Question about Vacuums
Hoover tempo bagless
I went to vacuum and nothing happened.my vacuum is a hoover tempo bagless .
  • rella hoffman Nov 30, 2008
    is there anywhere i can go on the web to get instructions to do those things?
  • mackjohn Feb 16, 2009
    power off in use
    President:
  • 1,673 Answers
If it is completely dead, you could have a bad switch, cord or a bad motor. I would check it in that order.
Posted on Nov 30, 2008
  • Lauren Junge
    Lauren Junge Nov 30, 2008
    Sorry, no I don't. You might try putting in you model number into the search and see what comes up. They usually don't have service manuals, maybe a parts type manual, if you get lucky. Or you could take it into a repair shop.
Height adjustment does not work
Hello! The vacuum does not move up and down when you change the height setting. When the handle is reclined is when the height of the nozzle will adjust. Hope this was helpful!
Jun 26, 2014 | Hoover Tempo Widepath Upright Vacuum -...
Hoover Tempo Widepath - propellor not working
If you are refering to the roller underneath, the belt nees to be replaced. Simply remove 4 bottom screws and then the roller, Place new belt on roller and thenon motor shaft, pull belt with the roller to install in position and install bottom plate.
May 02, 2010 | Hoover Tempo Widepath Upright Vacuum -...
HOW DO YOU REPLACE THE BELT ON A HOOVER US140-900 WIDEPATH TEMPO VAC
To help you in your efforts to change your belt here are some good resources. This is the manual for your vacuum. It explains how to change the belt:
Manual for HOOVER U5140-900 WIDEPATH TEMPO VAC
Here you can get replacement belts for your models:
http://www.vacbelts.com/hoover-40201160-belt.htm
Oct 20, 2009 | Hoover S1410 WindTunnel Porta Power Bagged...
Need a front wheel assembly for my Hoover Tempo model u5144-900. I see similar looking Hoover wheel assemblies online for different models, will they fit mine?
The Tempo series cleaners look similar, but are different colors. The wheel assemblies will work if they look identical in appearance to yours.
Aug 07, 2009 | Hoover U5144900 / U5146900 / U5147900...
Vacuum not working
Enter "Tempo" into the following location bar once you get to this link:
http://www.hoover.com/CustomerService/Manuals/Default.aspx
There are a few different models including bagless and bagged versions of the Tempo of which you should be able to find any one of the pdf. adobe files.
Good luck and don't forget to rate.
Mar 27, 2009 | Hoover Tempo Widepath Upright Vacuum -...
Hoover Wind Tunnel bagless- issue with turning on
Have you tried to plug the vaccuum in another outlet that is on another breaker? It could be the vaccuum tripped the breaker. Turn the breaker back on. The manual mentions the thermal protector could have been activated. If this happened it resets and your vac should run after 30 minutes. I have a Widepath Tempo and it has tripped the surge protector. If this is the problem try turning some things off that are also on that breaker/outlet, or unplug them when you use the vac.
Jan 04, 2009 | Hoover U6630-900 WindTunnel Bagless...
Vacuums Logo
77 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
