Question about HP Pavilion zd7000 zx5000 zv5000 presario 3000,R3000 Series 120W Laptop AC Adapter-360699-001 CD-ROM Drive
Hp laptop won't turn on at all
Laptop won't turn on at all. When plugged in, the lightening bolt flashes
  • 1 more comment
  • Anonymous Mar 05, 2009
    Same problem here. The fans wont turn on or anything. Woould be nice for a solution :)
  • subor0711 Apr 24, 2009
    I have the same problem. The HP zv 5000 won't turn on. The cord is plugged in and the lightening bolt flashes then turns off, so that is not the problem.
  • Dreammatch May 02, 2009
    I have same problem, when i only got battery in it and i want to turn it on the lighting symbol flashes and stops within 2 seconds.
    The only thing i know what happend is that it was busy loading some program and then it just shutted off and i hear some little tickin insine if i put in AC power.
HeHe.... My grandpa called me because he was having this problem. After searching the internet, I asked him to check the power cord - sure enough the two pieces of the cord had come separated. The computer wasn't plugged in!
Posted on Jan 06, 2009
What is the Icon for Flash and How do I turn on the flash?
Hi, The icon for the flash on a camera is a lightening bolt, you press the button with the lightening bolt and it will give you option to have it on or off.
May 14, 2011 | Cameras
A red lightning arrow keeps flashing on the screen and the camera isn't doin anything,what can the problem be?
Hi.
A red flashing lightening bolt can mean different things on different camera's. The most common are that you are too far away from the object you want to take a picture of. That the flash on the camera needs to be turned off and that the flash itself is charging up and won't allow a picture to be taken.
Try turning the flash off and see if it will let you take a picture.
Regards.
May 01, 2011 | Cameras
How do i turn the flash on
The flash in a camera is represented by a symbol like that of a 'lightening bolt' If you have a cross sign over that symbol, it means that the flash is turned off. Change the setting of the camera to make it only the 'lightening bolt'. Then it would flash when you take a picture.
Apr 02, 2011 | Cameras
Is the lightening bolt supposed to flash orange? The battery will not keep a charge at all, so I have to keep it plugged in all the time. Does the orange flash mean I may be in danger of losing files, etc....
The orange flashing lightening bolt is confirmation the battery does not charge. It is not an indicator of any other hardware failure.
You can remove the battery if you find the flash annoying. The laptop will be lighter without the battery too!
Sep 21, 2009 | Dell Inspiron E1705 Notebook
My comp shut off and wont turn on anymore.. lightening bolt comes
Please remove the battery and ac adapter and then press and hold the power button for 25 - 30 seconds after that connect the battery back and then try to turn on the machine. if not remove the battery and just plug in the adapter and then try to turn on the machine. If still not working then try to swap the ram. or else your system motherboard requires to be replaced.
Jul 15, 2009 | HP Pavilion dv6000z Notebook
Hp pavillion will not turn on, took battery out and put back in still not working. blue light around power cord on and blue lightening bolt flashes
Hi Iceprincess5
The three flashing lights indicate the battery is dead. Since it still wont power up with the cable plugged in I'd say the port has gone. Try wiggling the adapter about in the port to see if it begins to charge. If not then you would need to take it to a laptop repair centre to get a new dc port soldered on or buy a docking station.
May 15, 2009 | HP Pavilion dv2700t 2.5GHz Intel Core 2...
Receiving Charge will not turn on
Take out the battery and only have the ac adaptor hooked up to the laptop and then try to turn it on.
If that doesn't work, then the motherboard is faulty. Probably a short in the motherboard but the whole thing would need to be replaced.
Also make sure your using the correct adaptor as well.
Feb 10, 2009 | HP Compaq Presario V2000 Notebook
Canon Power shot sd 1000
what u have to do is when u are going to take the picture click on the little lightening bolt next to the func. set button. 2 pictures will pop up- one of a lightening bolt and another with a lightening bolt with a slash through it. hit the lightening bolt button again and it will select the slashed lightening bolt picture. this will turn flash off to turn it back on go back to the screen with the 2 bolts the same way but press the button with the flower to the right of the func. set button.
Nov 18, 2007 | Canon Cameras
Hpzd7000 notebook
the a/c jack on the computer is probably loose.
Oct 30, 2007 | HP Pavilion zd7000 zx5000 zv5000 presario...
HP Pavilion zd7000 zx5000 zv5000 presario 3000,R3000 Series 120W Laptop AC Adapter-360699-001 CD-ROM Drive Logo
440 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
