Question about Onkyo Audio Players & Recorders
Just bought refirb. Onkyo 805, hooked up front l&r plus sub and getting no sound. I set up am and fm as per manual and connected a cd changer thru the cd in via rca cables. Radio shows a signal but no sound, none from cd either. I did the Auddesy speaker set up and kept getting "no speaker detected" message and saying it failed to set up. Come on guys, I'm dying to hear my new receiver. HELP
  • griffinhomes Nov 30, 2008
    It is a Onkyo TX 805
  • Quang Viet HUYNH
    Quang Viet HUYNH May 11, 2010
    Can you give me exactly the model SR or TX
    Thank
    Scholar:
  • 107 Answers
After few sec when you turn on your receiver did you hear a click noise ? if yes your receiver is OK not in protection mode if no click noise is output protection in that case you must return where did you buy for service and update firmware a lot of update
However you can reset your receiver and debug the DSP section ( digital signal processor ) as follow
To reset
1. Press and hold down VCR/DVR button, then press STANDBY/ON button when the unit is Power on.
2. After " Clear " is displayed, the preset memory and each mode stored in the memory are initialized and will
return to the factory settings, and turn to Standby mode.
Now turn back on and check if it work or not and make sure check input mode such as analog or coaxial or optical input if stil no sound then debug DSP as follow
To set in DSP debug mode
1. Press and hold down DISPLAY button, then press STANDBY/ON button while the unit is powered ON.
The version number of m icroprocessor is displayed only for 3 seconds.
Main:
8 1.05/07903A
2. Press TONE+ button within 3 seconds above, the version number of 1st DSP is displayed.
DSP 1st:
SR8051:07601A
3. Press DISPLAY button while the 1st DSP version is displayed. The status of DSP and DIR will be displayed.
E1A48K0N/0FFPo
FFFFFF0 0 000
To exit
Press STANDBY/ON button.
Then unplug the unit for 30 sec then plug in it should work now if not you need to return it to 1 of the service center Onkyo in your town to repair it
Good luck
Posted on Dec 01, 2008
No sound on anything on the onkyo 626
It will shut down if you have the speaker wires touching, or the wrong polarity of your connected speakers. Check the wiring and connect one speaker at a time. (turn off to connect)
Dec 27, 2013 | Onkyo Audio Players & Recorders
How to hook up my subwoofer
It sounds like you're doing everything right. Did you define the sub to the Onkyo (Subwoofer = Yes, page 22)?
Let's prove the sub works. Set its volume about half-way, cutoff= 170Hz. Temporarily connect an RCA cable from its Line Input to one of the Tape Out connectors on the Onkyo and play some FM through it. If it's alive you'll hear the low end of the music.
Don't buy into the hype that there are different pedigrees of RCA (or speaker) cables that will make an audible difference. Save your money.
May 04, 2010 | Onkyo TX-DS696 Receiver
What fm station do I set my radio on?
i have a ford explorer, 1995 it came with a 10disc cd changer only trouble is we dont know what radion station we need to use for it can you help?
Apr 15, 2010 | Xtreme Sound WMS6100RW 10-Disc CD Changer
PIONEER 300 WATT CAR STEREO AMP WIREING HOW TOO
depending on how many channels the amp is, you may not be able to hook everything up to it.
usually you have a separate amp for subs. 4 channel amp for the speakers in the car, and a mono amp for the subs.
To hook them all up to the same amp you would need an amp with 5 channels. It wouldn't work out right.
If you have a mono amp its only for subs.
If you have a 2 channel you can either hook it up to the rear speakers or bridge them to mono to run the subs.
you need a channel per speaker basically.
Dec 15, 2009 | Pioneer DEH-P2000 CD Player
Not getting sound from my cd changer with FM modulator
make sure you have the 2 audio cords running from the changer into the FM module
Mar 28, 2009 | Sony CDX-540RF 10-Disc CD Changer
Connecting Sirus audio to Onkyo HT-R500
Carl- If you are sending a Line Level Audio signal to your ONKYO RECEVER, from your Sirus RCA cable Output, IE, the CD input, the VCR input, the AUX in, ETC. No Need to have the RECEIVER in the FM mode, you are just needing amplificaton of the sound signal or Sirus signal sound.
Feb 28, 2009 | Onkyo HTR500 Receiver
No sound from new refirbished Onkyo TX 805
The unit may not have been checked for audio output when it was "refurbished".
Oct 22, 2017 | Audio Players & Recorders
Onkyo 805 sub hook up problem
Talked to tech support at Onkyo and there seems to be two (2) places you can hook your sub up to. I placed mine in the wrong slot. So please double check where you placed the sub connection.
Jan 05, 2008 | Audio Players & Recorders
Can't get B Speakers to work
Use the remote and switch it to be in the sub mode (top right corner of remote) It is here (in the sub mode) that you can change volume and inputs.
May 29, 2007 | Onkyo TX-DS555 Receiver
880 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
