I have refilled the ink cartridges on my Canon Pixma MP220 printer but how do i reset the printer to show the ink level is replaced as it is still showing low ink-thanks
  • 1 more comment
  • bexywillz Dec 01, 2008
    not sure if i am doing this correctly or not-after the printer is turned off, when i press the resume button do i press the power button at same time?
    thank you-i have tried this and now get the green power light flashing and the display says 'service mode' then the green light stays on and display shows 'service mode idle'-what should i do then?
  • bexywillz Dec 03, 2008
    I have tried unplugging the printer and switching back on again again but i still get the display showing color ink low-is there anything else i can try? i have contacted but they said you cant reset on their printers-is this the case?thanks
  • 541 Answers
Try this
  1. Turn off the printer
  2. Hold the Resume Button (red circle in the triangle), add a printer (click “Power”) an indicator light green.
  3. Hold the Power Button, release the Resume Button.
  4. Not releasing the Power Button, double click “Resume” and release Both Buttons.
  5. Click “Resume” for Four times
  6. Once you click “Power”, to confirm the selected action (reset counter absorber). To disable the printer “Power” button to click again. dont forget to rate thank you
Posted on Nov 30, 2008
  • Lee Reynolds
    Lee Reynolds Dec 01, 2008
    yes at the same
  • Lee Reynolds
    unpulg it then back on and see it has worked
Canon pixma mx350 printer ink level shows exclamation mark about the icon
If you are using an ink refill kit (or buying ink that has been refilled, the ink level will not show accurately) also, if refilling yourself you must clean the pint area of the cartridge with alcohol before installation, and then run the 'clean print head' tools from you Canon menus.
I recommend buying Canon ink, at least for 1 in 4 refills to reset your ink levels.
Nov 20, 2013 | Canon PIXMA MX350 Wireless All-in-One...
Black ink cartridge is full, when printing no black showing
Reset waste ink counter
To reset waste ink counter at printers canon pixma MP150, MP160, MP170, MP180, MP450 and MP460 there any 2 choice, that is :
Start with printer on then run this software
Click Reset Main (main) to reset waste ink counter and then click Reset Platen button (additional)
When you insert a refilled ink cartridge into your Pixma MP500 printer you should get a warning about the refilled cartridge. You should also be prompted, asking if you wish to disable ink level detecting. Agree to do so, and you won't get the warnings again because the ink levels won't be monitored by the printer.
Feb 22, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Dear Adviser The Canon cartridges for my Pixma MP140 printer have run out of ink as indicated both on the printer by the E4 signal and on the computer by a pop up window when trying to print a...
Hello, the printer Canon Pixma MP140 has cartridges with no chips. The printer reads the serial from the cartridge and tells you an estimated ink level. My recomandation is to press the resume/cancel buton for at least 10 seconds, that being the method to cancel the ink counter. After you press the resume/cancel buton you will be able to print, scan and copyas you did before.
The only disadvantage is that your printer will never show the ink level for this set of refilled cartridges, but it will work as well as brand new cartridges.
Nov 12, 2010 | Canon PIXMA MP150 All-In-One InkJet...
My Canon Pixma MP220 is has an error code U051 Chk Ink Blk Col, but i have just refilled my ink cartridges
Using refilled ink cartridges will get this error. You have to reset the waste ink levels by doing the followin
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click “Power” button. green led should be on
  3. hold the Power button, release Resume Button.
  4. Without releasing the Power Button, double click “Resume” button and then release Both Buttons.
  5. Click “Resume” for four times then click “Power” button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
Aug 12, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Error code U163 on cannon pixma mp220 printer
Those cartridges don't refill unless you have a way to reset the internal chip. Check online for refillable cartridges or a chip resetter. For priming you go into printer properties and choose maintenance and head cleaning, or choose cleaning from the front panel.
Feb 15, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Cannon MP220 displays colour ink vol unknown
For the Canon Pixma MP220, I kept getting a message saying "Col Ink Vol Unknown" after refilling and replacing a cartridge. After reading some of the other responses it appears as though Canon cartridges contain internal chips that prevent you from using them after they have been refilled. However, I tried a few things and this is what worked for me.
1. Insert your refilled Canon cartridge like normal, close the lid.
2. The Error message "Col Ink Vol Unknown" should still appear.
3. Use the "Menu" button to scroll to "Maintenance" (press "Menu" 8 times to find it), then press "OK" to conduct a "Nozzle Check" and a coloured test will print out.
4. The Error message will still appear but you will be able to print using colour AND with black and white. For some silly reason the Canon Pixma MP220 won't print using black and white if there is no coloured ink...
Hope this helps!
Feb 03, 2010 | Canon Office Equipment & Supplies
Ca i recharge catridge form cnon pixma MX 330?, i
All catridges are made to show the ink levels only for 1st use, once you refill the cartridge you need to reset the ink level chip, some cartrides level cannot be reset, some can be re-set.
There are solution available for some specific printer ink cartridges on how to re-set the ink level.
You can google and loacte the solution giving cartridge number in the search field of google.
Dec 07, 2009 | Canon PIXMA MX310 All-In-One Printer
I refilled the ink with a refill kit
You can't reset the ink level on all Canon Pixma printers.You need to turn off the function on printer to show the ink level.On your printer this happen with push consistently buttons for black copy (for turn of level on black cartridge) and color copy (for turn of level in color cartridge). The printer
shows empty cartridges but it will printing.
Oct 07, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Hi problem fixed through a previous post that is by holding the reset button for 5 seconds.
Feb 13, 2009 | Office Equipment & Supplies
How to reset ink level warning when refilling?
EASY!!!!: push the cancel button by 6 seconds, this deactivate the ink level sensor.
Dec 15, 2008 | Canon PIXMA MP470 All-in-One Printer
707 people viewed this question
