Question about Sony KP-46WT510 46" Rear Projection HDTV
I have a sony skp46wt500  it is only 5 years old. i have a green wavy band on top and a red wavy band on the bottom.  everything within these bands are showing double vision.  there is red and green all through the picture and the picture is not clear.
    Problem Solver:
  • 3 Answers
If you have the ORIGINAL remote, you can access the diagnostic computer built into your TV (neat, seems only SONY has it ). Download the manual (google it, it's out there!) and follow the instructions. Universal remotes WILL NOT WORK. Good luck, hope this helps.
Posted on Dec 01, 2008
    Problem Solver:
  • 13 Answers
Well its fairly obvious that the convergence amplifier ICs need replacing... I believe STK392-560 ... if those are not available then the STK392-570s should also work.. Always remember to change the open pico fuses... also seen a coil open up before
Posted on Dec 23, 2008
Disney princess tv suddenly narrowed the visible part of the screen. Now everything is squished into a two in wide band with all the rest of the screen is black.
if that 2 band according to you from top to bottom,it has a defective vertical stage.if this two band appears one on top and one at the bottom,it`s on vertical stage.leaky capacitors,resistance changed or resistor devalued ang ic`s, are too weak to amplify a signal to make the screen complete....
Jan 29, 2014 | Disney 13" TV
I am form mysore karnataka india,l.cd of sony bravia 42"horizontal blue band appears on the bottom of the screen
Check the warranty period is still valid and if it is within the warranty then get it Sony repaired under warranty.
Dec 26, 2012 | Sony KDL-52XBR9 52 in. LCD HDTV
Red band at top of tv
Hi,if its a an LCD RPTV it sounds like a light engine problem.Basically your tv uses 3 LCD chips that create the image .Each chip is like a tiny screen that blend together to get the colors and picture right.They are green,red and blue.When they start to fail you will start to get color discoloration or that red band you are getting.May the Lord Jesus bless you!
Oct 20, 2009 | Sony Televison & Video
Green band
http://www.mitsubishi-tv.com/support.html
click warranties...
Important Warranty Announcement for LCD TV Owners
Jul 26, 2009 | Mitsubishi LT-52244 TV
Frozen screen with 4 band colors
Your phone is stuck in bootloader mode, it seems that you may need to reinstall your phone OS on your phone.
Go to the HTC site and download your phone's OS files/installer:
http://www.htc.com/us/SupportDownload.aspx?p_id=67&cat=2&dl_id=68
Follow the installer's instructions after you've downloaded the needed file.
Jul 19, 2009 | HTC Tilt 8900 Smartphone
Green and purple band of color
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 31, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Band on top of Sony Grand Wega Model KDF-E42A10
Contact Sony Auth Servicecenter....Probable bad Optical Block
Assy. .....Part # A-1606-008-A at cost = 750.00+600.00 core..........................................T.
Dec 09, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Sony Ericsson K800i
have the lcd replaced on the phone
Oct 27, 2007 | Sony Ericsson K800i Cellular Phone
Sony KP-46WT510 46" Rear Projection HDTV Logo
106 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
