Toro Blowers Rake and Vac - Electric Blower/Vac - 51573 Logo
Posted on Nov 30, 2008
#51574 Toro Rake&Vac--Lost manual
Haven't used since summer; Set for vac. I don't know how to get it to levaf blowing mode. Please instrcut.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 20, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
344
Points
You should have another door that goes in front of the impeller (blade) which doesn't have a vacuum attachment. You should first detach the vacuum door from the bottom, put on the blower tube, and install the other door that came with the blower. Hope that helps.
My toro blower will start but sucton not blowing the leaves where is the switch located
Remove the vacuum part and install the protection grid over the intake propeller. This protects you from getting caught in the propeller and engages the safety switch witch allows you to use it as a blower.
Dec 18, 2014 • Toro Garden
Toro model 51575. Was using it as a vacuum and it just shut off. Checked breakers ...all ok. Plugged it in direct to outlet and still nothing. What might be the problem?
If you're Toro electric blower is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower Vacuums)
Search E-bay for: "Toro Blower Carbon Brush"
- 12 Amp leaf blowers Toro Super (Old model 51552) through Toro Ultra (New model 51609).
- 10.5 Amp leaf blowers Toro Old through Toro New model 51573.
- 7 Amp leaf blowers Toro model 51586 and other Toro 7 amp blowers
1helpful
Where can I get a manual for a toro CCR-3650
go to www.toro.com and should be able print it there.
Need to know the points and coil setting 3hp brigs
The easiest way to set points and coills on most brigs engines is get a pack of matches and rip the cover off them and use this as the tool to gap your points and coils it is cardboard so magnets do not bother it and it just happens to be around 25 thou which is the center of the adjustment on most Brigs. Hope This Helps Don
3helpful
4answers
2answers
Toro Rake and Vac model #51573
I was able to find PDFs of manuals from the manufacturer directly at this site: https://homeownersolutions.toro.com
Just run a search based on your model. In this case, simply type in 51573 in their search box. You get access to an online interactive manual and also makes PDF available.
Top Toro Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Toro Garden Expert? Answer questions, earn points and help others
