Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Refridgerator not cold
Model #: 970-56312E
Serial #: LA43804264
Neither side of the fridge are cold or warm. I emptied the water filter cap holder, but did not take the actual filter out as the water is dripping into the cap holder.
Called Sears to send a technician. Replaced the thermostat (DTS). Fridge is now working. The themostat was $21 + service/labor total $160 +/-.
Posted on Dec 02, 2008
How big is the reservoir for the water dispenser? Also, what is the normal temperature of the water being dispensed?
??? You never gave make or model and your mouth is that accurate to tell a 17 degree difference in water temp?
Jul 02, 2015 | Refrigerators
Kenmore fridge with a strong chemical taste in water and ice
Every time you replace a water filter you want to purge about 3-4 gallons. Or maybe the filter was bad.
Dec 31, 2012 | Refrigerators
Amana green water filter light off
If your machine is only 2 months old and wasn't used when you bought it call the number on the label that has the model and serial number on it that is located either inside the refridgerator on the upper wall somewhere or somewhere on the frame. Being that whirlpool now owns Maytag, which encompasses Amana, you have a one year manufacturer warranty where parts and labor are both covered free of cost.
Apr 27, 2012 | Amana 22.6 cu. ft. Side-By-Side...
Hi, I have a GE BSS25JSRF side by side refridgerator and both sides are not staying cold. All of our food in the freezer has defrosted and all of our food in the fridge side has warmed. This all happened...
Quite right, it shouldn't. You didn't switch it off at the wall while changing the filter did you? Check you haven't disturbed the plug and that the switch is back on and making positive contact.
Oct 30, 2017 | Refrigerators
I have a dometic mod.2852 refridgerator/freezer that was working fine until a day ago when it stopped getting cold in both parts. It has power. the space between the freezer and refridgerator is very warm....
Check this link to dometic recalls first and enter your model number and serial number. There may be a recall on that fridge.
http://67.238.126.140/recall.php
Jun 13, 2011 | Dometic RM2852 Refrigerator
I have a Sub zero refridgerator 590, the refridgerator side is not getting cold, and it's icing up inside where the fresh foods are stored, yet the freezer is working fine. Please help
The freezer coils are iced up and that is blocking the sir flow to the fridge.... You have a defrost problem and that is causing the refrigerator to be warm...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 28, 2010 | Sub-Zero 690 Side by Side Refrigerator
Side by side refridgerator part too warm
Make sure the small door between the freezer and fridge is open. It should be at the top towards the rear on the wall between the fridge and freezer. Thermostat controls its open/closing. And make sure freezer is in fact freezing and you don't just have residual cold in it. Freezer should be about 0 dertees.
Feb 05, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I opened the door on this frig this morning and water poured out like a small river! It filled the frig, and leaked below into the basement. Horrible! I noticed the water streaming out of the built-in...
obviously a filter leak. the water shuts off when the filter is removed. either it wasn't installed properly or it has a bad gasket. as for the fridge getting warm, the water probably collected and froze to the evaporator coils and now resrticts the cold air flow. you need to turn off the fridge, empty it out, leave the freezer door open, and let the coils defrost on their own. or remove the back panel in the freezer and defrost the coils with a hair dryer. you will need to soak up some water, but not nearly as much. once it's defrosted, dry it out, close the doors and turn it on while it's empty. when it's cold enough, replace the food.
Jul 31, 2009 | GE Profile PSC23MGTBB Counter Depth Side...
Whirlpool gold:upper half of refridgerator side not cold
Either the evap fan has a problem, or the defrost system has failed. You should never see frost in the freezer section as the defrost sensor should sense that the coils need to be defrosted before that much frost accumulates.
Unplugging to clean out helped because the frost got a chance to melt away.
If you find the evap motor is running, then the things to check are the defrost sensor, the defrost timer, and the defrost heater.
Reply back if you would like more info.
Jan 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Frigidare side by side FRS202RG freezer cold, fridge side warm (coils frozen)
your having a defrost promblem either the adc-auto defrost control board is bad or the defrost termination thermostat is bad or the heater is bad thats rare but does happen if you will open the refridgerator door and get me the model number off the serial plate on the toop of the compartment just look up when you open the door then let me see if it has an adc or timer i can reply and be more spefic about fixing your promblem hold my rating till we are done ok
Mar 30, 2008 | Frigidaire FRS26ZSG
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
240 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
