Question about GoVideo VR4940 DVD Player/VCR
DVD unable to play tv recorded items
Have a 4 plus year old GoVideo VR4940, which will not recognize the disc when I place it in the system-whether it is a tv recorded item (DVD-R) or a pre-recorded movie DVD. Had the unit cleaned, but still no luck and have a ton of DVD-R discs recorded, but not finalized and cannot get the screen up to finalize it. What can be done with the unit (or outside the unit) to get them finalized so that they can be viewed on other systems? Hope someone has a good answer. Thanks for your help.
GoVideo Gone
    Problem Solver:
  • 5 Answers
If you can see recording on the flip side..it is either a disc patch fix (software) obtained thru Go Video..or find another go video recorder to finalize it..you might try unplugging the unit for a minute or two..and try it again...
Posted on Jan 16, 2009
Recorded GoVideo DVD-R will NOT play in any other DVD player
most dvd players have a region code and you must know what code yours is in, oryou can't play any dvd's, try and find your dvd code,by the way you can only change the code ,think it is 5 times , then it will stay in that code and cannot be changed.
Oct 10, 2012 | GoVideo VR4940 DVD Player/VCR
How do you use the combo I tried but I did it wrong it says wrong dvd and it is a rewritable one Thamks
The Go Video VR 4940 can only record to DVD -R and DVD -RW discs. It cannot record to +R or +RW discs. It can play back many types of discs, but can only record to the -R and -RW ones.
JFFields
Jan 16, 2009 | GoVideo VR4940 DVD Player/VCR
Go video VR4940 VCR video recording has sound but no picture
You can try cleaning the video tape heads. The vcr has 2 different heads. One for audio which is fixed and a drum head for video with 2 heads on it that rotate. The best way to clean them is to take a lint free cloth ad wrap it tightly around your finger. Put some alcohol on the cloth and place it on the drum. Then rotate the drum as you hold your finger against the drum. DO NOT move your finger up and down as you can brake the head off. The other option is to go buy a head cleaning stick. It's a piece of chamie on a plastic tongue depressor. I've cleaned hundreds of them with my finger though. You can clean the whole tape path with the rag. Good Luck.
Nov 30, 2008 | GoVideo VR4940 DVD Player/VCR
VR4940, I CAN PLAY A DVD FROM MY RECORDER. BUT WHEN I TRY TO BURN A NEW DVD THE RECORDER REJECTS THE BLANK AND SAYS "UNKNOWN DISC. CHECK DISC AGAIN"
Try Diffferent media's.
Like different manufacturer's ( ummm!! Sony , philips TDK or verbatim etc
If U did this then U'r optical device is faulty
Cheers
Rifaa
Nov 19, 2008 | GoVideo Televison & Video
VR4940 Go Video DVD/VCR Recorder
Hey you can try takin the top off and blowin it out ,,thats worked for a few of mine ,, also you can use a air compresser ,,,,hope to help
Oct 05, 2008 | GoVideo VR4940 DVD Player/VCR
Region change to multi on govideo #DV1140
This might help some...no gurantees...... take care...
Kevin
GoVideo D2730
  1. Power up
  2. Wait for "No Disc" to bei displayed
  3. Immediately enter 7, 3, 8, 7, 9 (the last figure is for the region, 9 = multi-region)
GoVideo DV2150
  1. Open the disc tray
  2. Press 0, 5, 2, 0
  3. Press UP, DOWN, LEFT, RIGHT
  4. Press the button for the desired RC (0 = codefree)
  5. Close the disc tray
GoVideo DVP750 / DVP950
  2. Press 0, 1, 0, 6, 0
  3. Press the button for the desired RC (0 = codefree)
  4. Close the disc tray
GoVideo DVP850 / DVP853 / DVP855 / DVP860 / DVP865
  2. Press SETUP
  3. Highlight "Custom"
  4. Press 3, 3, 3, 3
  5. A menu should pop up (Secret)
  6. Select region (0 = region-free)
  7. Press ENTER
  8. Press SETUP
  9. Close the disc tray
GoVideo DVP1100 / DVP1165
  1. Turn on the player (without a disc inserted)
  2. Press PLAY 8x
  3. Press 0, 1, 0, 6, 0
  4. 9 should be displayed
  5. Press 9
GoVideo DVR4200 / DVR4250
  1. Change to dvd mode
  2. Insert a DVD and play it
  3. Press STOP
  4. Press PAUSE
  5. Press 3, 1, 4, 1, 5, 9
  6. Enter the region you want (0 = codefree)
  7. Press PAUSE
GoVideo R6640 / R6750
  1. region-free out of the box
GoVideo R6740
  1. Press SETUP
  2. Highlight "Exit"
  3. Enter 2, 9, 6, 0
  4. Press SETUP
GoVideo VR2945
  1. The disc tray has to be empty
  2. Press SETUP
  3. Go to the "System Info Screen"
  4. Enter 1, 1, 0, 1
  5. Enter the region (0 = multi-region)
  6. Press SETUP
GoVideo VR3840 / VR3845 / VR3930 / VR4940
  1. Press SETUP
  2. Scroll down to the lock symbol
  3. Keep Pressing 0 until it says "Congratulations region free!"
  4. Press RETURN
GoVideo D640, D645, DTH7000, DJ350, DP7240, DP8240, DP8440, DV1030, DV1130, DV1140, DV2130, DV3130, DV3140, DVR4000, DVR4100, DVR4175, DVR4300, DVR4400, DVR4550, DVR5000, DVR5100, GVP5850, GVP7811, R6530, R6540, VR1940, VR2940, VR5940
Jul 18, 2008 | GoVideo D645 DVD Player
GoVideo VR4940 has stopped reading recorded discs
try using a dvd lens cleaner to clean lens and then try.
also use a quality brand dvd-r I suggest memorex Brand dvd-r
to record on.
Jan 08, 2008 | GoVideo Go Video DVD/VCR Combo
Disc Tray Will Not Eject
Just next to the eject button on the actual recorder there should be a tiny pinhole.  If you use a small paperclip and insert it, then push, you should be able to manually eject the DVD.  Hope this helps!
Oct 16, 2007 | GoVideo Go Video DVD/VCR Combo
DVD Player/recorder
yes ,you can try to buy at radioshack a cd cleaner if that does'nt fix the problem you'll need a new optic,let me know
Jun 10, 2007 | GoVideo VR4940 DVD Player/VCR
GoVideo VR4940 DVD Player/VCR Logo
94 people viewed this question
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
