Question about LG KU990 Viewty
Touch Pad beep
How do I turn off the touch pad bleep sound- I have looked at all the menu functions but I am totally lost on this one
    Problem Solver:
  • 5 Answers
Go to the settings menu, and then Profiles. Select the profile you which to apply it to, and choose edit (from the bottom left icon). One of the settings is 'Touch type', and just change that to No feedback, or Touch vibration, depending on whether you still want the vibration.
Hope that helps.
Posted on Dec 25, 2008
My neighbor disabled my Toshiba touch pad. what do i press to re enable it?
Start menu. Control panel. Go from there with keyboard options and it should work. OR research stick keys/ on screen keyboard
Feb 24, 2015 | Toshiba Computers & Internet
How do I get the microwave to stop beeping.It"s beeping and locking the controls by itself.
The touch pad sounds like it is trying to tell you it has a stuck pad. The touch pad will need replacing.
Oct 01, 2014 | GE Microwave Ovens
Touch pad has frozen/turned off for no reason. Any ideas why?
You have probably accidentally typed in shortcut for turning off touch pad. Look for function button (FN) and press and hold it, then find touchpad button ON/OFF, usually some of F-buttons has icon above it.
Mar 07, 2011 | Samsung NC10-14GW PC Notebook
Model JBGP80 MEV2BC Display panel shows "F1" and emits beeps (very annoying)... while unit seems now to be working fine otherwise. I will check and re-establish any cabling, etc. Meanwhile, how do I...
F1 touch pad / ERC test This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Sep 16, 2010 | GE JGBP80 Gas Kitchen Range
F1 error code and beeping on a ge doubleoven
Hello there:
How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    NOTE: Some models incorporate the touch pad and the clock as one part. * We have seen a few of the newer Maytag ranges with a F1 fault code and the problem was the oven temp sensor, check carefully the wires to and from the oven temp sensor!!
Jan 12, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
My touch pad is SUPER sensitive, when I type, my cursor ends up all over the place. I read up on hitting the f7 key, but I am totally computer illiterate. When you guys say hit the function key, do you...
From Dell:
Customizing the Touch PadYou can use the Mouse Properties window to disable the touch pad or adjust the touch pad settings.
  1. Click Start keyboar4.jpg , and then click Control Panel.
  2. Click Hardware and Sound.
  3. Click Keyboard.
  4. In the Mouse Properties window:
    • Click the Device Select tab to disable the touch pad.
    • Click the Touch Pad tab to adjust touch pad settings.
  5. Click OK to save the settings and close the window.
Oct 06, 2009 | Dell Inspiron 1526 Laptop
I am receiving the same error message on the display window
Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information.
Function key shorted or stuck :
Replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Sep 12, 2009 | Maytag MER6769 Gemini Electric Kitchen...
Lost my manual for chef condor integra oven - need to check auto functions and how to set them
For TOuch Control oven:
1. Press Finish Time touch pad
2.press ^ touch pad until clock displays the required am or pm finish time.
3. Press Cook Period touch pad.
4. Adjust the cooking time as in step 2, using up and down arrow touch pads. (hours and minutes needed to cook food)
5. Press Automatic touch pad.
Press Fan touch pad to select fan speed. Red indicating light shows normal speed.
7. Turn oven thermostat to desired setting.
8. Press Keep Warm touch pad if keep warm function is required at end of cooking. 9. At end of cooking time a buzzer will sound for 1 minute and the KEEP WARM cycle will now operate until the meal is ready to be served.
10. To cancel the Automatic cycle, press Manual touch pad and turn oven thermostat off.
For Multifunction oven:
1. Set time of day.
2. Turn Function switch to Finish. 0.00 will be displayed.
3. Turn display switch + to give the required am or pm finish time. (an illuminated bar in the bottom left corner indicates when the clock display is pm).
4. Turn Function switch to Cook then turn Display switch to + till desired cooking period is displayed (hours and minutes needed to cook food)
5. Turn Function switch to Auto. The automatic programme is now ready to use.
Turn upper oven thermostat to desired setting.
If keep warm function is required, turn function switch to Cook (optional)
Happy cooking!
Jun 14, 2009 | Ovens
The display at top of stove is showing "F1" and continuously beep
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Mar 19, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
F7 Code and stove beeps
F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button F7 Shorted key sensed for 32 seconds 1. Membrane shorted, or,
2.
Display board defectiveIf touch pad is a separate unit then unplug it and see if code comes back.  Unplug range before doing so.  Once touch pad is disconnected, plug range back in and see if code shows.  Wait a few minutes.  If no code then replace touch pad.  If code does come on while touch pad is disconnected then replace main control.  If touch pad and main control are all one part then replace the whole control.  Doubt if you would have any luck trying to unstick the bad button as stated above.
Oct 15, 2007 | Jenn-Air JGR8850 Gas Kitchen Range
LG KU990 Viewty Logo
105 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
