I have a blue convergence adjustment problem with Apex gb43hd10 tv.
  • lorrislinda Nov 30, 2008
    the solution by futurelogin didn't work for my blue convergence problem . I think i need a new convergence ic?
  • 19,396 Answers
You need to test the pico fuses on the convergence board, this are two small resistors at the base of the STK ICs on C board.
I think this unit mounts two STK 392-040 , you can replace with two STK 392-150 that blow less frequently. Ask the seller what ICs are supported on your set.
Each convergence IC costs about $8.
You can buy the STKs here:
STK392-110 - $5.99 each
Semiconductor STK392-150
See here on how to replace them.
Posted on Nov 30, 2008
    Sergeant:
  • 217 Answers
Yes u r verry correct .u need a new convergence stk ic. u will get this stk ic at radioshack wesites. and to replace it manually here r the instructions given for this  just click the link http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
thanks. good luck.
  • 734 Answers
There is a manual convergence setting. Press Menu until you see the option of convergence.
Save settings by pressing Power until you see Save Ok. You can exit the convergence screen by pressing the PIP button. 0 reloads the convergence.
It will periodically go out of wack again.
  • futureloginn
    futureloginn Dec 01, 2008
    yes, if the solution given by me not works,, than you needs to replaceconvergence ic.
    Thanks
I need a repair kit for a apex gb43hd10 convergance problem
Check the site www.TvRepairKits.com - they will not have your model listed but they can build a customer convergence kit for many models. You just need to send them a few photos of your boards.
Apr 18, 2013 | Televison & Video
Picture on screen shrunk to about half size and color bands go around the picture - red, yellow, green, blue - almost looks like things are in 3D
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 22, 2010 | Apex Digital GB43HD09 43" Rear Projection...
Apex Mod# GB43HD10 The picture is now blurry or wavy.
Sounds Like your convergence ICs big black ICs will part number on them example STK394-020 Call Mats for Parts on ICs 1-800-628-1118 Also Call Encompass you can order whole Board if you want to you just unplug old board and plug in new 1-800-638-3328
Oct 01, 2009 | Apex Digital GB43HD09 43" Rear Projection...
My Apex GB43HD10 pictures disappears after a while, sound works.
possible solder connection in the powersupply needs to be
resolderd it shouldnt cost much
Sep 15, 2009 | Apex Digital GB5108 51" Rear Projection...
Screen Distorted
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
  • Screen looks 3D
  • TV shuts off after powering on - TV may also make a chirping noise.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
May 18, 2009 | Apex Digital GB5108 51" Rear Projection...
Apex GB43HD10 Convergence
  • Screen looks 3D
Jan 10, 2009 | Apex Digital GB43HD09 43" Rear Projection...
Apex Digital GB43HD10
I was watching My Apex Digital GB43HD10 one night and i smelled smoke the TV went blank i lost all power, i called the repair man and he came and looked at it and replaced the thermosat and it solved the problem.
Oct 20, 2008 | Apex Digital GB4308 43" Rear Projection...
Color
yes those ICs will work in your model. You can get replacement ICs and free instalation instructions at the following link.
http://servicemanuals.vstore.ca/
Sep 06, 2008 | Apex Digital GB43HD09 43" Rear Projection...
Apex model GB43HD10 need instructions for service menu
Decrease vol to 0 on remote. Then press menu on the front panel while holding mute on the remote. An s appears on upper left side of screen. Press pip Ch+ to scan menu, Press CH+ or - to select and press VOL + 0r- to adjust items
Jun 16, 2008 | Televison & Video
Apex gb5108
Your Convergence is off. Go through the menue to the CONVERGENCE and follow the on screen instructions.
Start with the RED gun and align each cross point starting with the upper left corner.
You will be pulling the red to match the green.
If the television shuts down during this process, it will reset the convergence and you can try again.
After you get the red gun perfectly aligned with the green, start with the blue.
follow the on screen directs and don't forget to store.
Use the remote for these adjustments.
I hope that this helps..
Jan 06, 2008 | Apex Digital GB5108 51" Rear Projection...
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Electro Med Services...
