Question about Lexmark Z600 InkJet Printer
I have a problem with the colorsCartriged
I print the TESTPAGE and the printer just print BLACK.(i have color Cartridge & they are clean) i also did try to see if the printer setup was wrong but itis as is supposed to be. Then i just WRITE a Colorfulmessage in blank paper, and the colors dosent appear on the paper, itis like its printing Clear! and the printer sound is printing but the colors dosent appear. what can i do??? @: CARL
    Sergeant:
  • 390 Answers
Your printer itself is functioning ok, but the colour ink is not coming out. Have you successfully printed with this colour cartridge before or is it new. It could be a dud if it is new. Also, you need to manuallt clean your printhead with solution and cotton buds until no residie left. This should resolve your issue.
Posted on Aug 12, 2007
Printing black vague block on one side of paper on a testpage, but NOT on the testpage generated from within the lasermenu itself. How is this possible?
TheSamsung ML1210is alaser printer, so it shouldnt have been soaked in ink?
In any case, you have broken the contact for thelaserjet cartridge, which is unable to get charged for imaging your stuff that you want to print.
You will need to get a new cartridge. Take out this one and do not use it anymore. You will cause the cartridge waste hopper to overflow and potentially leak toner all over the inside of your printer.
Feb 27, 2014 | Samsung Office Equipment & Supplies
Don't print the black color
Doing reference on your issue. Double check the ink cartridge to make sure that the cartridge is correctly installed. Also be sure that the black ink cartridge used is compatible with the machine.
The next thing to do is a cartridge cleaning as the belief is that the print head is blocked. If you have done a thurough cleaning, the next thing to do is replace the black ink cartridge to be certain the ink cartridge is not faulty.
I have included print head cleaning instructions in case you have not done this cleaning process.
here is some information from the Brother support site:
If one or more of the ink colors are missing from pages printed by your machine (i.e. received faxes, copies and/or documents printed from the PC etc), nozzles in the print head may be clogged, or the ink cartridge in question may not be installed correctly. Verifying that the ink cartridges are installed correctly and/or cleaning the print head may solve the problem.
Cleaning the print head may solve the problem. When cleaning the print head, you are given the option to clean BLACK ONLY, one of the three colors (CYAN, YELLOW, or MAGENTA), or all four colors at once. For this issue we recommend cleaning only the affected color. If more than one color is missing then choose ALL.
When the machine completes cleaning the print head, press Color Start. A Print Quality Check Sheet will print.
Brian
Jan 22, 2011 | Canon MX700 Office All-In-One InkJet...
My deskjet 5550 printer stopped printing in color it only print black ink i have replaced the color cartridge still only prints in blank only; i have tried calibrate printer and clean cartridge options;...
If the Cartridge and printer alignment is successfull and you are still not able to print in color, mostly the Color print is disabled in your pc
Click on START Button
Click on CONTROL PANEL
Open Printers and Faxes folder
Highlight the Printer icon for Deskjet
Right click on the printer icon and choose Printing Preferences
Under Printing preferences, you will find Printing mode - It must be on BLACK or GREY SCALE, Change to COLOR/ ALL
try printing.
Jul 03, 2010 | HP DeskJet 5550 InkJet Printer
Non printing epson c20ux
Sounds like color cartridge ran out. Were u using color to print black?
Try new color cartridge.
Then if you don't need color go in and set to use black cartridge to print black (text).
If you need color on something only takes a minute to turn color back on.
Since printer worked you can go in and select black which uses the black cartridge and if it prints gives validity to a bad/empty color cartridge.
Good luck.
JC
Nov 27, 2008 | Epson Stylus C20UX InkJet Printer
Cartridge light blinks.
Try printing a testpage to see if the problem is w/ the printer, press print + cancel
Nov 11, 2008 | Kodak EASYSHARE 300 Photo Printer
Lexmark X1100 printer will not print black
I came up with a work around for printing black.
I changed the black cartridge with the color cartridge.
Then when I have a letter to print, I change change (or write) the letter text to yellow, red or blue.
Then I can print out a letter.
By printing the text as yellow, red or blue the cartridge will try to print with only 1 color, but will print out black.
If you do not use one of these primary printing colors the out put will be unusable.
I can not of course print out pictures.
Oct 04, 2008 | Office Equipment & Supplies
HP Deskjet F380 won't print
i think the inside printer have dirt or obstacles that blocken the cartridges while printing.
try to clean manually the printer by using powerful air blower,repeatedly.
Sep 14, 2008 | HP DeskJet F380 All-In-One Printer
Printer wont print
Did you tried the testpage via PC or did you use the built-in testpage, starting with the printers buttons ?
Do you use refilled cartridges ?
Sometimes these cartridges need to be "resetted" after refill, what some refillers do forget.
Do you know if the drum is ok ?
What errors are displayed ?
Paperjam warnings can also come from the sensors for the paper.
Sep 09, 2008 | HP LaserJet 2605DTN Color Printer
Wont printer color
was the colour ink printing verywell before you change it? go to your printer properties setting if your printer monochrome setting is on.well remove your ink & use a soft tissue to clean your printer ink cup softly & clean the ink terminals (contacts)too. use a soft tissue on he ink nozzle if the three colour appeare on the tissue .then install back & run a self test if the test prints colour , then you can reinstall your printer & run a testpage.
thanks.
Mar 31, 2008 | Epson Stylus CX4600 All-In-One InkJet...
Replaced empt 3E cartridge. Now it won't print
I had removed and reinstalled the empty 3e cartridge. Sorry for the Confusion. I hadn't put a new 3e cartrige in until today. Them I ran " deep clean" twice. The printer works fine. I still don't understand why the printer wouldn't print color, when I was had set the printer to print in color when my 3e cartridge was empty and all colors including the 6 black showed full.
Mar 31, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Lexmark Z600 InkJet Printer Logo
90 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
