Question about Amana Refrigerators
Have inside filtered water. Changed water filter and have lost water pressure. It now trickles out slowly. Changed filter (thought it could be bad) and have the same result.
  • 121 Answers
The water filter head may be bad check the water befor and after it
Posted on Nov 30, 2008
Doed the filter have to be in place for water to be dispensed? Would replacing the filter be the first step in trying to diagnose why water will not come out anymore?
When you push the lever listen carefully for a click or buzz. If you hear this then the water valve is kicking on. If you don't then it may be a bad switch in the water lever area or a bad water valve. If you do hear that sound it could very well be a blocked filter. Usually a filter will slowly cut the water flow down to a trickle. Try taking the filter out and shake the water out of it and reinstall it. Sometimes this will allow some water to flow through it and this will let you know if you need a new filter.
Oct 01, 2015 | Refrigerators
Water does not flow
Sounds like air in the line.....the filter may be cracked/damaged, or not quite seated...?
since you've tried 2 new ones....I'm gonna bet they are not quite the correct ones for your fridge.
Sep 07, 2012 | GE GSHF5KGXBB (254 cu ft) Side by Side...
2006 Pacifica 3.5L I have a small coolant leak on the passenger side. The coolant will trickle down and drip from oil pan. The puddle is only 2 inches wide. I did a pressure test at 17PSI and I lost 2PSI...
It is a possibility that the leak may come from bad seals from the water pump or a bad water pump. If you also observe bubble in the coolant inside the radiator when the car is running or water coming out of the exhaust you may have a bad head gasket. The coolant comes out of the bad part of the head gasket near the outside which lets water outside the engine as well.
Aug 03, 2011 | 2004 Chrysler Pacifica
GE smartwater filter (model GXRLQR) stopped working...help!
These replacement filters (GXRLQR) are FLAWED straight out of the factory. The problem is in the 2 little "teeth" nubs that stick up near the center circle of the filter. When the filter is twisted and inserted, these teeth push up on a tiny black spring loaded valve in the body of the filter, alowing water to pass through up and out the spigot. The flaw is that the "nubs" are too short and do not push open the spring valve far enough, reducing flow to a semi-trickle, even with a brand new filter. GE seems to think this is not a problem.
Solution=stick a $0.25 garden hose rubber washer in the top of the filter and screw it in. You may have to try a few times to get it to work and seat properly. When it works, you'll immediately get a nice super flow of water. Better than upgrading to a $200 filter system recommended by GE...
May 06, 2010 | General Electric GE SmartWater Household...
I have a Jenn Air, french door style, bottom freezer. with the water dispenser on the inside left jamb of the box. there is also a ice maker. for the first 9 months every thing worked very well. then...
You have another plugged filter. That is why you ice cubes are hollow, the water is flowing so slowly into the ice maker, it does not fill up.
Recommend you install an external filter somewhere in the feeder line that connects to the rear of the refrigerator. The are surprisingly inexpensive, compared to the filter inside the new 'fridges. I recommend you buy a replacement external filter cartridge at the same time you buy the external filter kit. Of course you will need to change the internal filter one more time or bypass it per any instructions provided with your fridge.
Aug 11, 2009 | Refrigerators
Low water pressure on door dispenser
i have a similar problem. my water dispenser worked perfectly with the origional filter for about 8 month . then there was a decrease in water output. i then changed the filter.this worked fine for about 2 weeks . changed the filter again 2 days of water output. i have since changed the filter 2 more time with the same results. i do not have a kinked line . i have had the refer for about 1 1/2 years. ice production is down also . any thoughts?
Jul 01, 2009 | LG LFX25960ST Stainless Steel French Door...
Water trickles slowly into the machine.
Turn off the water.
Switch on the machine and let it try to start filling, that will take the mains pressure off the hose, switch off the machine
Take off the hose at the washer end and check to see how much dirt there is in the small filter inside the inlet solenoid
Most of them pull out for cleaning , be gentle they are nearly all made of plastc and can crack
May 27, 2009 | Roper RAS6233KQ Top Load Washer
Water dispenser is just a trickle
the biggest culprit for slow water dispensing aside from the filter is the water supply its self. check to make sure the water line isnt kinked behind the refrig, if thats ok then disconnect the water line from the refrig and run water into a bucket and observe your water flow. good water pressure would basicly fill a 2 gallon bucket in less than a minute. much less than that can cause problems. hope that helps peyton
Jan 29, 2009 | KitchenAid KSRA25CNSS Side by Side...
Monogram water flow problem
common low flow is a kinked line or a bad water valve, the solioid valve has a filter that may be dirty. then go from there
Jun 11, 2008 | GE Monogram ZISS480DRSS Stainless Steel
Refrigerators Logo
142 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
