Question about Humax DRT800 TiVo 80-Hours Video Recorder
Black and white picture
I only get a black and white picture when viewing thru my Humax Series 2 (DRT800), including TiVo menus. Terrestial transmission (not going thru the Humax) is normal. I tried changing out the cable connected to the recorder output (red/yel/white connectors) but that did not help. Also tried resetting the system.
I contacted Humax and they said they'd not heard of the problem before and could offer no help.
5 Suggested Answers
WebTeligent
  • 42 Answers
SOURCE: Humax Tivo will not record to DVD
After the update to 1.15 I had to delete EVERY recording on the unit. After that, any new recordings would burn just fine. However, some have found that same failure even after a hard reboot (repower). Called Humax level-1 support and they suggested a replacement unit so I swapped it out. But I've since learned that TiVo "pushes" a DVD firmware patch (possible supplied by Humax) from 1.08 to 1.15 and that patch is the culprit. That patch is suppose to make the DVD burn at a higher spin rate. After talking with level-2 Humax support they heard of the problem and said "the unit is working as designed", meaning, the DVD drive manufacturer specs say the drive is capable of a faster burn rate. So now I have Humax DTR800 #2 and so-far-so-good, but TiVo hasn't pushed the patch onto the box yet!
Posted on Nov 10, 2007
  • 6 Answers
SOURCE: Humax DRT800 DVR recorder has no sound
Loss of sound is often a problem with the SCART connections. The SCART may not be pushed in securely, or if the SCART is old the pins may not be good. Check SCART is securely in, or try another SCART lead.
Posted on Mar 22, 2009
SOURCE: Humax Tivo Stuck on the welcome screen
I just had the same problem with mine and found another post that at least fixed mine.
I had a DVD in the unit as it was restarting. I took a flathead screwdriver and opened up the DVD slot by inserting at the top right corner and opening the door. On the inside, at the bottom right, is a button that ejects the DVD player (the eject button on the outside won't work while it's booting up). I ejected the DVD that was in it, unplugged the unit for 30 seconds, and then it rebooted just fine.
Hope it works out for you too...
Posted on Aug 20, 2009
SOURCE: I can't find a Humax/Tivo repair service san francisco peninsula
Try tivorepair@gmail.com. Services SF Bay Area (Peninsula, San Jose, East Bay). They make housecalls. Can repair and upgrade all Tivo's - Series 1, Series 2, Series 3 (including your Humax)
Posted on Sep 16, 2010
How do I connect my Humax TiVo Dvr to to the free dish network apartment system?
Hi Lannie, my name is Mike Houston a Social MediaRepresentative at DISH. Connecting a TiVo box to an existing DISH connectionwill depend on a couple of things. Is there a DISH receiver in the apartment?What kind of connections do you have for the TV, HDMI, RCA, or Coax connections?I will send you my e-mail so I can assist you better; michael.houston@dish.com.
Apr 15, 2012 | Humax DRT800 TiVo Video Recorder
How can i program the Humax remote control (RM-F01) to work with my Sony TV and DVD
In the Setup Menu, Go to Remote,
Select your TV Type and try the different codes.
Jan 30, 2010 | Humax DRT800 TiVo Video Recorder
TIVO output is black and white only.
To solve this problem, I powercycled my TIVO.
Sep 17, 2009 | Humax DRT800 TiVo 80-Hours Video Recorder
Apr 16, 2009 | Humax DRT800 DVD Recorder w/ 80 hr Tivo
Mar 13, 2009 | Humax DRT800 DVD Recorder w/ 80 hr Tivo
Can I use HUMAX like a 24 hour surveillance recorder?
For the TIVO series 2: hit the TIVO button, then go to messages and settings, then to to video input, then go to change input, then pick which input your camera uses. It will ask you if you can see the picture. If you can click the answer and then hit the select button. Then hit the TIVO button again then hit watch live tv.
The Humex should work very similar.
Sep 10, 2008 | Humax DRT400 TiVo 40-Hours Video Recorder
Connecting my Humax Series 2 Tivo to a Motorola HD DCH3416 Cable Box
Yes, the Tivo will just record in standard definition, instead of high def.
You can still hook the two up together, though.
What I would suggest (and have done in the past) is this:
Split the cable coming out of the cable box.
Hook one up to your HD cable box, and the other up to the Tivo.
Hook the output of your HD cable box to one HD input on your TV
Hook the output of your Tivo up to a different (non-HD) input on your TV.
This will allow you to watch HD while recording standard definition, and vise versa.
Running the HD through the Tivo will work, but will limit you to not be able to watch HD through it.
Aug 10, 2008 | Humax DRT800 TiVo Video Recorder
Nov 10, 2007 | Humax DRT800 DVD Recorder w/ 80 hr Tivo
Humax DRT800 TiVo 80-Hours Video Recorder Logo
96 people viewed this question
Top Humax Televison & Video Experts
Andy Fraser
Andy Fraser
Are you a Humax Televison and Video Expert? Answer questions, earn points and help others
