Question about Husqvarna Chain Saw 20" Bar
Husqvarna chain saw, model 455 will not oil properly bar and chai
My Husqvarna chain saw, model #455, will not oil properly bar and chain.
  • 4 more comments
  • Anonymous Mar 12, 2014
    Solo chainsaw model 654 has excessive chain oil coming up through the top of bar cover during operation
    Solo chainsaw model 654 has excessive chain oil comes up through bar cover during operation.
  • Anonymous Mar 15, 2014
    where is T screw on husqvarna 455 chainsaw
  • Anonymous Mar 18, 2014
    leaks bar oil
  • Anonymous Mar 27, 2014
    oil is full and pushing the oil knob and still no oil
  • Anonymous Mar 31, 2014
    Why does the anti kick bar trip?
  • 211 Answers
Hi cindilou50
check the oil filter from the oil tank,the oil line ,the worm gear and the oiler under the clutch.Clean the ways where the oil goes with compresed air.(after you fill out the oil tank)Also check the oil hose.
best regards savumihai71
Posted on Dec 01, 2008
What is the gas / oil ratio mixture for husqvarna 455 rancher model ?
50:1 that's 2.6 ounces of 2-stroke oil (preferably with fuel stabilizer) to one gallon of gas. I recommend using 89 octane gasoline for all small engines. It has little or no ethanol in it, as opposed to the 10% typical in 87 or 86 octane fuel. This will prevent a lot of fuel issues, especially if you are not using the tool daily or at least weekly.
Aug 02, 2014 | Husqvarna "965030298 - 455 Rancher, 20""""...
Husqvarna 455 rancher, chain getting too loose to tighten after one days use age. Bar oil topped off with every fill up of gas. Bar cleaned in the groove, etc. New chain. The bar will no longer adjust to...
indicates incorrect length chain in use
the adjustment slots should be about 1/3 when fitted moving close to 1/2 when adjusted
the correct adjustment is when the chain in the center of the bar is lifted up the bottom segments of the chain are still in the bar groove
make sure that the oiler hole is not blocked from saw dust and chips
Aug 08, 2017 | Husqvarna , No.455 Rancher, 20" Gas -...
What kind of oil do I need to use in my husqvarna 16" chain saw?
Unleaded fuel with Husqvarna two stoke oil mixed at 50-1, for the chain you need a non fling chain oil, both should be available from your local Husqvarna dealer.
Aug 21, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
No chain oil feed
not sure if the 455 rancher is the exact same as my rancher but when the oil feed on my saw seems slow i remove the chain and bar and clean the chain grove. pay special attention to the end that is near the motor there are a couple of places that allow the oil to flow from the saw body to the chain groove and then subsequently to the chain
Feb 25, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a husqvarna 257 with a 20inch bar and having oiling problems, is getting hardly any to no oil and have the oil adjuster screw the whole ways out, is the oil plunger bad?
If you take the bar off, and then run the saw, does oil come out of the saw? If it does, then the oil pump is likely working O.K.
If the oil comes out of the saw and does not make it onto the chain, it is possible that the oil exit slot on the saw, and the hole on the bar are not lining up properly. This happened on my Husqvarna 141 saw. The oil was coming out of the saw fine, but it never made it to the bar and chain. As a consequence the chain was always dry and very, very hot.
The other saws we use, always have plenty of oil on the chain. I think Husqvarna may have made a design flaw on some of their saws, and the exit point of the saw and the entry to the bar are not properly aligned. I wonder how many saws this affects.
Sep 14, 2010 | Husqvarna Chain Saw 20" Bar
Turning up the bar oil?
An “OM, 455e Rancher, 455 Rancher, 460 Rancher, 2009-09, EN, FR, ES” Follows (may not be your saw):
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2009/HOUS2009_1151382-49.pdf
An excerpt from page 38 of the above OM follows (forcing it may render it inoperative):
Adjustment of the oil pump
Adjustments are made by turning the screw using a screwdriver or combination spanner.
The machine is supplied from the factory with the screw set to position 2.
Turning the screw clockwise will reduce the oil flow and turning the screw anti-clockwise will increase the oil flow.
Recommended settings:
• Bar 13"-15": Position 1 (full CW)
• Bar 15"-18": Position 2 (center)
• Bar 18"-20": Position (full CCW)
These recommendations apply to Husqvarna’s chain oil, for other chain oils increase the oil flow by one step.
WARNING! The engine must be stopped when making adjustments.
All OMs and IPLs can be found here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Apr 27, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
I need to know the right angle to sharpen my chainsaw
If your saw still has the original bar and chain, it was supplied with a .325" pitch chain and you'll need a 3/8" round file with a sharpening guide to properly sharpen it.
Here's a link to the Husqvarna site to the Rancher 455 models so you can select the correct manual to download, that matches your particular saw, based on the year of manufacture, etc.
There is some excellent information about maintaining your saw, along with a really good guide with step-by-step instructions for proper sharpening.
http://www.husqvarna.com/us/homeowner/support/download-manuals/?query=455&types=O
If you're having trouble figuring out the right manual for your saw, use the online Customer Support page and they'll reply.
Hope you find this Very Helpful - Best regards!
Aug 19, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna Chain Saw 20" Bar Logo
1,999 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
