Question about Ariston Technologies CBC96 Wine Cooler Refrigerator With Ice Box
Ariston fridge freezer - drips water
Water from my icebox drips incessantly. The icebox door catch broke and is irrepairable (a bit snapped off the door too). After this the icebox/door froze together and now the icebox just drips. What can I do?
  • 237 Answers
I'm afraid if the door isn't sealing properly and staying cold then the ice will always be melting somewhat and dripping. Is there ANY way to glue/epoxy/fiberglass that part back on or repair the door, etc.? If you can't get repair parts either you may be stuck with a broken cooler. It seems like some shop (boat shop, auto bodyshop, etc.) should be able to repair those items with fiberglass or something. I guess it just depends on the cost to repair verses to buy new again.
Posted on Jan 24, 2007
SOURCE:
Freezer drain is clogged, I guess, water dripping on the floor, ice buildup on bottom of second door, it has an ice machine built in, what do I do? I'm a female.
Good Morning Andi.
the good news is that the fridge is not likely doing this because you're female, and your description of what has happened with power outages sounds like that's very likely the culprit - a fair amount of melted water dripping, then power comes on and freezes water in the drain.
I don't know your specific model, or if you know where the drain is. it's likely down in the bottom of the freezer compartment. If you remove the lower drawer, or unpack the lowest area, the floor will likely slope toward either an overt hole, or to a slit/hole in the back. If there is actual ice frozen on the lowest shelf/shell of the freezer, you'll want to get rid of it.
Easiest and safest route (as in least likelihood of damaging the freezer or hurting anyone)
  1. Turn the fridge off. It won't be off long enough to risk much thawing, but you don't want the cooling coils actively pulling heat from what you do in the next step.
  2. Hot, even scalding water. Especially if there is overt ice at the bottom, pour small dribbles in at the edge. Some will go across the ice and melt a bit of the bulk. Some will trickle down between the ice and the freezer floor. Do this a couple times, then see if you can pry up sections of the ice from the floor. Pull out as much as you can of the bulk ice. You'll likely want to get a couple of towels out since you'll likely get some water on the floor.
  3. Once you've cleared overt ice from the freezer floor, pour some more hot/scalding water onto the plug, or into wherever the floor slopes to. Be patient and don't pour too big a volume. Ideally, after a few modest pours, you'll get water coming out from under the fridge. If the lower panel will pop loose, get in and use a towel to pick up as much of the water as you can. pour a bit more hot water through and verify it pours through to the floor (or possibly a catch pan).
  4. If you get this far, dry the freezer floor as best you can with the towels, replace the drawer or any unpacked foods, close the freezer, and turn the fridge back on. It will probably be back to normal.
    Good Luck!
    D
Nov 23, 2015 | Freezers
Water leaks inside food compartment
Your fan has stopped working. You need to either replace it or see if your defrost timer is working.
Jan 07, 2014 | Frigidaire FRT15B3A Top Freezer...
I keep getting water at the bottom of the fridge, under salad boxes on my Hotpoint fridge
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Jul 03, 2012 | Hotpoint-Ariston HS3022VL Refrigerator
Where is the reset on my refidgerator wont get cold enough kid left it open
May 09, 2012 | Hotpoint-Ariston HSS25GFT Side by Side...
Water is dripping from the bottom of the fridge (slow drip). How do I fix it. I have a Maytag French Door stainless steel fridge (4-year-old) with freezer on the bottom.
There should be a drip tray catching the defrost water... it may be overfull... Try to remove it and empty it. The tray is actually supposed to have a heat evaporator to dry up the water before it overflows. Your may be fuller due to excessive frost also... from hot temperatures outside or opening the fridge too often or for too long... good luck!
Jul 24, 2011 | Freezers
Constant Defrost causing water accumulation problems
Yes! look under you fridge for the consendate drain hose *(usually dangling right over the catch tray) and using a long piece of slightly heavy guage wire snake up the drain hose and see if it's blocked.
If it isn't blocked you might have a crack somewhere in the fridges interior near the fridge/freezer interface. That might be a bit harder to spot since it would most likely be under cover.
Good luck and be careful.
Dec 29, 2009 | Whirlpool Freezers
Water inside refrigerator
Even though it doesn't seem like it's coming from your freezer, morre than likely that's where it's coming from. At the back of the fridge there will be a drip tray that actually catches the water from the thawing freeze. One way to avoid access water is to simply turn down your freezer and fridge. Usually if they are number 0-10, both frigde and freezer should be set on the 5 level.
Aug 31, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
WATER DRIPPING FROM DISPENSER IN DOOR. GE Model TFX20JRBG WH
You are correct. this is actually a faulty inlet valve(dual) assembly. replacing this faulty valve will fix this issue.
Jun 19, 2009 | GE GSH25JFR Side by Side Refrigerator
Water dripping inside refrigerator
the defoost drain is cloged the drain inlet is located in the freezer behind the back wall under the coils. to clear the drain remove the back wall in the freezer and clear the ice underneth the coils then use hot water to clear the drain inlet, I use a garden sprayer to spray hot water.
Dec 24, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Ariston Technologies CBC96 Wine Cooler Refrigerator With Ice Box Logo
221 people viewed this question
Top Ariston Technologies Refrigerators Experts
Sal De
Marvin
Marvin
Are you an Ariston Technologies Refrigerator Expert? Answer questions, earn points and help others
