Question about KitchenAid (KSRD22FKST) Side by Side Refrigerator
Amana side by side ice maker will not fill with water
Have 120 volts to ice maker. ( Red,White) Cannot get 120 volts from ice maker down to solonoid fill valve ( Brown, White) Manually applied 120 volts to fill valve solonoid and unit began to fill. Suspect faulty ice maker contacts. What do you think? Ice maker #'s as follows: IM #S 106 626639. Manf date 12-21-96. Refrigerator #'s as follows: Model SXD22S2W Manf # P1303503WW S/N: 9701234890
  • suzyq103 Mar 28, 2009
    my amana side by side ice maker stopped filling with water so I replaced the ice maker. It still does not fill with water. I have water to the outside door area but not the ice maker. Is it possible that one side of the water vaulve would stop working but not the other?
  • Anonymous Mar 16, 2014
    ice maker does not fill
  • KitchenAid Master
  • 5,568 Answers
Old message, I'm sure you have solved your problem by now, but . . .
IF
 Amana/Whirlpool conforms to wiring standards (no guarantees), the main AC wires should be white=neutral, black=hot, red=switched line.  Of course, they already depart with the use of the brown wire.
You should be able to access the 'full' switch at the ice maker itself and as you have found, it will turn on (or off) the fill solenoid.
It would be kind to post back what you found as it might benefit others in the future.
Thanks-
Posted on Jan 09, 2009
Ice maker not making ice and water is not flowing
this could be several items so will go down the list in order... 1st you need to make sure you have a good clean filter or that it has been changed recently... sometimes removed and reinstalled will also help... 2nd do you have 120 volts ac current to the water valve when called for water example" someone pushing the water dispenser handle while you test... if you have 120 volts and no water coming you have a bad water valve... if the dispenser is working but the ice maker is not filling with water they do have dual water valves and one side can actually be bad... before shooting the water valve down though if your getting water to the dispenser but not to ice maker make sure the unit is actually calling for water... on most of these ice makers there is a gear motor on the front part of ice maker there will be a white cover over the front of unit remove it and turn gear motor makes sure it is not broke.. is there frozen water in ice maker if so may be the heater on ice maker is bad... if no water again before shooting down water valve make sure the fill tube coming into ice maker is not froze up...if it is froze up most likely you have a weak water valve and needs to be replaced due to not seating properly.... hope this helps hard to diagnose when not sure what all you have already tested or not...
Jan 01, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
No water to ice maker. I want to check the water solenoid to see if it is getting power. I don't have a diagram. is it a 120 volt solenoid? and when does it get the signal to open and allow water into the...
The water control valve gets its signal from the ice maker itself. Then begins the cycle of about six different functions until the ice ejector forks go to the position you see most (home) Then it tells the water control valve to open for about seven (7.5) seconds. You may test the true voltage from the female connection with a OHM meter set to AC voltage. Just have someone press the dispense water control. You can also check each sides coil windings for resistance or OHM's and they should be the same or very close to the same. Use care in the area of the coils and make sure the wires are not wet. One of the two wires for each side may be active even without pressing dispense or having ice maker call for water. Another thing I noticed is that you have two sets of water control valves. The problem is about as much with the Primary Water Control
Valve Part Numbers=> 12544002 and Secondary Water Control Valve => 12002193
as is the=> D7824706Q Ice Maker Module Whirlpool now owns Amana, Maytag, Jenn-Air and Samsung will not let me post their manuals to the public. I can answer your questions as need so If you need more answers or diagrams or photos Click Here=> Sea Breeze If you have any questions please ask, Thanks, Sea Breeze
Amana DRS2660BW Wiring Diagram
Amana DRS2660BW Ice Maker Parts Breakdown
Dec 14, 2010 | Amana DRS2660B Side by Side Refrigerator
To check ice makers in general you have to first check there is water which is simply filling a glass from the freezer door dispenser. Next you need to check there is not a frozen fill tube where the water is run through the cabinet into the ice maker.(you should be able to blow through it from the back when you disconnect the line) If it has frozen solid with water, this has to be cleaned of the ice(melted with a hair dryer) Frozen fill tube problem usually caused by water valve not completely shutting off-a drip) May work ok with old valve for a while without replacing also.
The next is to test water valve and ice maker by jumping the thermostat inside the icemaker assembly, there are pins under the cover of the ice maker. If you are this far also check for 120 volts at ice maker. This is general, if you have a ice bin in the door, you have a emitter receiver board which needs to be jumped out. It can get complicated, but you are trying to break down the system components to isolate the problem.
Also remember ice makers generally have a thermostat in them to prevent operation if not down in the zero to fifteen degree range. You can get one of those outdoor liquid filled mercury or alcohol stemmed thermometers to test your freezer temperature before you tear apart your fridge..........
