Question about Fuji FinePix A340 Digital Camera
Lens shutter stuck
The lens shutter on my Finepix A340 seems to be stuck and jammed. I can only move it a little bit, covering the retracted lens and effectively turning off the camera but not covering it. I have no idea why it might be jammed, but I don't want to force the shutter because I'm afraid it might break off. Any suggestions would be helpful.
  • Fuji Master
  • 4,738 Answers
If you're careful this problem is a relatively easy fix for many digital cameras. The design of the lens cover mechanism is usually simple and very similar throughout camera brands. Here's an example fix for a Canon A400 with similar problems:
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Posted on Nov 10, 2007
  • CameraR
    CameraR Nov 25, 2007
    Forgot to mention the above should be done only as a last resort. First try blowing lots of compressed air around the open lens shutter to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Also with the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. A grain of sand in the mechanism is usually the culprit, and you want to try to dislodge it.
FinePix A500:
had this solution, tried everything.
Eventually i slowly applied pressure on the focas len, and the zoom mechinism, when it was switching off, and it make a click. some sand came out, and the camera started working.
the motor is loud though, i then polished and oiled the zoom lens cases. and ran some more compressed air though.
I mean, a loud zoom motor, or a £100 repair bill?
i'd rather doing it my way. hope this helps
Posted on Apr 18, 2008
My camera ( finepix jz100) wont open and screen says turn off and on again when camera is turned on
It looks like the lens is stuck or jammed. Is the lens damaged in some way? Make sure the lens retracts fully when the camera is turned off. If not the lens is probably defective.
Oct 19, 2014 | Fujifilm FinePix JZ100 Digital Camera
Lens gets stuck,and makes a clicking noise when trying to open
Hi
Thanks for using FixYa. With the camera closed and off point it straight up (lens towards the ceiling) and hit the power button while holding down the shutter release. When the camera opened, it immediately tried to focus for the picture it was told to take, and apparently it forced the lens to move.
You can also try blowing compressed air around the lens cover to clean it. Now slide a thin strip of paper between the lens cover shutters and the outer support ring and move it around 360 degrees. This will clear the debris stuck there.
With the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. Repeat these steps several times to resolve the issue.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 04, 2010 | Samsung S1050 Digital Camera
LENS IS JAMMED ON MY Canon A510 PowerShot
pls see these links they will help u
http://www.flickr.com/groups/a510/discuss/72157594369867126/
pls rate me well !
May 10, 2009 | Tokina 3652T for Canon Power-shot A510,...
Shutter won't close all the way
The lens cover of PSA60 opens along with the move of the objective lens. Normally the camera will sound an error beep when the lens does not end to the end position -- the lens cover is also not fully opened. In reverse, the lens will be retracted when the camera is switched off.
The "shutter" (outside lens cover) might have something stuck inside the blades or other mechanical parts that prevents the lens cover fully closed. Try to blow with a clean air (no hot air - because it can damage the electronics or plastics).
Or maybe the blades are probably not flat that may create resistance on the surface. Try to flatten the blades by hands.
Or maybe the mechanical systems need to be calibrated (by Canon service center).
My suggestion, try to exchange/trade-in your PSA60 with the latest model at the Canon center, because I have done it last year (trade-in with PS S5IS).
Aug 08, 2008 | Canon PowerShot A60 Digital Camera
The lens is stuck
my daughter sat on ours while it was on and the lens wouldn't retract. I tried the banging repair suggested for a stuck lens. After quite a few tries, it got the lens to retract when turned off but it wouldn't stay out when on, so i grabbed the lens and gently pulled it all the way out while it was on and it worked! (phew!)
Sep 15, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Fujifilm Finepix A340
Hi, you can't fix the problem yourself.Because i think there is a problem with lens assy. and to fix this problem you have to repair or replace the lens assy. so pls take it to the Fuji shop. good luck........
Jul 24, 2006 | Fuji FinePix A340 Digital Camera
Fuji FinePix A340 Digital Camera Logo
405 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
KJ Soni
Level 1 Expert
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
