Question about Zenith B25A10Z 25" TV
VHF stations WILL NOT display. UHF stations WILL display. Have tried both the remote and the controls on the TV. What is the solution?
  • Mary Squires Jan 26, 2007
    Thank you for your prompt reply. I wish the answer was something I understood and could solve by myself. I had hoped one of the settings had been changed in error. Perhaps I can find a guy who can help. Maybe my elderly friend, the owner of this unit, will have to buy a new unit.
    Thanks, PERK47
    Scholar:
  • 119 Answers
A no ufh channels would be a setting in the menu, but when your vhf channels go, the problem is typically the tuner itself, or the band switching ic. could be either. you will need a schematic to know what voltage is supposed to be on the pins.
Posted on Jan 24, 2007
SOURCE:
When I set the remote automatically, it picked up all of what used to be the UHF stations but not the VHF stations. Why is that?
Cable companies often do not pay for rebroadcast licenses for free to air VHF. Contact your cable company and ask them... you are paying them every month, make them serve you or change providers.
Sep 02, 2017 | Televison & Video
Okay, here I am again, wanting to know how to add cable channels to my Hitachi C21 F800S TV. It currently only shows one channel, BET. Please help! Thanks!
1 Press menu button to enter the menu screens for the following optional adjustable settings.choose
2-tune
3-AUTO SEARCH (Activate to auto search & preset receivable broadcast stations)
-if it don't work change this
4Press menu button to enter the menu screens for the following optional adjustable settings.choose
5-tune
6-BAND (change the band system for tuning (i.e. VHF-L,VHF-H or UHF).
if VHF-L don't work try VHF-H or UHF and restart all over
good luck
Oct 05, 2014 | Televison & Video
Since the digital switchover, I have lost channels, despite re running the setup and tuning. Any suggestions as to why this is happening?
I have a similar issue. When the digital switch happened here some of the local TV stations changed frequencies from UHF to VHF. I do not have a VHF antenna so I am unable to receive these channels. I do have a great UHF antenna, but it will not receive VHF. The fix is of course is a new UHF/VHF antenna. I am 50 miles away from the TV transmitters.
This may or may not be your problem. I hope this is helpful to you.
Bob
Nov 08, 2009 | JVC LT42P789 42 in. LCD TV
Local ABC and PBS stations do not come in. All others local stat
Check to make sure your DTV antenna is an "all band" antenna with reception in both the UHF and VHF bands. It sounds like you may be in Philadelphia area. In Philadelphia, all the DTV stations are in the UHF band except Ch 6 and Ch12, which are in the VHF band. Some of the DTV antennas are UHF only. You can tell if yours can receive VHF if it has the "rabbit ears" long wip antennas. If so make sure the whips are extended fully and turn the antenna to try to get a good signal.
Visit the 6ABC and WHYY websites for up to the minute information about the issues with reception issues.
Jun 16, 2009 | Insignia Digital-to-Analog Converter for...
I get no stations on my tv
Use an Antenna that Provides Good Reception of All Channels
  • Most existing antennas used by consumers will provide good reception of DTV signals. (Before making any changes, try your existing antenna first to see of it allows you to receive all the stations you normally watch.)
  • For watching DTV signals, you will need an antenna that provides good reception of both VHF signals (channels 2-13) and UHF signals (channels 14-51) to reliably receive all of the digital signals broadcast in your area.
  • Many antennas are designed only for reception of either VHF or UHF signals (but not both). For example, the commonly used “rabbit ears” indoor antenna is only suitable for receiving VHF signals. To receive UHF signals, an indoor antenna should also include a wire loop or other feature for reception in that band.
  • The reception capabilities of TV antennas also vary considerably, so be sure to talk to retail consultants and look at information on the packaging and/or the Internet to make sure that any new antenna you may choose provides good reception of both VHF and UHF channels. In addition, if you use an indoor antenna and receive signals on VHF channels, you may need to use an antenna with amplification.
  • Many antennas currently being sold as “HDTV Antennas,” perform best at receiving UHF signals; some of these models state that they provide reception of signals on channels 7-13 but actually perform less well receiving those channels. If you obtain one of these antennas, be sure it provides good reception of all the VHF channels as well as the UHF channels.
  • To check for the DTV signals that are available at your location, use the DTV Reception Maps available at www.fcc.gov/mb/engineering/maps.
Check Your Connections
  • Check that your digital-to-analog converter box or digital television is connected properly. Make sure your antenna is connected to the antenna input of your digital-to-analog converter box or digital television. If using a digital-to-analog converter box, also ensure that the antenna output of your converter box is connected to the antenna input of your analog TV. Refer to the owner’s manuals of your components if you are unsure of the proper connections.
  • Ensure that your components are plugged in and have their power turned on.
  • If you have a digital-to-analog converter box, tune your analog TV to channel 3. You should see a set-up menu or picture displayed on your TV screen. If you do not see a set-up menu or picture, tune your TV to channel 4. If you still do not see a set-up menu or picture, recheck your connections.
