Question about Philips GoGear SA178 MP3 Player
My Philips GoGear (4 GB) is showing a symbol indicating that the battery needs a recharge (battery symbol with a thin red line at the far right - within the symbol). I thought I could recharge it by plugging it into a USB port on a powered-up computer. It's been plugged in for about 1 hour, and the battery symbol hasn't changed. Is it charged up, or simply not recharging? If the latter, how do I recharge it? Thank you.
  • 8,596 Answers
Make sure the hold/lock is not engaged- it will prevent the player from charging.
Posted on Jan 03, 2009
My philips gogear vibe wont turn on
Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip,
if you're device isn't working properly or there's a frozen display.
Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off.
If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager."
This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button.
Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode.
Click the "Repair" button when it appears on your computer, then folow the steps to fully recover the GoGear.
Properly disconnect your GoGear from your computer and restart the device.
Recharge your device if your GoGear dies suddenly while playing.
Connect the GoGear to your computer via the supplied USB cord.
Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on.
This will begin the charging process of your GoGear.
If recharging doesn't work, the battery may need to be replaced.
Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
hope this helps
Oct 07, 2012 | Philips GoGear ViBE SA1VBE08K MP3 Player
My philips gogear 4g is pluged in and works but when i unplug it it says low battery and shuts off immediatly it has been left on for 4 hours now trying to fully charge it will not charge is the battery...
If the media player battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Aug 26, 2011 | Philips GoGear ViBE Digital Media Player
Hello, I have a question: how many hours do i have to recharge my Philips GoGear SA018 mp3 player? In the guide its written to keep it for 3h and when the light is green it means its recharged,however...
If its new and your having this problem DO NOT hesitate to take it back. However most new gadgets when charging for the first time may require a bit more charging time than stated in the manuals.
If the problem persists take it back.
Aug 12, 2010 | Philips GoGear Clip SA018102S/02 2 GB MP3...
My iphone 3gs won't turn on. If i plug it into charge then it comes up with a small red line on the battery symbol (like the battery is about to run out) and a lightning bolt symbol. If i unplug the...
Sounds like you have at least a broken battery. Apple should give you a replacement. If you're out warranty, you can try to open it and replace battery. If that fails you need a new logic board. You can get the part at iPad Repair and there is a guide that shows you how to open a kindle and install parts at iPad Repair Guide.
May 18, 2010 | Apple iPhone Smartphone
Philips gogear 1 gb mp3 not showing default folders.
Double-click My Computer
Double-click the Philips icon
Go to Tools --> Folder Options --> View --> check Show Hidden Files and Folders
The fodlers should now show
Mar 08, 2009 | Philips GOGEAR SA6045 MP3 Player
Battery recharge problem
Make sure the hold/lock switch is not engaged
Jan 06, 2009 | Philips GOGEAR SA6045 MP3 Player
Unable to recharge
Philips GOGEAR 4 GB mp3, unable to download videos to it
Merry Christmas Leo! Just got a GoGear for my son and my daughter. I used the bundled application to convert a DIVX AVI file to the Philips GoGear format. Then just open the Windows Explorer, locate the Video folder on the Philips (which should show up as removable drive). Then copy the file over as you would any other data file.
Dec 25, 2008 | Philips GOGEAR SA6045 MP3 Player
Switch the lock symbol on the bottom of the player to unlock the little button from left to right. That should do the trick.
Apr 17, 2008 | Philips GOGEAR SA6045 MP3 Player
Lightning Strike in Battery Symbol
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Feb 15, 2008 | Philips HDD120 MP3 Player
Philips GoGear SA178 MP3 Player Logo
123 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
