Question about Canon FAX-JX200
Line in Use
Cannot delete or turn off
Try pressing start button to receive your fax. Ours is the same, but we can't receive any faxes without pressing the start button.
Posted on Jan 14, 2009
USING INSERT KEY ON ASUS LAPTOP. KEY SAYS DELETE AND INSERT BELOW IT. IT WON'T WORK.
The problem with the Insert key is that people press it twice, just to make sure it was pressed. It is a toggle key, so first press allows Insert, and the second press turns it off.
The Insert key allows you to type in a line of text deleting the character that is in front of it as the new characters go in.
The Delete key just deletes anything in front of it, or any file or folder highlighted at the time.
Nov 28, 2016 | ASUS Computers & Internet
How do I remove the red flashing light on my phone?
probably means that you either have a missed call or message on your machine try deleting the call history and deleting all old messages. that might turn it off
Mar 24, 2015 | Aastra Telecom Aastra M9417CW 2-Line...
My grandson inserted his name on the icon line along with the icons such as maps, you tube etc - how does one delete it? There are also games he downloaded within this section that I want to delete. The...
If you mean you now have a name at the bottom line on the screen (same line as where your clock and start button appear), then this is the Task Bar. Hold the left mouse button down on the item to be removed, and then drag the item onto the main desktop area. Then release the button, now try to delete it again.
Aug 06, 2013 | Computers & Internet
There is only one OS, but during booting it shows three
Delete the OS Command line inside the MSConfig indow by clicking start - run -type msconfig then press enter. On the MS config window click on the boot.ini tab then you will see the command line inside the text box. Leave the first command line from [Boot Loader] till the end of the command line of your Default Operating system.
Example:
(Leave this lines)
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect
(Till here!)
(Delete this line)
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Viz XP Example line Professional" /fastdetect (up to here)
any other command line that says Viz XP -- you may delete it. Click apply button then Restart the computer afterwards and this should fix the issue.
Should you have any other questions just please leave a comment.
Cheers~
Jun 28, 2010 | Intel D845GVSR Motherboard
Printer keeps printing one line gibberish and then scrolls on
1) click the printer icon in the tasktray to open the printer tasks and delete any active print jobs, and wait for the task to be deleted.
2) power off the printer and power it back on that should clear it.
3) you may need to power it on and off more than once.
Apr 13, 2009 | HP DeskJet 920c InkJet Printer
How do i delete stored memory?
If you want to delete data line by line kindly refer page22 of the below manual
http://www.brother.ca/en/products/pdf/manuals/SX4000-UG.pdf
If you want to erase all the data . Turn of the unit press and hold the power button for 20 seconds. This will clear the memory.
Nov 14, 2008 | Brother SX-4000 Typewriter
Delete from Outlook subject line
hi,
create folder and copy all the messages in.
Now right-click the folder containing the messages and click on delete..
Please let me know when your successful or not.
Cheers
Dec 16, 2007 | Microsoft Outlook 2003 for PC
Delete more than 4.omb
I think the problem is that you deleted one of the syst. file on the RCA Lyra.. These are the files you need to have in order to make the mp3 player work.
Setting.dat
Music.sec
Time.dat
music.lib
and the 4 folders (Voice) (line-in) (FM) (audible)
Nov 27, 2007 | RCA Lyra RD2217 MP3 Player
Memory full display when trying ty fax
Thks for the above info. Went to my 530 to fix same problem and didn"t work. Mem in use light kept flashing. Re-traced phone line and outside line and found they were plugged into wrong jack. Moved the phone to the phone plug and outside line to outside line, and problem gone. This worked for me but there may be other causes that will make this happen
regards
oldcoot
Oct 28, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Canon FAX-JX200 Logo
62 people viewed this question
old marine
old marine
