Question about Zanussi ZWF1430W Front Load Washer
Hello there,ok my washing machine makes this weird noise when its spins.but i have noticed this for a couple of weeks now ive emptied the filter to clean it but now it wont do nothin and the pumb makes noise which dont sound normal to me .but its drained ok so HELP ME PLEASE ITS ONLY 11MONTHS OLD
  • Zanussi Master
  • 3,463 Answers
If washer is only 11 months old, then I suggest you contact the service agent for your m/c..
It should still be under guarantee.
Good luck
Posted on Dec 01, 2008
When spinning on highest spin make very loud noise like brick inside then heard loud bang and noise stopped washer carried on spinning
Hello that sounds like a broken spider that's blotted to the drum what hold the drum to the bearings if one is broken that will do that the banging is when it pop out on a spin it sounds like a brick hitting the back I would be very carefull as it can try and flip the machine if it catch the drum it's not bearings as you said it stopes and it was ok so it's the spider and most drums are sealed units so you can't do any thing ok hope this has helped you
Nov 13, 2015 | Washing Machines
Why does my front loader make a banging noise while spinning?
Ive checked thru the top and back cant notice anythin brohen but when i do spin tbe tub the banging noice is coming from in tbe drum and its pretty wobbley
Aug 28, 2015 | Washing Machines
Bosch logixx 8 varioperfect
you will have a broken spider in the machine
Jul 22, 2014 | Washing Machines
Washer does spin and it makes a weird noise
Not familiar with model but must cases its the drain pump blocked. water needs lowered before spin cycle works. Lay drain hose out the door to empty. Drain pump is down bottom beside where this hose comes out. Undo the filter bung there and clean out
Dec 13, 2009 | Kenmore 24032\24036 Top Load Washer
Whirlpool washing machine won't spin
its probably your motor coupling u have to take pump and motor off to get to it
Apr 15, 2009 | Washing Machines
Washer won't spin, but making funny noise and water drains
You have a broke motor coupling broken between the motor and transmission the part is not expencive but a little hard to explain how to put it in.
Mar 29, 2009 | Whirlpool Washing Machines
Admiral makes rattling noise during spin
Hello, could be a possible bad pump. I would lean the washer back so you can see the belt. take the belt off and spin all of the pulleys. the pump pulley has a s leave that sometimes makes a grinding noise.
Jan 05, 2009 | Admiral AAV7000A
Whirlpool top load washer LSQ9610LG0 wont spin but makes noise
HI thanks for your question. the part that failed is called the motor coupling. it s located on the motor and the transmission. if you need help to replace come on back. but that's the part you need to change. thanks
Oct 14, 2008 | Whirlpool LSQ9610L Top Load Washer
Zanussi ZWF1430W Front Load Washer Logo
81 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
