Cannot connect to internet.ethernet connection does not click into router.cable is not faulty
  • humbletech
    humbletech May 11, 2010
    please tell me more about the problem or the situation of your connection.thanks
  • markus
    markus May 11, 2010
    to you got a router between the pc and the internet?
  • 50 Answers
Can u go to control panel>network connections
and see if u have got any network connections? usually it will be something called LAN or something u have renamed it as.if a network connection cannot be found it means ur having a problem with your network card driver which is in the motherboard CD if the card is on board and a separate cd if the card is pci. or if u have the network connection open up startmenu>run> and type cmd and press enter. in the dos command prompt u can type netsh winsock reset
and reboot the system. that might also fix the issue.
Posted on Dec 01, 2008
  • Ismail Shifau Dec 01, 2008
    remember to press enter after typing netsh winsock reset
Where do I find the IP address for vizio va19l
To help you and let you know the default IP address of Vizio router is (192.168.1.1)
Now to help you connect the internet connection by configuring Vizio router, please follow the step-by-step instructions given below:
- Unplug the power cable from your high-speed Internet modem.
- Connect one end of the Ethernet cable (included) to the number 1 port on your router.
- Connect the other end to the Ethernet port on your computer.
- Connect an Ethernet cable from your high-speed Internet modem into the Internet port on your router.
- Plug the power back into your high-speed Internet modem and wait 30 for seconds and power on your router with the included power adapter. Your router will automatically turn on.
- Wait for 30 seconds for your router to fully connect and open an Internet browser window (such as Internet Explorer, Firefox, or Safari).
- Type http://vizio.home (or 192.168.1.1) in the browser window and press Enter
- The Quick Setup App will automatically start. Click ACCEPT and CONTINUE.
- From here you can: Click Print to print your configuration.
- Click EDIT SETTINGS to make changes to the Network Name, Security Type, Security Key and Network Status.
- Click Manual Settings to make changes to the advanced settings of your router.
- Click EXIT to close the Router Settings App.
GuruAid.com
May 20, 2016 | Vizio Computers & Internet
Http://192.168.0.1/
286520a4-ee13-4d09-80b0-c6808ea917d3_15.pngA modem and router properly plugged in
  1. Plug the modem into an electrical outlet.
  2. Plug one end of a phone cord or cable into the modem, and plug the other end into the wall jack. (DSL users: Do not use a DSL filter on the phone line.)
  3. Plug one end of an Ethernet cable into the modem, and plug the other end into the wide area network (WAN) port on the router.
  4. Plug the router into an electrical outlet.
  5. Plug one end of an Ethernet cable into the local area network (LAN) port on the router, and plug the other end into the networking port on the computer that you want to connect to the Internet. (If you are connecting wirelessly, skip this step.)
  6. Start (or restart) the computer.
  7. Open the Connect to the Internet wizard by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_47.png, clicking Control Panel, clicking Network and Internet, clicking Network and Sharing Center, clicking Set up a connection or network, and then clicking Connect to the Internet.
READ http://www.fixya.com/support/r7900574-general_router_setup
Nov 26, 2011 | Computers & Internet
My linksys w/2phone ports cannot hook up with the ethernet
Most Cable Internet Service Providers (ISPs) use Media Access Control (MAC) Address authentication to establish Internet connection for end-users. MAC address is a unique identifier assigned to the network adapter/s of the computer.
To set up your Linksys router to work with a Cable ISP, you have to enable the MAC Clone feature of the router. MAC Cloning is a procedure which enables a router to copy the MAC address of the computer registered with the ISP.
To set up a Linksys router with Cable connection, you need to perform four steps using the computer that's been registered with the ISP:
i. Verifying Internet Connection
ii. Connecting the Devices Together
iii. Checking the Router's LEDs
iv. Setting Up a Linksys Router for Cable Internet Connection
Connect the computer to the Broadband modem using an Ethernet cable without the router installed. If you cannot get online, contact your ISP. If it's online, use the computer to set up the router.
NOTE: Some cable modems use the USB port. If the physical connection is via USB port, you may not be able to go online via Ethernet connection. Contact your ISP to have the Ethernet port of the modem configured.
kb17251-001_en.png NOTE: The image may vary depending on the computer and modem you're using.
After confirming the Internet connection through the modem, connect the modem to the Internet port of the router; connect the computer to any of the four Ethernet ports at the back of the router. For instructions, click here.
After connecting the devices together, check the lights on the front panel of the router. Ensure that the Internet light, as well as numbered light corresponding to the Ethernet port where the computer is connected, is lit. For further instructions, click here.
