Question about Amana Dryers
Amana dryer over heating
Is this possible, why does it happen, how do I fix it
  • 121 Answers
Check the vent disconect it and check it then
Posted on Nov 30, 2008
Amana dryer dle330raw not heating
When a dryer won't heat, the most prevalent issue is the heating coil. Getting to it can be a bit of a problem, but after you do, you can check it's conductivity with a volt meter.. It's likely not passing current through, and thus not heating up - much like what happens when the eye goes out on an electric stove or the heating element in an electric oven.
Jul 26, 2017 | Amana Dryers
My electric amana dryer will not heat
It could be the heating element . You can fix it. follow this link
http://www.partselect.com/Repair/Dryer/Not-Enough-Heat/
Oct 28, 2016 | Amana Dryers
No heat/ heating element needs replacement!! How do u replace!! I looked at a video, but the dryer i saw wasnt like mine!!
Is it possible the dryer vent that runs from the dryer to the outside of the house is clogged with lint. This happens to us. Just thought I would suggest this, in case you weren't sure if it was the heating element or not. Good luck!
Apr 14, 2011 | Amana Dryers
Amana Dryer ALG443RAW little heat. It heated slightly and know there is no heat. It is also very noisy when drum is turning.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Oct 11, 2010 | Amana ALG331RAW Gas Dryer
Amana model 2330aww....runs but does not heat up....just started happening, dried one load then it stopped heating up
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 15, 2010 | Amana NDE2330AY Electric Dryer
Amana dryer does not heat sufficiently
The problem is the dryer coils are failing. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a link that should help http://appliancehelponline.com/gdryertroublevideo.html
Jul 27, 2010 | Amana ALG866SB Gas Dryer
Amana dyer model ale956eaw, won't heat up, all
if all other operations of your dryer are ok possibly your heater element or thermostat are faulty also there may be damaged wiring you will need to look closer and own a multi meter to check properly keep me informed of how you went
Nov 07, 2009 | Amana ALE956EA Dryer
I have a Amana Electric Dryer NED5500TQ. When I
It is possible that you could have a bad breaker in the panel. They will start to trip randomly when they are going bad. If not the dryer is drawing too many amps and the breaker is doing it's job. If the heating element is defective and drawing extra juice that could trip the breaker. Usually replacement breakers are not too expensive if you electrical panel is less then 20 years old and can be purchased at most home improvement stores. I would try replacing the breaker before you try repairing the dryer. If you install a new breaker and the problem continues to happen then you should check the dryer heating element. That component is what draws the most amps and would be the most common one for tripping the breaker.
Sep 25, 2009 | Amana NED5500TQ Electric Dryer
Amana gas dryer mod #NGD5240TQ0 intermitten heat
i went to a local appliance store asked them for assistance. they were more than helpful and sold me the parts i needed. fixed the problem for under $30.00. i also didnt have to pay for their ADVICE !!!
Aug 22, 2009 | Amana Dryers
Dryers Logo
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
