Question about Maytag PYE2300AY Electric Dryer
How to remove lint tray receiver: maytag dryer model#pye2300ayw
How do i remove the lint tray receiver from a maytag dryer model # PYE2300AYW?
  • jjhombre1 Dec 02, 2008
    how do i open the case for the lint remover
  • lindacmoorin Jan 14, 2009
    Tons of lint down underneath the lint catcher. I need to get in there and remove it but need to know how to remove the part that holds in the lint screen.
Unplug first with a straight blade screwdriver, pry up on the top of the dryer where the front wall of the dryer and the top meet. there are 2 screws 1 on each side inside the dryer where the sides and front meet, remove them and unhook the wires from the door switch. the whole front will now pull out and up, now open the door remove the 2 screws at the bottom of the door opening and the whole lint tray will pull out. sounds like a lot but only takes about 5 minutes.
Posted on Dec 04, 2008
  • 121 Answers
You must remove the front to remove the vent housing
Posted on Nov 30, 2008
Does a kenmoore 80 series have glides
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Dryer-Parts/Model-PYE2300AYW/3048/0151200?pathTaken=&prst=0&shdMod=PYE2300AYW
go here and you can see the parts in your dryer,if the model isn't a maytag pye2300ay then just put your model number in there and it will show you,kenmore doesn't make anything,you go by the model number if it starts with 110. it's a whirlpool,if say 417. it's frigidaire made but the maytag model you sent has rollers and i would say if you have a kenmore 80 series it has rollers,you can buy a kit that comes with the rollers,belt and belt pulley
Nov 14, 2013 | Maytag PYE2300AY Electric Dryer
How do you replace a heating element on model # PYE2300AYW electric dryer
Unplug itthemobilian_181.jpgthemobilian_182.jpgGo ahead and take the front off, clean and inspect the dryer for lint. Check the blower wheel for looseness.themobilian_183.jpgthemobilian_184.jpgthemobilian_185.jpgthemobilian_186.jpguse some zoomoil to lube the rollers and idlerthemobilian_187.jpg
Don't forget to check the glides. MORE GOOD STUFF HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 17, 2010 | Maytag Dryers
I have a maytag pye2300ayw. The heating element gets extremely hot to the point it will start a fire. It takes only 2 minutes or so to get really hot. I can spit on the back of the dryer and it boils up. I...
It is possible that the fan is not blowing the air enough. The lint does accumulate in the fan housing which will cause this problem. You may need to clean it out more, it is possible after you "cleaned" it some of the lint that you couldnt remove balled up and went into the fan area. Otherwise the fan is not working correctly. It is usually the lint buildup though. Hope this helps..WF
Sep 13, 2010 | Maytag Dryers
PYE2300AYW dryer doesn't heat up, but vent system ...
May 20, 2010 | Maytag PYE2300AY Electric Dryer
Maytag dryer model PYE2300AYW dryer runs gets hot stops. when I try to turn it back on it makes a noise and won't start back up. What could be wrong?
It sounds like your motor is bad. you could take the dryer apart and clean off the lint on the motor and see if that helps but it sounds like i said the motor is faulty.
Mar 24, 2010 | Maytag PYE2300AY Electric Dryer
Maytag performa dryer model pye2300ayw, what should the ohms reading be on the thermal fuse?
doesn't matter,it's either good or bad,when you touch the meter to it if it reads 1 and doen't move it's bad if you get any reading it's good,if the dryer is loaded with lint in the duct that the lint filter slides into and the vent line is blocked it will keep popping on you, clean out the dryer,number one cause for popping the thermal fuse
Feb 22, 2010 | Maytag Dryers
Model #PYE2300AYW Dryer. Changed therm fuse. Died in 5 loads. Changed therm fuse/Hi limit. Died in one load. This is a fairly simple machine. Could op thermostat be taking all these out? Tnx
Your lint trap and/or ducting could be blocked. This will cause the machine to overheat and the thermal fuse shuts it off before it burns your house down.
Jan 30, 2010 | Maytag PYE2300AY Electric Dryer
Maytag electric dryer (PYE2300AYW) does not stop on auto cycle.
Either the control board or the humidity sensor is bad.
Jan 11, 2010 | Dryers
Maytag electric dryer is drying inconsistently.
you may need to check the lint trap and clean it .. also try cleaning out the dryer vent... if this doesnt work , try changing the drine belt...
good luck
Oct 12, 2009 | Dryers
Maytag PYE2300AY Electric Dryer Logo
1,260 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
