menu?
    Sergeant:
  • 308 Answers
It could be a bad solder connection that opens up as the set warms up. It could also be caused by a couple of bad capacitors, C2p05 (100uf/16v) Located By Ic2p01 and check C2c52 (10uf/50v) Located near Q2c51. A technican will be able to fix it for about what you paid for it I suppose.
Posted on Jan 28, 2007
Purple static lines and a jumpy picture
Your picture tube is about to go.
If it's still under warranty,take it back.
Hope this helps.
Nov 26, 2013 | Mitsubishi VS-45607 45" Rear Projection...
Is this Tv HD? Molel # VS-45607 Mitsubishi
I am sorry to say that your set is not compatable with HD.
Although you should still get a good picture.
I hope that this helps.
asnowman
Jul 22, 2010 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi
This is a case of bad capacitors in the PIP (picture in picture) module. If you have any electronics repair experience, you should be able to do the repair yourself. Here is some more detailed instructions:
http://forum.eserviceinfo.com/viewtopic.php?p=59404#59404
Jan 15, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-4561 picture curved inward
Its Your Convergence Chips!. And Maybe a few Resisters!. Common Problem with this kind Of Set!.....
Jun 30, 2008 | Mitsubishi VS-45607 45" Rear Projection...
VS-45607
sounds like a defective cappacitor or leaky diode in the deflection circuits. Unless youre comfortable working around the high voltage circuits of a rear projection set, it may be best to call a reputable repair facility that is famillair with mitsubishi products.
Jun 15, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-45607 45" Big Screen
Good Day, Delano1981;
It may cure the problem but I would suspect the 9 Volt source
CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND
IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH
ARE ON THE SIGNAL PCB.
This should resolve your TV"s condition.
Good Luck, big IRISH.
May 27, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Picture has horizontal lines that move to middle of screen........
Just got this fixed. The problem is the 21 (yes, 21) main capacitors. It'll only get worse if they aren't replaced. The whole screen'll start jumping, multi-hour "warm up" times until you get a clear picture, maybe not even then... it isn't pretty. Just nip it in the bud now, and more power to you if you tackle it yourself. A good repair shop ought to be able to do this for under $400 if you can't.
Nov 12, 2007 | Mitsubishi VS-45607 45" Rear Projection...
VS-45607 Mitsubishi rear projection TV
Oh good, two people. I was getting weary of attempting to slightly change my answer for all the other people who didn't use the "has the same problem" feature. Anyway, the problem both of you have is not too far gone yet, but will get worse if you let it. It's the main capacitors. Maybe not all 21, but probably at least half of the 21 main caps are shot. All should be replaced at any rate. Any shop worth it's salt ought to be able to do this for you for under $400 if you can't do this yourself.
Oct 31, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Vs-45607 mitsubishi tv
Try Re-soldering the vertical yoke connections and vertical output IC. This is quite common with this model.
Sep 23, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
182 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
