Question about Sony Ericsson W800i Cellular Phone
My usb port is not working
When i connectct my phone to the computer, it begins to charge but it is not recorgnised by the computer
  • beggarman Nov 30, 2008
    Having wiped my hd and started again, I've loaded the updated versions of all software from Sony site but my pc still cannot see my W800. What am I not doing?
    Thanks
    Brigadier General:
  • 7,752 Answers
You need to install the drivers for the phone to the pc...go to the sonyericsson.com website
Posted on Dec 01, 2008
My samsung HM160HI external harddrive is not recorgnised by my laptop.I have tried different laptops,PCs and cables with the same results.This harddrive have been working 100% for the past year.
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 23, 2010 | Samsung SpinPoint 160GB SATA150 5400RPM...
W385 not charging off computer
you have to give more detail to your question to get a better diagnosis.
(1) have you charged from this USB port before?
(2) Are you using a laptop?
There are 2 basic types of USB ports. powered and non-powered.
Sometimes you have to go into your computer settings and tell the computer this USB port you want powered.
The reason I asked if you are trying to charge using a laptop is because most laptop USB ports or non-powered because It will drain the battery down too fast.
if this is the case you can look into buying a powered USB hub which you can plug into your non-powered port you should be able to then charge this way.
good luck hope this helps.
Mar 26, 2010 | Motorola Mobility W385 Cellular Phone
Zen V Plus not recognized ANYwhere on the computer...don't have original CD, have downloaded the driver update and media explore software which begins to load and fails because the computer cannot find the...
most computers have lots of USB inputs. my frnt USB cords don't work on my MP3 but I plugged it into my back USB port and it work fine...Just try to use other USB ports
Feb 25, 2010 | Creative Labs ZEN V Plus MP3 Player
The emachine model KAWE0 is with operating system windows xp sp1 doesnot recognise any usb device.
Good day sir, hi, usually its one or two ports that does not recorgnise a usb device, but if all ports does not recognise the usb device, check the CMOS setup. check this out;
  • one or two ports does not recognise the usb device, this is a local fault, try to check the CMOS setup, this could also be the port itself is the faulty one having loose connection.
  • all ports does not recognise the usb device, this is a system fault, check again the CMOS setup if the USB port is enabled, check the USB device itself also. to make sure use another pc to test the usb device.
A computer virus can also cause the usb port to malfunction, run an anti virus software, if possible you can reinstall the XP and test the USB port afterward.
If all else fails, you can buy a USB card and plug it on the expansion slot on your PC.
Nov 04, 2009 | E-Machines eMachines Desktop PC
Cannot connect to computer
FIRST OF ALL, NEVER EVER PLUG IT INTO THE COMPUTER WHILE ITS ON. ALWAYS TURN THE PHONE OFF BEFORE HAND. AS FAR AS YOUR COMPUTER NOT RECOGNIZING THE USB CABLE, IT MAY ACTUALLY BE YOUR COMPUTER. AFTER ALL IF IT WAS THE CABLE, YOUR PHONE WOULDN'T CHARGE SINCE IT IS THE SAME CABLE FOR CHARGING AND USB CONNECTIONS. MY COMPUTER HAS HAD TROUBLE SEVERAL TIMES WHEN PLUGGING IN NEW OR DIFFERENT DEVICES INTO THE PORT. TO CHECK THE USB PORT ON YOUR COMPUTER.... GO TO CONTROL PANEL, THEN DEVICE MANAGER. DOUBLE CLICK UNIVERSAL SERIAL BUS CONTROLLERS. IF ANY OF THEM ARENT WORKING PROPERLY THERE WILL BE A YELLOW TRIANGLE WITH AN EXCLAMTION POINT BESIDE THE UNFUNCTIONING USB. IF IT IS NOT FUNCTIONING YOU WILL HAVE TO UPDATE THE DRIVER. IF YOUR PORTS, DRIVERS ETC DONT SHOW THE YELLOW TRIANGLE, THEY ARE WORKING. TRY PLUGGING THE PHONE INTO A DIFFERENT PORT UNTIL YOU FIND ONE THAT WILL ACCEPT IT. I HAVE A LAPTOP AND MY PHONE ISNT RECOGNIZED IN THE SAME USB PORT (ON THE RIGHT SIDE OF THE COMPUTER) THAT I USE FOR MY PRINTER. I USE A DIFFERENT PORT FOR MY CELL PHONE. IF YOUR COMPUTER IS OLDER , THE USB PORT MAY NOT BE HIGH SPEED. OLDER COMPUTERS HAVE USB PORTS WITH A SPEED OF 1x OR A MIX OF PORTS WITH 1x AND 2.O (2.0 IS HIGHSPEED 1x IS NOT). I HOPE THIS HELPS!!!
Jun 23, 2009 | Dual Electronics CECT P168 Cellular Phone
When I plug in my Zen Micro to the PC to chage all i get is the flashing charge signal but the devices does not recgharge. This is the same USB that i have used successfully on another PC. it also wont...
I use to have that little player and i remember how it could be tricky on different computers.
from http://www.anythingbutipod.com/forum/showthread.php?t=27711
If these don't work please report back:
4. If the Zen is not detected by or charging from the computer when connected, make sure you are using a USB port on the back of the computer (built into the motherboard) instead of one wired to the case (front or side). That way you are using a USB port with the proper power output.
5. If the Zen is not detected by or charging from the computer when connected, make sure the USB port you are using are USB 2.0 and not v1.1. If you computer is a newer computer, this shouldn't be a problem, but if it is an older computer, it may only have USB 1.1 ports which doesn't output enough power as USB 2.0 ports.
6. If the Zen is not detected by or charging from the computer when connected, make sure you have no other USB devices plugged into the computer (front and back ports), but the Zen. That may be worth a try to see if you can get enough current from the USB ports to begin charging it again. Usually the more devices you have plugged into the USB ports, the less current that will be available for charging due to the power being shared with all other devices plugged in.
7. If the Zen is not detected by or charging from the computer when connected, make sure that the drivers are loading for it properly under Device Manager (no conflicts showing). I believe the Zen will not be detected or begin charging unless its drivers are loaded and working properly.
Jul 30, 2008 | Audio Players & Recorders
My k800 will not show up on my computer as a usb mass storage drive
you need to install its software first, then it will be recorgnised by the computer
May 17, 2008 | Cell Phones
Sony ericsson w610i
If you are unable to charge your handset through usb cable., make sure that your battery is not completly drained..there should me some battery left..and you have to check that the USB port of your computer is working or not ..,other case can be the usb cable may be faulty ..so you have tio check all these conditions than only you can do the charging through the usb port of your PC
Sep 23, 2007 | Cell Phones
Sony Ericsson W800i Cellular Phone Logo
52 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
