Question about Yamaha HTR-5440 Receiver
No sound coming from reciever from tv
I just moved and cant find instruction manuel for reciever. trying to hook up audio wires from tv to reciever to get surrond sound from tv. i am not getting any sound at all. i have noticed reciever when i turn it to tv mode is showing tv is in d mode. i dont know how to change it so it works.
Make sure connections are going-audio out from tv to d-tv/cbl in on back of reciever. Then turn on tv and turn reciever input to d-tv/cbl and make sure the input mode is on auto. Hope this helps you.
Posted on Jul 04, 2007
  • Quentin Reimer Jul 05, 2007
    You can go to Yamaha.com and get the manual.
I am trying to hook up my Pioneer vsx-455 to a LG LED LCD TV. I am not sure on how to do this and I can not find a manual anywhere. Can you help me?
your reciever does not have hdmi, so the audio is not going to be true DD+ or DTS for broadcast tv.
if your dvd/blue ray player has digital optical spdif, this can be used to transfer the encoded DD+/DTS digital audio.
the besat way to run your tv audio through the reciever is to hook up the dvd/blue ray player up with (perferrably) digital optical spdif, composite spdif or (least favorably) through the stereo stereo analog inputs on the reciever for "dvd" audio in and hook the video from the dvd/blue ray up to the corresponding "dvd" video component input on the reciever.
this way is only going to get your dvd/blue ray sound, next you need to hook up your cable box to the reciever so that you can get broadcast tv sound. hook up the cable box audio to the "tv" stereo analog audio ins, and hook the video to the corresponding "tv" video component inputs.
the component video inputs have separate jacks for red, green and blue ( labeled "Y" "Pb" and "Pr") and are capable of carrying a 1080p full hd signal. use the component video outputs on the reciever to output the video signal to a component video input on the tv, using the receiver's input selector to change the video source.
Nov 25, 2010 | Pioneer VSX-455 Receiver
Audio Issue
You may have tried this, but when you hook up audio out from TV to audio in on reciever, did you try the different input options for the reciever. Often times, audio in is an aux1 or aux2 setting on the receiver. If it is working with the DVD player, it is functional, you just have to get the wires hooked up and get the reciever on the correct setting. Also, even if you have TV audio out correctly configured to audio in AND on the correct input setting, the TV volume will have to be UP as well as the receiver volume. NOT ALL THE WAY UP (you'll blow your speakers), but up about 25% for you to hear it.
Jul 29, 2009 | Audio Players & Recorders
Don't have manuel and don't know how to Set up Hitachi VCR
Such a simple job. First check if the cables are connecred properly
1. Audio OUT from VCR to AUDIO IN of TV.
2. Video OUT from VCR to VIDEO IN of TV
Then switch the TV ON. Select 'Video' on the TV/Video
selection button on the TV's remote control.
Your TV screen will show a display like 'Video' or 'AV'
Play a cassette and you should be able to see the picture...
Happy Viewing.
Apr 01, 2009 | Televison & Video
No sound when the tv is on and the mute is turned off
I still am unclear as to your hook up but lets try this, if you have your DVD/VCR plugged into the TV audio and video and a audio cord from the tv monitor out to an input on the reciever, this way you should hear the sound at the tv and reciever.
However if you have your DVD/VCR plugged into the reciever first audio and video connections made at the reciever you should just have a video cord fromthe monitor out of the reciever to the tv and your audio will come from the reciever
Feb 25, 2009 | Panasonic PT-52DL10 52" Rear Projection...
I have a vr-405 5.1 channels reciever, I have it hooked to nanlog out on tv per tv manual,tv speaker r off,there is a dvd/vcr hooked into video 1 and it works on tv speaker, where do i hook into the...
try to be a little more clear on what you are trying to do.do you have it connected to hdtv and cable box if so run hdmi cable from cable box to tv and then run optical cable from reciever to cable box you then must turn reciever to cd/dvd to listen to it leave reciever in auto mode go into cable box menu under audio and select dolby digital
Feb 21, 2009 | Kenwood VR-405 Receiver
Hooking up a tv to a surround sound and to a dig cable box
Ok, hook the cable box up to the reciever audio/video, find the monitor out from the reciever and plug it in to the TV input. sound will come from the reciever this way onto your speakers and the Tv will act as a monitor
Feb 02, 2009 | Audio Players & Recorders
Cant see the picther
check cable connections
Mar 03, 2008 | RCA DRC8335
Help with AG-D9320
These recievers are prime for running surround sound through you TV. It all depends on your TV service, Now if you have a cable box from Dish network, this is the easiest in the world, all you need to look for is an output labeled "OPTICAL OUT". It's a small port with probably a small glowing red light coming out of it. You'll need to buy and optical cable and plug it in there, and then run the other end to the optical input of your surround sound reciever, and then assign a video input to that digital audio signal. It's the best audio you can get by far.
Now if you down't have that, it is still very easy. Find you reciever look for a video input and plug an audio cable in(Red and White cable). Plug the other end into your TV's audio output, a red and white output that is probably labeled audio out, plug that in, switch TV to whatever you are viewing, turn on the reciever to whichever input you assigned and there you go.
If your TV doesn't have an audio output, then you need to go to your cable or sattleite box, and find the audio output, the R/W(Red & white), and run that out to your reciever, the sound won't come through the tv unless you run a second audio out from the reciever into you tv's audio input on the same signal your picture is coming from.
I hope that helps.
Jan 07, 2008 | Teac AG-D9320 Receiver
Connecting up
Easy set up, Hook up all the components to the back of the TV normally and then use a stereo cable from the tv to your reciever.
Usually on the tv it says audio out or variable audio out, this will go straight to your reciever on one input allowing all devices on your tv to be hooked through your reciever on one cable and the sound will come from the tv and reciever at the same time or you can turn the audio off on the tv., you can also hook up any optical audio outs from your devices to your reciever as well. This will allow for surround sound to your reciever.
Dec 21, 2007 | Televison & Video
Yamaha HTR-5440 Receiver Logo
398 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
CHP6PH1
Level 1 Expert
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
