Question about Weather King 12AJA4801AH Air Conditioner
Where can I find weatherking acclaim II filters
I have a weatherking acclaim II furnace and need filters. Where can I get them?
  • 85 Answers
Your best option is to contact your nearest wheather king/Rheem dealer. They may have replacements. The filter store online, they offer any size and cheap too!
Posted on Dec 02, 2008
Ever limit switch i changed in my Weatherking furnace, it breaks the switch, what could cause this?
You need the model number of the furnace to determine what the flashing light is telling you. Many times the part that looks to be at fault is not the true fault in the furnace. A slow running blower could cause the limit switch to trip. The circuit board tells you that the limit tripped, but the real cause is the motor or clogged filter.
Jan 02, 2016 | FACTORY AC PARTS Limit Switch Double Pole...
My weatherking acclaim furnace was working well, but started blowing cold air and would not shut off. I shut it off via fuse box and waited 15 min. and tried it...now it starts blowing cold air right
Usually when there is a problem with a unit in the heating mode it default to the blower running. Could be one of the limit switches need to be reset - or it could be some other issue related to the heating circuit.
You probably need to get someone to check it out.
Oct 04, 2014 | Heating & Cooling
What is the door switch on the weatherking acclaim II Furnace that allows it to go on and off?
When you pull the panel off the blower compartment there is a switch that verifys this panel is place. Its called a door switch although you are putting the blower panel on. Its usually black and has the hot incoming line voltage that runs through this first. Thanks Happy Heating
Dec 11, 2010 | Heating & Cooling
Igniter keeps breaking
Wow, this is a new one on me! Are you using true OEM parts for your source? If not, you may be getting sub standard parts. There are some companies that use generic parts and this isn't a good thing to do sometimes. Weatherking is a Rheem/Ruud product.
Apr 10, 2009 | Weather King 12AJA4801AH Air Conditioner
WeatherKing Acclaim II
  1. The sensor that tells the furnace whether the gas is lit has got build-up on it and is giving the furnace bad information.
  2. The flame sensor is often a single wire or rod that sticks up in the center of the flame.
  3. You can shut off the furnace and the gas and clean the sensor with some sandpaper.
If that still doesn't work, the sensor may need to be replaced.
Please rate this solution.
Jan 16, 2009 | Heating & Cooling
not only the jets but you need to change the spring in the gas valve and cut the pressure WAY back to prolly 3.5"wc
Nov 22, 2008 | Weather King 12AJA4801AH Air Conditioner
Finding the cooling contactor on weatherking acclaim II gas furna
the "y" terminal sends the hot leg of the 24 volts and the "c" terminal sends the common leg to the condenser..
Nov 15, 2008 | Weather King Heating & Cooling
Weather King 12AJA4801AH Air Conditioner Logo
486 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
acrman404a
Level 1 Expert
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
