Question about Jenn-Air Microwave Ovens
Microwave died while defrosting
Checked power, and it is fine. Hair dryer works from plug.
  • 78 Answers
20A fuse iside microwave needs to be replace.
Posted on Nov 30, 2008
Only a few buttons on my key panel work, example the start/ clear button does not work, a few numbers do work. I think its from condensation. How can I dry this out? Can I use a hair dryer?
Yes you can use a hair dryer but the power should be off so that you don't short it out any more than it already is. Most likely the keypad has been ruined and will need replaced., Once these go bad there is no fix except to replace the keypad.
Apr 23, 2011 | LG LMVM2055 Convection/Microwave Oven
The microwave had been working fine we now have no power at all
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Feb 21, 2010 | Maytag MMV5207AAS Microwave Oven
Built-in Sharp Carousel II Microwave Convection Oven died.
There are a couple of safety thermostats in the oven to shut down power if something overheats. One is on the magnetron tube (the microwave source), the other is on the cooking cavity. These sometimes go bad. There's also a power line fuse that may have failed, or become loose in its mounting clips. These can be tested with an ohmmeter; they should all measure very close to zero ohms if they're good.
Another possibility is that the control circuit board in the oven may have failed. I have worked on several Sharp ovens where the power transformer for the board has gone bad for no good reason. If the board goes bad the oven may appear to be dead as well.
Microwave servicing is best left to professionals. If you're thinking of keeping this one, take it to a service shop (or call for home service) and get an estimate. Then decide whether to repair or replace.
Hope this has helped a little. Thanks for using Fixya!
Feb 02, 2010 | Sharp R-1874 Convection/Microwave Oven
Microwave stopped working, no power. Checked
There are two thermal fuses.
One is located on the magnetron and another one is located on top of the left side of the cavity under the air duct. The microwave has to be removed from the cabinet to access the second one.
The problem turned out to be a 20 amp fuse that I was able to replace and the unit is working fine. Sometimes a blind squirrel finds nuts.
Aug 24, 2009 | Kenmore Microwave Ovens
Our Emerson microwave died and I bought a new one. Plugged it into the same socket and it immediately shorted out and died. After the new microwave died I plugged a blender into the same receptacle and it...
I believe you have a bad circuit breaker or fuse. If you have a delay fuse contrilling this circuit, that would explain the spotty availability of power to the outlet. Also, a faulty circuit breaker can operate in an irregular way, as you describe.
A microwave oven requires a lot of power, relatively speaking. If your microwave is a 1200 watt model, for example it draws 12 amps of power, which could well be almost all of the power available at that outlet, providing that other appliances were not also drawing power from that circuit at the same time.
I can assist you further, but if this information is all you need to proceed that is fine too. Get back if you need more assistance.
Jul 02, 2009 | Microwave Ovens
We have a JVM1870SF02 Microwave Oven. Everything
Is it on a gfci plug? If it is reset that. If not I would recheck the circuit breaker again
Sep 23, 2017 | GE Microwave Ovens
GE Sensor Microwave JES1855 died
Mine went dead after about 6 months. I had problems with my breakers and I found out that it was the microwave that blew all of them. I also found out that this perticular microwave is a fire hazard and should be recalled. It has caused me alot of headache. The breakers in my house are brand new and they are put out by GE also. It caused me to loose the food in my freezer, I did not know my freezer had lost power. It would cause my entire lights to go off and then they would come back on. I have checked around and I found out that the power cord on the back of the unit is very loose. I had a person to come in and look at it, he thinks its the power cord.
Feb 20, 2009 | GE JES1855 Microwave Oven
GE MicroWave JES1136WL01 died while defrosting.
Mine has the same problems. After removing top cover, check fuse on power supply board (mine was OK). Then check thermo fuse located to the far left under the top cover( 2 black wires going to it) using a meter. I then jumped this fuse to see if this was the only problem. I hope to find a replacement thermofuse at the local hardware store.
Nov 17, 2008 | Microwave Ovens
Panasonic NN-8501V Convection beeps on AUTO DEFROST when cold
I'm replying privately with complete details.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 13, 2008 | Microwave Ovens
Emerson MW8168B Microwave
pls check fuse replace with since there were no noises seems pretty straight forward
Jul 30, 2007 | Emerson MW8168B Microwave Oven
Microwave Ovens Logo
63 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
