Question about Canon BubbleJet i320 Printer
I have a canon i320. the light flashes green, orange. does not print. I tried resetting the printer but to no avail. What is the next step?
It means that waste ink is full,
do this:
How To: Reset Canon Printer
I have try to find out how to reset many canon printer in my office. I
was try to googling to find the best way and quickly how to reset it.
And in google I was found two way how to do it. With Manual Reset and
with Software reset. I will give some advice how to do that with first
method, yes manual reset.
On this point we will do this with my Office printer, Canon i255, i320, ip1000.
For i255, i320
Waste Ink Counter Reset.
1. Unplug power and USB.
2. Open door and hold power button.
3. Connect power.
4. Close door, then release power button.
or Step This Step
1. Turn off the printer. And disconnect the printer cable.
2. Press and hold the POWER button, turn on the printer.
3. The indicator (L.E.D.) should be green.
4. Press and release the RESUME button , the indicator (L.E.D.) should
be orange.
5. Press and release the RESUME button again, the indicator (L.E.D.)
should be green.
6. Release both buttons.
Canon PIXMA iP1000
Waste Ink Counter Reset Manual for Service mode
be orange.
should be green.
Posted on Jan 03, 2009
I320: Light on printer alternates between green & amber
Hi there.
Step 1: Manual Temporary
4. Press and release the RESUME button , the indicator (L.E.D.) should be orange.
5. Press and release the RESUME button again, the indicator (L.E.D.) should be green.
step 2 : Software for Permanant
1. Reconnect the printer cable.
2.Open General Tools software and select (USB PORT)
3.Choose (SET DESTINATION 1) And it should be reset.
Sofware Download "After service mode Pls use software for permanent reset
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 09, 2010 | Office Equipment & Supplies
The printer flashes orange light five times, and green once
Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
This also applies to the i550, i560, i950, i960
Sep 07, 2009 | Canon BubbleJet i560 InkJet Printer
Will not print. says printer not responding
Canon i320 does not want to print light flashes green and orange alternatively. Please help. I tried the above, but nothing works
Apr 20, 2009 | Canon BubbleJet i320 Printer
6 orange and 1 green flashing light on S400 canon bubblejet
Friend your printer has reached to its printing limit. Its printer has a maximum of printing point it is registered in the printer memory. When it reach to its limit it will stop. To solve this problem you need to use CSS Utility Software so that you can make the printer reset then you can print again. You can download for just type CSSutility software in google or yahoo. then download.
Apr 09, 2009 | Office Equipment & Supplies
Canon i320 printer is busy
Normal 0 Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 03, 2009 | Canon i 320 InkJet Printer
Canon i320 amber light flashing will not print
I believe that 7 amber flashes refer to a cartridge error. Check that the cartridge is seated correctly.
Nov 05, 2008 | Canon i80 InkJet Printer
Canon i550 printer stoipped printing
My cannon printer no longer responds to any commands. I get 4 yellow blinking lights and then 1 green blinker.
Oct 09, 2008 | Canon BubbleJet i550 InkJet Printer
Canon BubbleJet i320 Printer Problem
The Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
What you can do is:
· Resetting the Printer By resetting the printer's power, the print buffer is cleared and certain sensors are reset. If there is invalid data in the buffer, or sensors are stuck in a particular mode; errors may occur. Follow these steps to reset the printer:
  1. Turn the printer off with the Power button (if available).
  2. Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
  3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
  4. Turn the printer back on.
· Ink Absorber Replacement Options
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the <Resume> button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Jul 11, 2008 | Canon BubbleJet i320 Printer
On/off button & restore button blink green & orange; printer doesn't work
the problems are :-
  • cartridges are not recognised or installed
  • there is a paper jam.
May 22, 2008 | Canon BubbleJet i320 Printer
Canon i320
Try unticking ENABLE BIDIRECTIONAL SUPPORT on the Ports Tab under Printer Properties accessed through control panel / Printers and Faxes. Try to print - get error message Enable Bidirectional Support. Reverse back into Ports Tab and re-enable Bidirectional Support and try printing again.
Jan 13, 2008 | Canon BubbleJet i320 Printer
Canon BubbleJet i320 Printer Logo
1,936 people viewed this question
old marine
old marine
