I want to unlock my shift button on my laptop help me pls
When u say ur shift key is locked i dont know if u mean stuck on upper case or the key is physically stuck. either way u need to carefully remove the casing of the shift cover and clean the press pad below as something has probably got underneath it and so its not rteleasing. good luck
If you are printing all CAPS then it is the Caps Locks key. It is located just above the shift key on the left side of the keyboard. There should also be a light on the laptop indicating the Caps lock is on.
Hope this helps
