Question about Medion md40298 Notebook
TV Tuner express card 54 DVB-T Medion
I have new Laptop 97110 and whyen I try to connect Media Centre to TV channels I get message"No tuner found" or something to that effect. I have themedion DVB-T TUNER ExpressCard54 but it is not recognised.
How can I get the Express Card working?
John
  • John Kent Nov 30, 2008
    Thanks Mike, very punctual, efficient, I'm impressed, looks real helpful, When I have tried all suggestions I'll get back.
    John
  • John Kent Dec 31, 2008
    Thank you Mike. I have tried your suggestions. Found it difficult to get any info of Medion Express card. I have been informed that the DVB-T card will only work in an area which has digitally installed TV. My arfea does not have digital TV so that may be the problem. Appreciate your help.
    Nicky 2407
    Genius:
  • 1,019 Answers
you need to install/re-install the drivers for the expresscard, should be downloadable from medion. Also check in control-panel that the device is there. If you look in My Computer/control Panel/System/Device Manager and the device is listed, with a yellow exclamation mark. try removing/uninstalling. or physically remove from the computer, re-install and go through the new hardware wizard to set it up.
Mike @ compurepair.
Posted on Nov 30, 2008
Hello, Any suggestion when to buy ExpressCard for Medion Akoya P6612, OR I just need it connector to Cable net, Win 7 exe TV Tuner software & Driver including remote controller, please?
Posted on May 18, 2010
Have had a DMR-EX75EB for a couple of years - great bit of kit but for some reason, the digital channels have all dropped out and i cant seem to get them back. I know the aerial feed is good because we...
It is possible that the built in DVB tuner of your DVD recorder has failed, since your TV still has its DVB receiver working fine. I suppose if you have tried to reset the recorder numerous times, and it still has not found any DVB channels, then yes, the DVB tuner has died - probably not economical to replace that as a separate component, since it is hard-soldered to the motherboard, making the overall replacement cost-prohibitive.
But if you want to do so, you can submit your recorder to any authorised DVD service centre for a quote, as well as a detailed description of the problem(s) (assuming the tuner is found to be the culprit); this will help you to make an informed decision as to whether to go ahead with the repair or not. Up to you.
Presuming your unit works otherwise, you should not need a new one (but an external set top box connected via the recorder's inputs may be required if you need to record channels) - but get a couple of quotes from service centres FIRST before doing anything else ((you can always say no to the quotes if they are too high).
Jun 08, 2011 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
I NEED NEW DRIVERS FOR WINDOWS MEDIA CENTRE 7 ON
Get connected to the internet and download the necessary driver software for windows media center.
Nov 07, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
Maxim 11-54 26 inch lcd tv switch mode power supply blown up need new one
I have a Maxim 15" Portable LCD TV with built in DVB-T Tuner.
It has worked well for 2 years.
Now when you switch it on set to DTV
Starts to reload the channels
Once it has found 90 channels it moves to Add and will not add any.
There are no stored channels from the built in freeview.
However we still have the normal 4 on ATV.
Any advice.
Aug 10, 2009 | Televison & Video
Cant copy recorded tv
fixed thank you.when you install dvb-t tuner software DONT let it search for available channels dont set it up just install the operating program. then using windows media centre scan for available channels. i think there is a conflict of interest between the media centre program and the dvb-t stick program. mine is pinnacle studios.the stick needs to be in the usb on boot up to be recognised.this works a treat and thinking about it could be the cause of many windows media crashes when two tuners are competing for the same signal.
regards
steve
May 17, 2009 | Toshiba Satellite Pro L350-S1001V Notebook
Got a new Dell Studio 17 laptop with TV Tuner, but TV wont go
if it is not finding channels, it could be a physical connection problem from the antenna or the antenna lead on the device.
Mar 10, 2009 | Dell Studio 17 Laptop
DVB -T Tuner express card 54
Are you sure that the correct drivers are installed and updated? Do you know what a driver is or where to look for them. What operating system are you using. Do you have the disk that came with the Acer? The disk should have the driver on it or software to make it work. How are you connecting to the card? It will be easier to have the laptop model number.
Jun 02, 2008 | Computers & Internet
Medion dvb-t tuner expresscard 54 ctx967 v7.2.2 have tv guide but window indicates hardware not detected any ideas using vista premium
I have a problem with my tv signal, and it started when i had a problem with my system so i had to farmat the system and now i can't receive any signal again from from my DVB=T and i have tryed to reprogramm with no avail.can any one help me solve this problem?Thanks
May 12, 2008 | Televison & Video
Trying to play ps2 through my pc
if u have a RCA or S-Video input on your tuner look on your remote control for a button called AV press the button and your card will enter in av mode that will be av1,av2,S-video and the card will display your signal from your ps2
Apr 18, 2008 | Computers & Internet
Dvb-t tuner express card ctx967 v7 2.2 p/n 40022821
normally, it would work with the files in the download. You have to copy it to your local drive and connect your program with these files.
download link:
http://rapidshare.com/files/161566526/TV_Tuner__optional_.rar.html
Mar 30, 2008 | Medion md40298 Notebook
Getting windows media to work with tv tuner card
its is due to the older tv tuner card drivers doesnot supports for windows mediacentre try to update driver if not change for new tv tuner card which supports mediacentre.
Feb 24, 2008 | Creative Labs Sound Blaster Live! 5.1...
Medion md40298 Notebook Logo
3,633 people viewed this question
Top Medion Computers & Internet Experts
John Anderson
John Anderson
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
