Question about ViewSonic VA520 15" Flat Panel LCD Monitor
I am using a viewsonic va520 and the colors are very bland...there is no vividness in the picture and it is mostly a gray color.
    Champion:
  • 293 Answers
Hi...there,
It's seems you got a busted AD board...
Posted on Dec 01, 2008
I cant get sound on my viewsonic va520
You need to add some information - what is the source for the video that you are viewing on the VA520? The VA520 has no speakers in it. If it is a desktop computer, look on the back of the computer for a green 3.5 mm stereo audio port. This is your speaker out connection. Plug in any set of computer speakers or headphones. (Computer speakers may require a USB connection or to be plugged into an AC outlet to power the speakers.) You can find cheap speakers for under $20; good speakers will be more expensive. With a laptop or some desktops, you'll find a headphone jack on the front of the computer. (This will be labeled with a small picture of a set of headphones.) The headphone jack is also a 3.5 mm stereo port.
I hope this helps.
(laptops usually have internal speakers; most desktops do not have any internal speaker anymore. If you have headphones with RCA audio plugs, you can use a RCA F/F to 3.5 mm M audio adapter to use them with the computer. A stereo system may not work with a computer.)
Jul 24, 2012 | ViewSonic VA520 15" Flat Panel LCD Monitor
I have an Sceptre 37"
For most TVs in the market, you would use their DYNAMIC or VIVID mode for the best picture settings.
Sep 09, 2011 | Sceptre Televison & Video
I was given a ViewSonic 520 by my father, but he couldn't find the power cord or USB cable. What do I need, and where in my area can I get them? David Hart Fort Worth, Texas 76119
You don't need a USB cable to plug in the monitor. The VA520 requires a standard power cable, available at any electronics or computer store. Same one used for a computer power supply.
Feb 28, 2011 | ViewSonic VA520 15" Flat Panel LCD Monitor
I want to know the perfect color settings for the th-42px80u
The Settings are :-
-Picture menu Picture mode: Custom
Picture: +80
Brightness: +60
Color: +44
Tint: -8
Sharpness: 0
Color temp: Warm
Color management: On
x.v.Color: Off
Zoom adjust: [grayed out]
-Advanced picture submenu
Video NR: On
3D Y/C filter: [grayed out]
Color matrix: [grayed out]
MPEG NR: [grayed out]
Black level: Light
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 10, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Cannot adjust color
Have you turned the controls from one of the presets? Presets are Vivid, Movie, etc. Most sets have to be in Custom or Customize to adjust the controls, likely on-screen with one of contrast, brightness, color, or tint selected. If those are horizontal bars then up/down selects which and right/left select decrease/increase or red/green for tint. Start with 50% if no reset (0% for R/G) or start with the non-Vivid settings. Consult AVS forums for you model to get better settings. Rules of thumb: Brightness should be as dark as possible without losing gray scale at lowest part. Contrast should not be so high that whites bloom or make it hard to see. Color should not blow out any color nor be unnatural. Tint is best judged on flesh tones. -Ken
Jul 15, 2009 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
What voltage is the dc adapter?
You will need at least a 4 amp rated regulated 12 Volt power supply.
These are commercialy available from most electronics parts suppliers.
They come on a circuit board. You can mount it in your own case and
use the original Viewsonic wire end. If you do a google search for 12
volt reglated power supplies you should find many of these.
However, with a second-hand Sprint AC adapter with 3A,
12v adapter, the screen blinks on and off
intermittently. Obviously there is some difference here between a class
2 adapter and a power supply box.
Oct 03, 2008 | ViewSonic VA520 15" Flat Panel LCD Monitor
VA520 Resolution Message
Have you tried via the Control Panel/Display function?  The driver provides the means but Windows provides access to those settings.
May 24, 2008 | ViewSonic VA520 15" Flat Panel LCD Monitor
Starts up looking good then in 3 minutes, all hell...
Go to the ViewSonic site and read through their knowledge base on your monitor.
Then once you familiarize yourself with electronics safety by reading through a basics manual once or five times, and once you've got it, open up the monitor cold and/or hot, and find out where they spilled Coca-cola down the back or whatever might be suggested by the ViewSonic knowledge base.  Lather, rinse, repeat; when the monitor acts right, then stop.
Dec 09, 2007 | ViewSonic VA520 15" Flat Panel LCD Monitor
Help.. LCD colors
Reconnect your cables!  Somehow you don't have red and green in there, just shades of blue, right?  And it doesn't depend on whether you're running a browser or something else?
Make sure everything's tight and if you can (but only if tightening cables didn't work,) check that your computer's putting out a normal signal by testing another monitor with that computer.
Nov 11, 2007 | ViewSonic VA520 15" Flat Panel LCD Monitor
ViewSonic VA520 15" Flat Panel LCD Monitor Logo
119 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