Perform a Channel Scan
  • Digital-to-analog converter boxes and digital televisions have a button, usually on the remote control, that is labeled “set-up” or “menu” or some similar term. Press that button to access the set-up menu. Using the directional arrow buttons on your remote, scroll to the option that allows you to perform a “channel scan.” The channel scan will automatically search for digital broadcast channels that are available in your area. Consult the owner’s manual of your digital-to-analog converter box or digital television for detailed instructions on how to perform a channel scan for your device.
  • Once the channel scan is complete, you will be able to tune to the digital channels received by your antenna. You should perform a channel scan periodically to check whether additional digital channels have become available.
Adjust Your Antenna
  • Small adjustments to your antenna can make a big difference in the number of digital channels you can receive. If you have an indoor antenna, try elevating it and moving it closer to an exterior wall of your home. After adjusting your antenna, perform another channel scan to see if your reception is improved.
  • While adjusting your antenna, it may be helpful to access the “signal strength meter” on your digital-to-analog converter box or digital television to determine whether your adjustments are improving the signals’ strength. The signal strength meter is usually accessed through the menu feature on your remote control. Refer to the owner’s manual of your device for detailed instructions on how to access its signal strength meter. Remember to do another channel scan after you have adjusted your antenna.
  • Television stations broadcasting in digital use both the VHF band (channels 2-13) and UHF band (channels 14-51). Many indoor antennas use “rabbit ears” for the VHF band and a “loop” or “bow-tie” antenna for the UHF band. Make sure you are using an antenna that covers both the VHF and UHF bands and have connected it properly.
If You are Still Having Difficulty:
  • Until June 12, 2009, some stations will be operating at reduced power levels. If you are not receiving certain digital TV stations, this does not necessarily mean there is a problem with your antenna or digital-to-analog converter box or digital television. Check with the TV station to find out whether they are planning changes that will improve reception.
  • When an analog TV signal is weak or receives interference, static, snow, and distortion will often appear on the screen. Digital broadcasting will provide a clear picture; however, if the signal falls below a certain minimum strength, the picture can disappear. This “cliff effect” means that if you watch analog TV stations that have static and distortion, you may have to adjust or upgrade your antenna system.
  • Simple indoor antennas provide minimal performance that may not be suitable for your location. If you are unable to obtain satisfactory DTV reception with your current indoor antenna, you may wish to obtain an indoor antenna that includes features for better reception of UHF signals, as well as VHF, and/or an amplifier to boost the received signal (often referred to as an active indoor antenna).
  • Generally, an outdoor antenna will get better reception than an indoor antenna. However, the performance of outdoor antennas can degrade over time due to exposure to the weather. If you are having problems, check for loose or corroded wiring, broken antenna elements and that the antenna is pointed in the right direction.
  • Try to keep the length of wire between your antenna and digital-to-analog converter box or digital television as short as possible for best reception.
  • “Splitters” that are used to connect a single antenna to multiple digital-to-analog converter boxes or digital televisions reduce the amount of signal available to each device. If you are having problems, check whether reception is improved without the splitter. In some cases an “active” splitter that includes an amplifier can solve the problem.
  • If you are near a station’s broadcast tower, reception of that station, as well as other stations, can be impeded by strong signal “overload.” Consider using an “attenuator” or removing amplifiers to improve your reception.
  • If you decide to replace or upgrade your indoor or outdoor antenna, many types are available from electronics retail stores at a variety of prices. Websites such as www.antennaweb.org provide information on the locations of broadcast towers and the types of outdoor antennas appropriate for the stations you wish to receive. If you need assistance with upgrading your antenna system, check with a local antenna retailer or antenna installer.
Hope it may helps:
Regards:
VOTIT
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
Tv WILL NOT GO PAST CHANNEL 18 AND THE REMOTE IS UNIVERSAL AND WILL NOT PASS THESE STATIONS EITHER.cAN BRING UP MENU BUT CAN'T GET ANY FURTHER THAN THAT. wHAT CAN i DO TO GET PAST THIS?
There's a setting in the TV to be able to switch between VHF and UHF. VHF is limited to channels 18 and below (if I remember correctly). Look for a switch or setting on the TV to change it to UHF. Could be a setting in TV menu or a physical switch on the TV.
Apr 06, 2009 | Televison & Video
TV'S
Salutations tobusy2,
With the pending conversion to digital broadcasting on 2/17/2009; BestBuy™ stores are selling units with digital tuners as well as analog tuners. Standard analog tuners should still receive UHF and VHF stations, that is until the conversion when most of theses stations will stop broadcasting in UHF as well as VHF.
I hope this helps.
Jon
Go Ahead. Use Us.
Jun 18, 2008 | Audio Players & Recorders
Sanyo ds 31350 tv
Hi there!
Assuming that you tried to tune stations onto the UHF bandwidth and received nothing,Commonly the tuner box is probably at fault and needs replacement. The VHF and UHF signals are split inside the tuner so if you receive VHF fine then UHF should as well unless faulty of course. Some circuits require an external IC to do the switching, but more on the older models. Regards and good luck, JUS004
Apr 02, 2008 | Televison & Video
Zenith B25A10Z 25" TV Logo
80 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