Jan 19, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker and water dispenser not working. it makes a funny girgling noise when water is "filling" for ice machine
Wake up one morning and Boom no ice left in the bin. What happened and What can I do to fix it without calling someone? Some ice makers will get a piece of ice in the wrong place and jam the extraction. Get a hair dryer and heat up the ice maker to release the fouled ice cube and that baby will start going. No water in ice mold?Do this easy test: pour some water in the ice maker mold and wait. If it kicks out a batch, but it has no water in it, most likely the water valve is bad. water%20valve%20for%20water%20and%20ice%20through%20the%20door.jpg Watervalve for SxS box Since it is the cheapest part and you can do it yourself replace it. If it turns out you need a new ice maker then you have a new water valve already to go with it. What if the ice maker has ice in it but won't harvest any? One cheap and easy item for the do it yourselfer to replace is the ice mold thermostat. Check for voltage between T and H if you have 120 volts then the bi-metal (inside that ice mold thermostat) is bad. If it's good you will have 0 volts. ice%20mold%20thermostat%28modular%29.jpg Ice mold thermostat Located in the plastic housing and seated against the ice mold is that thermostat. This looks intimidating but is easily fixed by anybody who could change a spark plug. There is no wiring. One more thing to look for: You can put a jumper between L and V and this will activate the watervalve. Have rags ready! If you are a cheapskate and want to be frugal and not buy a new ice maker or a new head(brain) head1.jpg modular crescent ice maker you may want to remove the main gear and clean the copper plate behind it. That plate gets dirty and won't allow for a good contact with the water valve connection and does not power up the valve...Shhh! They will all be doing it! Modular crescent Icemaker test points: With NO power to the icemaker, and ice ejection fingers in the freeze position: Your ohm meter should read 8800 ohms between L and M, and 72 ohms between L and H. With power ON to the ice maker: If meter reads 0 volts between L and N you have no power to the ice maker. If the meter reads 120 volts then you have power to the ice maker. If you have 0 volts between L and H heater is off if you have 120 between L and H the heater should be ON. If you have 0 power between L and M the motor is off. If you have 120 between L and M then the motor should be ON. If you have 0 volts between T and H the thermostat is closed If the meter reads 120 between T and H then the thermostat is OPEN. If the voltage is 0 between N and V the water valve is closed. If the meter reads 120 water should be filling the mold.
Nov 10, 2009 | Frigidaire FRS26R4A Side by Side...
I have an amana refrigerator with and ice maker. The ice maker will not fill with water. I have installed a new ice maker and it still will not fill with water. I have 120 volts going to the ice maker...
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
A strainer before the inlet valve can also get stopped up restricting flow.
Oct 23, 2009 | Jenn-Air JCD2295HES Side by Side...
The voltage to the solenoid only comes on when the ice maker ask for water to refill. Unplug both sides and check the resistance in the 2 coils. They should show very close to the same. The ice maker has a thermostat inside to tell the water valve to come on if defective the voltage most times 120 volts will not get to the coil. Sea Breeze
Jul 15, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Ice maker isn't working...
looked up a part number using your supplied model, its listed as anicemaker assy (220v) complete assy 67006665
Mar 22, 2008 | Amana SXD524VW Side by Side Refrigerator
Water leaking
Tarena, it's been my experience with Amana that tells me you have a failed water inlet valve.
Here's how it works; Water comes from the wall into the fridge to the valve I'm talking about. Now this valve works like this... When you put a cup in the dispenser area to get cold water a switch sends 120 volts to the valve and it opens up allowing water to flow through it. When you remove the cup, power is shut off at the valve... the valve is supposed to close all the way, if it didn't there would be water dripping from the dispenser area, right? (Like a leaky faucet) If the valve is bad, it won't open at all. (Like a blown out light bulb)
The ice maker is similar. When it "harvests" ice and it drops into the ice bin, the IM will send 120 volts to the valve (for 5 seconds or so) to re-fill the ice mold so it can make another batch. Now when the power is removed from the valve, it's supposed to shut off all the way. If it didn't, there would be water dripping into the ice maker fill tube (in the freezer behind the ice maker). drip, drip drip... one after the other.
Let's assume that the ice maker valve didn't close all the way. What would happen then? As these drops of water enter the freezer compartment and are heading down the ice maker fill tube toward the ice maker, they don't make it all the way 'cause they FREEZE in the tube! One drop at a time, week after week. ('course you never notice it, 'cause it's in the freezer) Now... the ice maker is still trying to make ice, so every 45 minutes or so it sends 120 volts to the valve to get more water. But the water fill tube has ice in it because of the water drops that have accumulated there. This goes on over time and eventually the water fill tube becomes completely BLOCKED with ice due to those water drops.
Now what happens? The ice maker is still trying to make ice, but the fill tube is blocked... it can't get water through it. But when the water valve opens up to allow water to the ice maker, where does it go? Since the fill tube is blocked, all that water pressure builds up in the water line (tube) that feeds the ice maker and eventually it blows out! (you can verify this... pull the refrigerator out from the wall, look at the water line going to the ice maker. There's a connector back there for the tube to fit into. This is what's blown out.) Now the tube is just dangling there and not hooked up to the ice maker any longer. Since the ice maker is still running, every time it asks for water it sprays out and onto the wall and floor back there through this dangling tube.
The repair? Replace the valve. It's easy. The part number is 67005154 and it lists for about $21.00. You can find one at any appliance parts retailer. (you'll see where the valve is located... it's where the water line hooks up behind the fridge.) UNPLUG YOUR FRIDGE WHILE YOU WORK ON IT!!!
Just replacing the valve is only half the job. You'll still need to remove the ice build up in the ice maker fill tube. Do this by pulling it straight out the back of the refrigerator and putting it under warm running water. Then re-install it and hook the water tube back up to it.
On some models, you can not remove the fill tube. If you can't get it out the back, you'll have to do it from the freezer compartment behind the ice maker (a little more work, but still do-able). It's easiest by removing the ice maker.... pull the ice bin out and set it aside. Then remove the 3 screws holding the ice maker. You don't have to disconnect the wires, just try to get it out of your way the best you can. Now take a hair dryer and thaw out the fill tube until the ice slides out of there. Then rebuild it.
There ya go! Job time? about an hour. Part cost? about $21.00. Knowing that you fixed it yourself? Priceless.
Oct 14, 2007 | Amana ACD2232HR Side by Side Refrigerator
KitchenAid (KSRD22FKST) Side by Side Refrigerator Logo
1,056 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