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: If you are using a Mac computer to access the router's web-based setup page, click here.
Step 2:
On the Setup tab, click the MAC Address Clone sub-tab.
Step 3:
Select Enabled then click Clone My PC's MAC.
Step 4:
Click Save Settings.
Step 5:
Click the Status tab.
Step 6:
Check the Internet IP Address. If the Internet IP Address has numbers, this means the router has been properly configured. You should now be able to access the Internet. If you're still unable to access the Internet, powercycle the modem, the router and then restart the computer.
NOTE: If the IP address is still 0.0.0.0, click IP Address Release then, click IP Address Renew. If this does not change the IP Address, powercycle the modem, the router and then restart the computer.
Nov 14, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
Want to connect aDI-604UP wired router to a DIR-615 wireless router to use as a printer port wirelessly
Hello Richard.
For this, you have two types of connection
1. LAN_LAN (ethernet to ethernet) -->wireless router is acting as a switch
2. LAN_WAN (ethernet to internet)-->wireless router is acting as a wireless router
in this case, you need the LAN_LAN connection
Physical connection:
plug an ethernet cable from the ethernet port on the wired router and connect the other end of that cabl to the ethernet port on the wireless router
Configuration:
log-on to the setup page of the wireless router, do this while the wired router is turned off.
-open your internet browser, type 192.168.0.1 on the address bar. Then type the username & password for the router ( default admin as the username, password : ).
Under the setup tab, click manual configuration. Then click network settings, change the router ip address to 192.168.0.5 & disable the DHCP server. save the settings. Just personalize the wireless network.
Hope this helps.
Sep 15, 2010 | D-Link DI-604 4-Port Cable/DSL Router...
I reset router....am having problems connecting to internet. I can connect as long as I have the ethernet cable connecting from the computer to the router. When I take out cable from computer, connection...
You need the Ethernet Cable in your Router to be able to connect to the Internet.That is the only way your going to be able to have Internet.It will not work without the Ethernet cable.
Jul 31, 2010 | Linksys WRT400N Router
I can't get my router to connect to the phone jack
Connect ethernet lan cable to computer and router end.
In router there is LAN port connect lan cable to that port and connect other end of that cable to your computer ethenet lan card.
Then connect phone line jack to router's ADSL Port.
Let me know if you need further assistance.
Thanks for using FixYa.
May 07, 2010 | Linksys Wireless-G WRT54G Router
Please clarify what you mean by ''Connect with an ethernet cable''
Ethernet cable means CAT5 or UTP for others or LAN cable. The connection should be LAN port of your computer to LAN1 of your router.
And you can connect also the internet cable usually ethernet cable from your internet provider directly to (ethernet cable)WAN port of your router to get signal from your internet provider.
Also if you get this message, this could also means you still don't set up or configure the router's settings to communicate when your LAN and router. They must see each other to access the router's utility webpage.
Regards
Jul 10, 2009 | Linksys Wireless-G WRT54G Router
Cannot connect through the router
With ethernet connected
Click start
click run
type cmd then ok
type ipconfig
take note of gateway address
type this into a web browser
it will ask for username password try these:
admin/admin
admin/blank
blank/admin
admin/password
root/admin
root/password
root/blank
by blank I mean enter nothing
When you login to the modem click on the wireless settings and record the wpa/wep key this is what you need to login through wireless.
May 25, 2009 | Linksys WRT160N Wireless Router
Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Apr 10, 2009 | D-Link AirPlus DI-524 Wireless Router
Router not recognized after all wired setup is complete
Remove the CD Setup,
>If you have the Internet connection on your modem.
>Unplug the Ethernet cable at the of your computer and place it at the of the router under the Internet port.
>You should have another Ethernet port, connect the other end of that Ethernet cable to the LAN port1 and the other end to your computer.
>Access the configuration page of the router by typing 192.168.0.1 on the address bar.
>On the login page. By default the Username is admin/Admin and leave the password blank and click ok.
>Once inside, click on Setup tab> then click Manual Setup
> Your connection type should be Dynamic DHCP IP
> Click on "Clone your PC Mac Address"
> Click on save settings
> Go Status and Under WAN check if you have values in the IP address. If you have value, then that mean you have an Internet connection by now. if you got all 0.. try calling your Dlink manufacturer to assist you on conneting your router to the Internet without running the CD or by doing it manually in short..
Jan 25, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Computers & Internet Logo
122 people viewed this question
Alun Cox
David Payne
David Payne
