Question about Admiral AW22 Top Load Washer
Admiral washer spin cycle spins out of balance
  • tedcarol Jan 05, 2009
    every thing works fine untill spin cycle, then machine wobbles across floor??
  • 833 Answers
This is either a machine fault or, more likely, an easily solvable problem.  First, spin the machine with just water in it.  If it spins smoothly, it is your fault!
Load the machine more lightly.  Heavy water laden items like jeans and towels unbalance the machine.  Try moving them around in the tub and restarting.  Also, if the machine is not sitting firmly on the floor, it will vibrate more.  Make sure that all 4 legs are contacting the floor to make the machine stable.  If the floor is not sturdy, you will need a piece of plywood under the machine to give it a firm base.
Posted on Dec 07, 2008
My admiral washer model atw4475tq0 is having trouble spinning and i also have a admiral dryer atw4475tq0 that is making a thumping sound
washer: check clutch assembly links with instructions here https://www.youtube.com/watch?v=tVc6SZ2DD4U
dryer: check support weels (2) for a flat spot or if theyre hard to turn
Dec 11, 2014 | Admiral Washing Machines
When washer gets to spin cycle it shakes and moves about the laundry room and does not drain
You will have to quit washing your concrete blocks with your red bricks.
When this problems begins you have to readjust the load to balance the spin cycle.Move item around to make the load more pound wise equitable.
Jan 29, 2011 | Admiral Washing Machines
Washer tub bangs when in spin cycle
There is not a repair guide , sounds like a spring may have broke or came loose inside on the frame take the front panel off to check for loose parts.
it may just be an off balanced load as well.
Phil
Apr 15, 2009 | Admiral AAV7000A
Admiral makes rattling noise during spin
Hello, could be a possible bad pump. I would lean the washer back so you can see the belt. take the belt off and spin all of the pulleys. the pump pulley has a s leave that sometimes makes a grinding noise.
Jan 05, 2009 | Admiral AAV7000A
AAV7000AWW washer
sounds like the thrust bearing is worn causing an imbalance on the shaft. check herehttp://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=AAV7000AWW&mfgModelNum=&fkMfgID=1:- for a schematic on this machine and parts as listed.. hope this is of some help
Oct 22, 2008 | Admiral AAV7000A
Admiral AAV8000AWW washer - clothes are wet after spin cycle...
may be a loose belt or a partial blockage somwhere.
Nov 09, 2007 | Admiral AAV7000A
Admiral AW22 Top Load Washer Logo
162 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De GO PATS
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
