Question about Palm Treo 650 Handheld
Stereo headset jack broke
I droped it when listening to music and a little tiny piece of plastic is broke on the inside edge where you stick the headset into. It still works but now I have to jiggle the head set because it won't hold it in securely. Is there a replacement part any where or does any one have an idea? Thanks everyone
    Problem Solver:
  • 5 Answers
Mean Dean, I would check out http://tinyurl.com/e8vlc (or go to http://treotricks.com and look on the side bar for audio jack fix). I have not used him so don't know how effective this is but he certainly seems knowledgeable. If you are the DIY type, he has detail instruction on how to fix it yourself.
Posted on Jun 15, 2007
Wondering with tools I need to remove the black screws and where can I find them.
If you are referring to the jack at the edge of the unit, you can't access the inside of it from inside the case at all. It is a closed unit that has electrical contacts attached. You need to go in the hole you show and pull it from there. It appears that the plastic tip has ome of it sticking out of the hole. Is that correct? If so you can grab the edge with a tiny pair of needle nosed plyers and yank! Another way is to get a dental hook tool and pull it from inside the plastic tip....good luck!
Jan 02, 2013 | Video Game Consoles & Games
925 is paired but has no sound
i had a similar problem. what had happened was maybe a piece of small lint or plastic got inside or broke off inside of headset and blocked the tiny hole at the tip. anyways, use a safety pin or anything small enough to unblock the hole.
Sep 22, 2012 | Plantronics Discovery 925 Bluetooth...
Only the left speakers are working 2010 altima
if the radio and DVD work, and only one channel comes on when you plug in your iPhone (i assume used for music), you may have a mono plug
(the tip looks like two pieces of metal, separated by plastic), going into a "stereo" jack (the stereo plug going into this should look like three pieces of metal, separated by two plastic).
for the earpiece with mike, used on a cell, that plug would look like four pieces of metal.
Feb 19, 2012 | 2010 Nissan Altima 2.5
Hello: I have had my ipod touch for a long time now no problem until now.....i have ipod touch 3G 32gb and whenever i listen to music....and i put my headphones in the jack. If i move the ipod itself like...
smoething like that happened to me. do you wrap your headphones around the Ipod when you're not using it? The connections inside the headset can break if you do that, and if its not the headset, then it is likely that something in the general vincinity of the headphone jack is loose.
Feb 02, 2011 | Computers & Internet
Cant hear music through my LG HBS-200 Bluetooth Stereo Headset
I have the same problem with my HBS-250. It was working fine on my iPod Touch. It worked the first couple of weeks on my iPhone 4 then stopped playing music. Phone funtion works. No music or podcasts or streaming from the web
Sep 12, 2009 | LG SGBS0001606 Bluetooth HBS-200 Stereo...
Headphones are only working in one ear.
This is a common problem. All stereo adapters will only play in the right ear. What you should do is send back the headset adapter and get a stereo headset that plugs directly into the 2.5mm jack, without going through an adapter. That should solve the problem.
Aug 03, 2009 | LG VOYAGER VX10000 Cellular Phone
I dropped my Blackberry Curve and the phone clicks...
the volume button may be stuck in a weird position on the inside. you may want to take it apart and clean the inside and reassemble. if you cant then a local repair shop may be able to do it for you
Apr 27, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
The guitar lead plug has fallen inside.
The safest way to fix this is to take the amp apart to get at the jack. If the jack is a solid black plastic shape, then you should replace the jack completely. Otherwise you should have access from the side of the jack to remove the piece of hte plug that broke off.
Dan
Feb 18, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
Setting up phone to s9 headset.
I bought the same headset and also have a K1m, I did research and found out that the k1m does not have a2dp technology so it will not play music on any bluetooth stereo headset, in order to listen to music through a headset you will have to get the handsfree wired stereo headset, bummer
Sep 14, 2007 | Cell Phones
Palm Treo 650 Handheld Logo
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
